ONTAP Recipes
Highlighted
ONTAP Recipes: Run ONTAP consolidated system diagnostic command
Did you know that...
There is a simple, consolidated ONTAP command to display a system health summary and alerts, if any?
For example:
cluster_1::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     ok
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster
                  ok
13 entries were displayed.
cluster_1::> system health alert show
This table is currently empty.
cluster_1::> system health config show
Node          Monitor                Subsystem       Health
node1         node-connect           SAS-connect, CIFS-NDO, MetroCluster_Node
                                                     ok
node1         system-connect         SAS-connect_Cluster, MetroCluster, FHM-Switch, FHM-Bridge
                                                     ok
node1         system                 -               ok
node1         controller             Environment, Memory, Service-Processor, Motherboard, IO
                                                     ok
node1         chassis                Environment     ok
node1         cluster-switch         Switch-Health   ok
node2         node-connect           SAS-connect, CIFS-NDO, MetroCluster_Node
                                                     ok
node2         controller             Environment, Memory, Service-Processor, Motherboard, IO
                                                     ok
8 entries were displayed.
For more information, visit the ONTAP 9 Documentation Center
Forums
