Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic for Current User
- Bookmark
- Subscribe
- Printer Friendly Page
Highlighted
- Bookmark
- Permalink
- Email to a Friend
- Report Inappropriate Content
Greetings,
I am building a filer for a project and ran into a issue. given the following filter:
select aggregate.name as "aggregate.name"
from cm_storage.aggregate, cm_storage.cluster, cm_storage.node
where
node.id = aggregate.node_id
and cluster.id = node.cluster_id
and cluster.name = '${Clustername}'
order by aggregate.available_size_mb
I am getting this error.
Filter 'test' returned attributes does not contain all natural keys. Filter's returned attributes '[aggregate.name]' , dictionary entry natural keys '[node.name, name, node.cluster.primary_address]'
I have attempted to modify this to include what I believe to be the rest of the natural keys
select aggregate.name as 'aggregate.name',node.name as 'node.name', aggregate.name as 'aggregate.name', node.primary_address as 'node.cluster.primary_address'
where
Filter 'test' returned attributes does not contain all natural keys. Filter's returned attributes '[aggregate.name, node.cluster.primary_address, node.name]' , dictionary entry natural keys '[node.name, name, node.cluster.primary_address]'
I would have expected the second query to correct the issue however I think I am missing something.
Thanks for your help
Solved! See The Solution
2 REPLIES 2
- Bookmark
- Permalink
- Email to a Friend
The required natural keys are : '[node.name, name, node.cluster.primary_address]'
Try this:
select aggregate.name as 'name',node.name as 'node.name', aggregate.name as 'aggregate.name', node.primary_address as 'node.cluster.primary_address'
where
I just used aggregate.name as 'name' instead of aggregate.name as 'aggregate.name'
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
- Bookmark
- Permalink
- Email to a Friend
So in the primary table all name references should be direct? This case cm_storage.aggreagate
That worked great!
Thanks for your help,
John
