Cache Tables no longer part of reference manual (as of WFA2) ?
cschnidr
Hi all,
I cannot find the cache tables anymore in the docs. Are they moved somewhere else?
Thanks
Christoph
1 ACCEPTED SOLUTION
kandati
Hi Christoph,
Like in pre-2.0, you don't find cache tables page separately to create or manage them.
In 2.0, dictionaries and cache tables are integrated in one table, that means, when creating a dictionary you can select which are column supposed to be cached, based on that cache table will be created.
You can find the cache table create query in  datasource types section.
Hope it helps..!
Warm Regards
Sivaprasad K
3 REPLIES 3
kandati
Hi Christoph,
Hope it helps..!
Warm Regards
Sivaprasad K
cschnidr
perfect - thanks!
yaronh
Hi Christoph,
Siva is correct. Both him and me wrote about it more when responding to Mike A. here:
https://communities.netapp.com/thread/25630
Hope that might clarify it more..
Yaron
