ONTAP Recipes
ONTAP Recipes: Easily create a SnapLock volume with Volume Append mode enabled
ontap_recipes
Did you know you can…?
1. Install the SnapLock license
license add -license-code <key>
2. Initialize the compliance clock on all the nodes of the cluster
snaplock compliance-clock initialize -node <nodename>
3. Create a SnapLock aggregate of the appropriate SnapLock type
storage aggregate create -aggregate <aggrname> -diskcount <count> -snaplock-type <enterprise|compliance>
4. Create a volume on the aggregate created.
volume create -vserver <vservername> -volume <volname> -aggregate <aggrname> -size <size>
5. Once the volume is created, enable the volume append mode
volume snaplock modify -vserver <vservername> -volume <volname> -is-volume-append-mode-enabled true
For more information, see the ONTAP 9 documentation center
3 REPLIES 3
Re: ONTAP Recipes: Easily create a SnapLock volume with Volume Append mode enabled
Jeff_Yao
thanks for the info
octavian
How does one set a retention policy on a "snaplocked" volume?
mbob
Hi, thank you for this recipes. I was looking for some more detailed information about this promising feature but wasn't able to find it either in then NetApp documentation nor somewhere in google ... Where can I find some general informations about its functionality (is-volume-append-mode-enabled)? Can you say which ontap release you are working with? 'is-volume-append-mode-enabled true' seems to be an invalid argument for 'volume snaplock modify' in our 9.1 ...
Earn Rewards for Your Review!
GPI Review Banner
All Community Forums
