ONTAP Recipes
ONTAP Recipes: Easily move a volume to a different aggregate using System Manager
ontap_recipes
ONTAP Recipes: Did you know you can…?
You can easily move a volume in System Manager by selecting a volume, starting the move, and then optionally monitoring the resulting job. When using System Manager, the volume move operation finishes automatically.
1. In OnCommand System Manager, click the SVMs tab
2. Select the SVM, and then click Manage.
3. Click the Volumes tab, select the volume that you want to move, and click Move.
4. Select the destination aggregate and click Move. System Manager displays only aggregates that have enough capacity available.
5. When a new Move Volume dialog box is displayed, leave it open if you want to monitor the volume move job.
For more information, see the ONTAP 9 documentation center
1 REPLY 1
Re: ONTAP Recipes: Easily move a volume to a different aggregate using System Manager
hariprak
Thanks for sharing this information.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Earn Rewards for Your Review!
GPI Review Banner
All Community Forums
