Hi Niels,
Yes you can do it. For each qtree on the primary snapvault creates a base snapshot, on first update all off them are coalesced into one base snapshot. Below is a example.
fas-sim-1> qtree status OneThousand
Volume Tree Style Oplocks Status
OneThousand unix enabled normal
OneThousand one unix enabled normal
OneThousand three unix enabled normal
OneThousand two unix enabled normal
fas-sim-1>
After SnapVault Start/Create Relationship job
fas-sim-1> snap list OneThousand
Volume OneThousand
working...
%/used %/total date name
21% (21%) 0% ( 0%) Apr 15 11:31 fas-sim-2(0099931872)_OneThousand_backup_one-src.0 (snapvault)
36% (23%) 0% ( 0%) Apr 15 11:31 fas-sim-2(0099931872)_OneThousand_backup_OneThousand_fas-sim-1_OneThousand-src.0 (snapvault)
46% (23%) 0% ( 0%) Apr 15 11:31 fas-sim-2(0099931872)_OneThousand_backup_two-src.0 (snapvault)
53% (21%) 0% ( 0%) Apr 15 11:31 fas-sim-2(0099931872)_OneThousand_backup_three-src.0 (snapvault)
fas-sim-1>
After SnapVault Update/Protect Now
Volume OneThousand
working...
27% (27%) 0% ( 0%) Apr 15 11:39 dfpm_base(OneThousand.436)conn1.0 (snapvault,acs)<<<<<<<<<<<<<<<<<<<<<<<<<SV Base Snapshot with dataset name & id
39% (21%) 0% ( 0%) Apr 15 11:38 2012-04-16 12:40:54 daily_fas-sim-1_OneThousand.-.one.three.two<<<<<<<<<<<<<<<<Backup snapshot created by Protect Now.
fas-sim-1>
As the max snapshot per volume is 255, after creating 255 qtree snapvault relationships the dataset will become non-conformant with error saying no snapshot available.
Now run a Protect Now from Protection Manager, all this 255 will be coalesce into one. But still the dataset will show the conformance status as non-conformant.Click on the same and say conform now.
PM will now create relation for next 253 qtree ( as one is already used by dfpm_base and other by the backup snapshot of PM).Once this is done, again it will fail due to non availability of snapshot.
Run Protect now. Keep doing the same until all 1000 qtrees are snapvaulted.
The down side is that, max concurrent SV stream per controller is limited and various with the following.
ONTAP Version
FAS Model
NearStore License being enabled or not.
The regular scheduled updates of this volume, will consume all SV threads until its finished and can increase the back window and delay snapshot creation on the secondary as alll 1000 needs to be snapvaulted before a SV snapshot can be created on the destination. This is the only downside I can think of.
This limit for 50 was done mainly for QSM as each qtree in a QSM needs a base snapshot and only remaining 205 would be available for long term retention as max snapshots per volume is only 255.
Also do remember the options you are changing is a global option and applies to all dataset creating SV relationship.
Regards
adai
Regards
adai
