ONTAP Recipes
ONTAP Recipes: Easily configure KMIP servers for NetApp volume encryption in ONTAP 9.3
ontap_recipes
ONTAP Recipes: Did you know you can…?
In ONTAP 9.3, you can configure KMIP servers for NetApp Volume Encryption.
 1. If you are upgrading to ONTAP 9.3 from a previous version, delete any external key management configurations for the cluster:
 cluster1::> security key-manager delete-kmip-config
 2. Configure key manager connectivity for cluster nodes:
 cluster1::> security key-manager setup
 3. Enter the appropriate responses in the wizard.
 4. Add a KMIP server at the IP address 20.1.1.1:
 security key-manager add -address 20.1.1.1
 5. Add another KMIP server for redundancy:
security key-manager add -address 20.1.1.2
For more information see the ONTAP 9 doc center
Earn Rewards for Your Review!
GPI Review Banner
All Community Forums
