ONTAP Hardware
hw_assist Error Messages
ymakoto
IHAC who receives the following error messages from FAS3170A(XXX01, YYY02).
Thu Nov 25 11:21:00 JST [XXX01: cf.hwassist.notifyCfgFailed:CRITICAL]: Failed to notify hardware-assist
configuration to hardware module (RLM): RLM status unknown(4)
Thu Nov 25 11:21:00 JST [XXX01:rlm.driver.timeout:warning]: The software driver for the Remote LAN Module (RLM) detected a
problem: RLM status unknown.
Mon Nov 29 17:22:16 JST [YYY02: cf.hwassist.notifyCfgFailed:CRITICAL]: Failed to notify hardware-assist configuration to hardware module (RLM): RLM status unknown(4)
Mon Nov 29 17:22:16 JST [YYY02: rlm.driver.timeout:warning]: The software driver for the Remote LAN Module (RLM) detected a problem: RLM status unknown.
As far as I can see, RLM and hw_assist seem to be configured properly.
The IP of VIF isn’t available in cf.hw_assist.partner.address option?
I’d appreciate any advice
=== hw_assist status, test ===
XXX01> cf hw_assist status
Local Node(XXX01) Status:
        Active: XXX01 monitoring alerts from partner(YYY02)
        port 4444 IP address 10.154.196.37
Partner Node(YYY02) Status:
        Active: YYY02 monitoring alerts from partner(XXX01)
        port 4444 IP address 10.154.196.38
XXX01>
XXX01> cf hw_assist test
cf hw_assist: test command successful.
YYY02> cf hw_asssist status
Local Node(YYY02) Status:
Partner Node(XXX01) Status:
YYY02>
YYY02> cf hw_assist test
=== RLM Status ===
XXX01> rlm status
        Remote LAN Module           Status: Online
                Part Number:        110-00154
                Revision:           A0
                Serial Number:      950749
                Firmware Version:   4.0
                Mgmt MAC Address:   00:A0:98:28:D5:6B
                Ethernet Link:      up, 100Mb, full duplex, auto-neg complete
                Using DHCP:         no
        IPv4 configuration:
                IP Address:         10.154.196.35
                Netmask:            255.255.252.0
                Gateway:            10.154.199.254
        IPv6 configuration:         Disabled
YYY02> rlm status
                Revision:           A0
                Serial Number:      950965
                Mgmt MAC Address:   00:A0:98:28:D5:2F
                Using DHCP:         no
        IPv4 configuration:
                IP Address:         10.154.196.36
=== Network Config ===
XXX01> ifconfig -a
e0M: flags=0x2108866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:a0:98:27:ee:32 (auto-unknown-cfg_down) flowcontrol full
e0a: flags=0xad48867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 02:a0:98:27:ee:32 (auto-1000t-fd-up) flowcontrol full
        trunked vif11
e0b: flags=0xad48867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        trunked vif11
e1a: flags=0x8bd0a867<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,VLAN> mtu 9000
        ether 02:a0:98:27:ee:30 (auto-10g_sr-fd-up) flowcontrol full
        trunked vif10
e1b: flags=0x350a866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:07:43:06:e2:74 (auto-unknown-cfg_down) flowcontrol full
e2a: flags=0x8bd0a867<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,VLAN> mtu 9000
        trunked vif10
e2b: flags=0x350a866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:07:43:06:e2:52 (auto-unknown-cfg_down) flowcontrol full
lo: flags=0x1948049<UP,LOOPBACK,RUNNING,MULTICAST,TCPCKSUM> mtu 8160
        inet 127.0.0.1 netmask-or-prefix 0xff000000 broadcast 127.0.0.1
        ether 00:00:00:00:00:00 (VIA Provider)
vif11: flags=0x22d48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.154.196.37 netmask-or-prefix 0xfffffc00 broadcast 10.154.199.255
        partner vif11 (not in use)
        ether 02:a0:98:27:ee:32 (Enabled virtual interface)
vif10: flags=0xa3d0a863<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,VLAN> mtu 9000
        partner vif10 (not in use)
        ether 02:a0:98:27:ee:30 (Enabled virtual interface)
vif10-2409: flags=0x394a863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 9000
        inet 10.154.207.129 netmask-or-prefix 0xffffffc0 broadcast 10.154.207.191
        partner vif10-2409 (not in use)
        nfo enabled
vif10-2410: flags=0x394a863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 9000
        inet 10.154.207.193 netmask-or-prefix 0xffffffc0 broadcast 10.154.207.255
        partner vif10-2410 (not in use)
YYY02> ifconfig -a
        ether 00:a0:98:27:e9:a6 (auto-unknown-cfg_down) flowcontrol full
        ether 02:a0:98:27:e9:a6 (auto-1000t-fd-up) flowcontrol full
        trunked vif11
        trunked vif11
        ether 02:a0:98:27:e9:a4 (auto-10g_sr-fd-up) flowcontrol full
        trunked vif10
        ether 00:07:43:06:e1:99 (auto-unknown-cfg_down) flowcontrol full
        trunked vif10
        ether 00:07:43:06:e2:5c (auto-unknown-cfg_down) flowcontrol full
        inet 10.154.196.38 netmask-or-prefix 0xfffffc00 broadcast 10.154.199.255
        ether 02:a0:98:27:e9:a6 (Enabled virtual interface)
        ether 02:a0:98:27:e9:a4 (Enabled virtual interface)
        inet 10.154.207.130 netmask-or-prefix 0xffffffc0 broadcast 10.154.207.191
        inet 10.154.207.194 netmask-or-prefix 0xffffffc0 broadcast 10.154.207.255
        nfo enabled
Thanks
Makoto Yoshida
3 REPLIES 3
ilgiz_nabiullin
Hi
1. Please check network interfaice e0m up???
2.If not - ifconfig e0m up
If not
Change options.cf.assist address from e0m interfaice to e0a.
Example
ifconfig -a
options
cf.hw_assist.enable on
Change cf.hw_assist.partner.address xxxx (IP address e0a)
cf.hw_assist.partner.port 4444
Check
cf hw_assist status
cf hw_assist test
ymakoto
Thank you for replying.
RLM is configured, but e0M isn't configured.
e0a is a part of vif named 'vif11'.
cf.hw_assist.partner.address is currently set the ip of vif11.
cf.hw_assist.partner.address accepts only e0M or e0a?
The IP of vif isn't supported on cf.hw_assist.partner.address option?
ilgiz_nabiullin
Note: RLM is required.
If filer is in a clustered state, go to one of the filers and issue the  command to check the current status:
>cf hw_assist status
Local Node(netapp1) Status:
  Inactive: filera not monitoring alerts  from partner(filerb)
  Fail to bind UDP socket to port 4444 IP address  10.61.69.125
To configure hw_assist, you will need to determine  which interface you will use for the configuration. Interface e0m is preferred  when setting up hw_assist to separate traffic, but e0a is the default if e0m is  not configured and online. If you will be using e0a, you will need to make sure  name resolution is working. No additional configuration is needed to use  e0m.
  1. Determine the interface to use:
        filera> ifconfig  -a
        e0M: flags=948043 mtu 1500
        inet 10.61.69.122 netmask 0xffffff00  broadcast 10.61.69.255
      partner e0M (not in use)
      ether  00:a0:98:0c:3d:a6 (auto-100tx-fd-up) flowcontrol full
        e0a: flags=948043  mtu 1500
        inet 10.61.69.120 netmask 0xffffff00 broadcast 10.61.69.255
       ether 00:a0:98:0c:3d:a4 (auto-1000t-fd-up) flowcontrol full
         filerb> ifconfig -a
        inet  10.61.69.127 netmask 0xffffff00 broadcast 10.61.69.255
      ether 00:a0:98:0c:40:3e (auto-100tx-fd-up) flowcontrol full
         e0a: flags=108042 mtu 1500
        inet 10.61.69.125 netmask 0xffffff00 broadcast  10.61.69.255
      ether 02:a0:98:0c:40:3e (auto-1000t-fd-up) flowcontrol  full
  2. Turn on hw_assist on for both heads (if needed):
      > options  cf.hw_assist.enable on
  3. Set the partner address for hw_assist:
      filera> options  cf.hw_assist.partner.address 10.61.69.127
      Validating the new hw-assist  configuration. Please wait...
      filera>
      filerb> options  cf.hw_assist.partner.address 10.61.69.122
      filerb>
  4. Set the hw_assist port for both heads (if needed):
      > options  cf.hw_assist.partner.port 4444
  5. Check hw_assist status for both heads (may take a few minutes):
        filera> cf hw_assist status
      Local Node(filera) Status:
      Active:  filera monitoring alerts from partner(filerb)
      port 4444 IP address  10.61.69.122
      Partner Node(filerb) Status:
      Active: filerb monitoring  alerts from partner(filera)
      port 4444 IP address 10.61.69.127
         filerb> cf hw_assist status
      Local Node(filerb) Status:
      Partner Node(filera) Status:
The status will not change to monitoring alerts from the partner until the  next keep alive ping has been received. Once the ping has been received, the  status will change to active for both the local and partner node.
As an alternative, test the configuration with the test command:
   > cf hw_assist test
