How many folks are running OnCommand in a large setting
MARK_TANGO
My questions are for those folks that are running OnCommand in a large enterprise setting.
How did you like the setup?
Doesnt look like this will do auto discovery and you must know every IP address of your filers
Do you find this software helpful or just another fancy dashboard?
I am looking to turn around a storage team and get the North American filers under some form of centralized monitoring.
Looking at several products for this
Logicmonitor really looked cool with lots of monitoring capabilities
1 REPLY 1
adaikkap
OnCommand does auto-discovery which by default is turned on. Do check whats your values for this options.
Also when adding a controller, the corresponding subnet is also added, unless you use the -N option in the add command.
[root@10 ~]# dfm options list | grep -i discover
discoverAgents                        Enabled
discoverClusters                      Enabled
discoverEnabled                       Enabled
discoverHostInitEnabled               Enabled
discoverHosts                         Enabled
discoverInterval                      15 minutes
discoverNetworks                      Disabled
discoverSAN                           Enabled
discoverTimeout                       5 seconds
discoverVfilers                       Enabled
Regards
adai
