OCUM 6.2.P1 connection with OCPM 1.1 failures due to wrong dns entries
mark_display
I added the Unified Manger and everything worked fine.
Unified Manager Connection Menu
    1 ) Display Unified Manager Server Connection
    2 ) Add / Modify Unified Manager Server Connection
Then I should change the dns name of the OCPM server and delete/add again the Unified Manager.
After that I started to notice this message every few minutes:
And in details:
But the OCPM has no that dns name entry and its configuration is clean and right.
The Unified Manager is remembering something wrong, even if those informations should be already cleaned up.
There is a way to change the wrong settings without reinstall the OCUM again ?
Thank you
Best Regards
Mark
1 REPLY 1
marz
Open a case with support for cleanup.  Changing the FQDN/IP of OPM is bug 898882.
