ONTAP Rest API Discussions
Volume Efficiency auto-state setting with PowerShell?
JimRobertson
There is a field in the volume efficiencies called "auto-state" that does not seem to be accessible using standard PowerShell commands (Get-NcSis or Get-NcVolume). From the CLI, it is only visable in diag mode. Does anyone know any way to pull this information using PowerShell, other than using Invoke-NcSSH?
This is the command to view it in the CLI (while in diag):
vol efficiency show -volume vol1 -fields auto-state
I'm asking because we have workflows in WFA that are failing when we try to set the efficiencies on volumes that have been "deprioritized".
1 ACCEPTED SOLUTION
mbeattie
Hi Jim,
Here's an example of using the ONTAP REST CLI. You can either use ZAPI or REST API to invoke a CLI command. The following link has examples of both (you would just have to change the command in the example)
https://community.netapp.com/t5/Microsoft-Virtualization-Discussions/PowerShell-equivalent-of-discovery-mode/m-p/451567#M6862
Hope that helps
/Matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
4 REPLIES 4
darr613
Hello Jim,
There is a Netapp efficiency check script that is supported by this community
https://www.powershellgallery.com/packages/NetAppEfficiencyCheck/1.4
I am not sure if the "auto-state" attribute is listed among the outputs in the latest version 1.4.
I hope this leads you in the right direction
https://kb.netapp.com/onprem/ontap/dm/Efficiency/How_to_check_AFF_storage_efficiency_with_the_NetApp_PowerShell_Toolkit
darr613
auto-state will show if a volume is deprioritized, only available in diagnostic mode so have to get it through SSH
Please check the below lib for "auto-state"
https://www.powershellgallery.com/packages/NetAppEfficiencyCheck/1.2/Content/NetAppEfficiencyCheck.ps1
mbeattie
Hi Jim,
Hope that helps
/Matt
JimRobertson
Thank you, @mbeattie , this is exactly what I was looking for, it works great!
