ONTAP Rest API Discussions
General ontap snapshot deletion and clone split question
kbhonagiri
Hi Everyone,
I'm facing below issue when trying to delete a snapshot from which a volume is cloned. Is this because the cloned volume has not been split from source yet ?
Exception in deleting snapshot:Job failed: Snapshot copy "<snaphostid>" of volume "<volumename>" in Vserver "<hostname>" has not expired or is locked. Use the "snapshot show -fields owners, expiry-time, snaplock-expiry-time" command to view the expiry and lock status of the Snapshot copy.
Kalyan
1 REPLY 1
jaikumar
Correct that is the reason why you are not able to delete the snapshot. When we do a snapshot backed volume clone or even LUN clone , the cloned volume/lun and the snapshot same data blocks and only when we split the volume, the volume have independent data blocks (& frees up the snapshot).
