How DFM define which events will be triggered and which ones are not?
chao
Hi Gurus
I found something I don't understand about how DFM define which events will be triggered and which ones are not.  for example, I am testing the events about snapmirror. totally there are following eventtype:
snapmirror-abort:completed                Normal   sm.abort
snapmirror-abort:failed                   Error    sm.abort
snapmirror-break:completed                Normal   sm.break
snapmirror-break:failed                   Error    sm.break
snapmirror-delete:aborted                 Warning  sm.delete
snapmirror-delete:completed               Normal   sm.delete
snapmirror-delete:failed                  Error    sm.delete
snapmirror-initialize:aborted             Warning  sm.initialize
snapmirror-initialize:completed           Normal   sm.initialize
snapmirror-initialize:failed              Error    sm.initialize
snapmirror-quiesce:aborted                Warning  sm.quiesce
snapmirror-quiesce:completed              Normal   sm.quiesce
snapmirror-quiesce:failed                 Error    sm.quiesce
snapmirror-resume:completed               Normal   sm.resume
snapmirror-resume:failed                  Error    sm.resume
snapmirror-resync:aborted                 Warning  sm.resync
snapmirror-resync:completed               Normal   sm.resync
snapmirror-resync:failed                  Error    sm.resync
snapmirror-update:aborted                 Warning  sm.update
snapmirror-update:completed               Normal   sm.update
snapmirror-update:failed                  Error    sm.update
snapmirror:date-ok                        Normal   sm.lag
snapmirror:deleted                        Information  sm.lag
snapmirror:discovered                     Information  sm.relationship
snapmirror:modified                       Information  sm.relationship
snapmirror:nearly-out-of-date             Warning  sm.lag
snapmirror:not-scheduled                  Normal   sm.state
snapmirror:not-working                    Error    sm.state
snapmirror:off                            Normal   sm.state
snapmirror:out-of-date                    Error    sm.lag
snapmirror:possible-problem               Warning  sm.state
snapmirror:undeleted                      Information  sm.relationship
snapmirror:unknown-state                  Warning  sm.state
snapmirror:working                        Normal   sm.state
but when I tried to initialize a snapmirror relation, when initialize,abort it, initialize it again,  abort it, resync it .  it should generate many events like snapmirror-initialize:completed,  snapmirror-resync:completed.  but in my case, only snapmirror:discovered is triggered.   is it expected?  your input are appreciated.
Thanks and Best Regards!
TC
11 REPLIES 11
adaikkap
Hi TC,
     When you say I initialized, abort etc where did you do it from ? Is it from Protection Manger or Disaster Recovery Manager ? If its done from the PM/DRM you will see all these events else you will only see below to events.
Same is the case when you do it from filer view/SystemManager/Filer cli.
You can also check the following thread on the same topic.
https://communities.netapp.com/message/93280#93280
Regards
adai
chao
Hi Adai
All operations were done via CLI.  but both source and destination are under same DFM and NMC could see the snapmirror relation but as external relation.
if customer want to see snapmirror alert either CLI operation or PM, what should we configure?   import snapmirror relation to a dataset? or anything else?
what's the document to describe which event will show-up or which ones will not?  I see it's no related with severity.
BR
TC
adaikkap
The reason we dont generate the events you are expecting is, these relationships are external. We generate all the events only when dfm manages these releationships and not when it only monitors.
Yes you will have to import them into a dataset in order for dfm to manage it.
Regards
adai
chao
I tried to initialize a snapmirror,  before initialization is completed,  I abort it.   I assume the followin event will be triggered:
this is warning event.
but it did not happen.
adaikkap
Hi TC
     Thats exactly what I said, if you do these in filer cli and not with dfdrm or dfpm cli you will not receive any snapmirror events other than lag error and warning events.
Regards
adai
chao
Hi Adai
Thanks for your kindly reply.
I just wonder
this event is warning event.  even I abort the initialize by CLI,  DFM should receive event?  right?
Do you think if there is anything I missed?  I am still confused.
1) external snapmirror relation,  abort intialize by CLI,   will DFM receive event (warning event)?
2) import snapmirror relation to dataset,  but still abort it by CLI,  will DFM receive event?
3) import snapmirror relation to dataset,  operation by PM,  will DFM receive event? (any level?)
is there a deep KB or document about that?
BR
TC
adaikkap
HI TC,
     I dont know what is not clear. Can you pls read this bug 206891 ? DFM is monitors for SnapMirror related things once every 30mins, so it can only report on the lag times of a relationship.
In order for dfm to generate these events either dfm should get traps or the action itself should be initiated from dfm so that it can generate the events. Hope this helps and clarifies.
No, because dfm doesn't get a trap and it only monitors once every 30mins.
No. Same as above.
Yes. Since the operation is initiated from dfm/PM it will receive the response and trigger the event.
Regards
adai
chao
Adai: Thank you very much!
chao
Hi Adai
Sorry for further question. for the below events:
if snapmirror relation (update interval) are defined in filer,  How DFM receive the lag error?  how DFM determin a snapmirror relation lag time?  (for example, one snapmirror update interval is 6 hours, and another one is 12 hours).
I know PM could define a dataset warning lag time. but a snapmirror relation is not imported to a dataset.  DFM could also receive the lag warning. right?
adaikkap
Hi Chao,
The default threshold for snapmirror:nearly-out-of-date is 1.5days or 36hours and snapmirror:out-of-date  is 2days or 48 hours.
If you want to get the alerts based on your scheduling then you will have to import them to dataset and define new lag times based on scheduling for each dataset.
Regards
adai
chao
I see. thanks a lot.  Sounds we could not avoid PM.
