How to add Storage system in Bulk - WFA
aselvan
Hi ,
Do we have an option to add storage systems(200+) in Bulk in WFA.
Regards
Aravindhan S
1 ACCEPTED SOLUTION
sinhaa
  1. Add a new credentials
  2. Match=Pattern
  3. Type according to the server you want to add. For cDOT or 7Mode selet ONTAP
  4. Name/IP: <regular expression which matches to your the group of servers for whom you ant to save a common credentials.
  5. Save.
Example 1:
For Type ONTAP:
This will match credentials with ip having 10.226.252. as the common part. So clusters like 10.226.252.1 to 10.226.252.255 all will have the same credentials saved.
for ONATP, Test-Connectivity is available so you can provide the IP for which you want to test. It will tell which pattern was used to obtain credentials
Example 2:
For Type Other:
This pattern can match server with host-names like ab-testsrv2 or dk-testsrv8 etc.
Test-Connectivity is not available for type Other. So you can do is self verify that if you are getting the right credentials or not for a given IP using the below command code. Just run "Test comand" and provide the IP. It will return the username/password from which you can know if the right credentials can be obtained for this host or not.
##BEGIN CODE
param (
[parameter(Mandatory=$true, HelpMessage="Host Name or IP")]
[string]$Host
$creds = Get-WfaCredentials -Host $Host
if($creds)
Get-WfaLogger -Info -Message "UserName: $creds.UserName"
Get-WfaLogger -Info -Message $("Pasword: "+ $(ConvertFromSecureToPlain -SecurePassword $creds.Password))
else
throw("No credentials were found")
##END CODE
sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
13 REPLIES 13
