Community maintenance is complete. Thank you for your patience!
ONTAP Recipes
ONTAP Recipes: Easily identify throughput and latency between nodes
ontap_recipes
ONTAP Recipes: Did you know you can...?
You can check throughput and latency to identify network bottlenecks, or to prequalify network paths between nodes. You can check pairs of node in the same cluster or in two peered clusters.
1. Change to advanced privilege level:
set -privilege advanced
2. Measure throughput and latency between nodes:
network test-path -source-node name -destination-cluster cluster_name -destination-node name -session-type Default
Example:
cluster1::> network test-path -source-node node1 -destination-cluster cluster2 -destination-node node3 -session-type Default
Test Duration:          10.88 secs
Send Throughput:        48.23 MB/sec
Receive Throughput:     48.23 MB/sec
MB sent:                524.74
MB received:            524.74
Avg latency in ms:      301.47
Min latency in ms:      61.14
Max latency in ms:      856.86
If performance does not meet expectations for the path configuration, you should check node performance statistics, use available tools to isolate the problem in the network, check switch settings, and so forth.
For more information, see the ONTAP 9 documentation center
1 REPLY 1
Jeff_Yao
thanks for sharing
Announcements
NetApp on Discord Image
We're on Discord, are you?
Live Chat, Watch Parties, and More!
Explore Banner
Meet Explore, NetApp’s digital sales platform
Engage digitally throughout the sales process, from product discovery to configuration, and handle all your post-purchase needs.
NetApp Insights to Action
I2A Banner
