Problem with dfm Backup
f_duranti
Hi, I'm opening a new post on this problem I had. Our backup is going bad from some times, I've a support call opened but it seems that it takes ages to get an answer so I'm trying on the forum to see If I'm a bit more lucky here
I've manually replicated the procedure that backup do to get the real error message (it's not in the log so it seems difficult to understand why backup are getting wrong).
Being able to do the validate table on the manually copied and started up database i get this erro:
VALIDATE TABLE "DFM"."hsNotifications"
Primary key for "hsNotifications" has missing index entries
Foreign key "hostServiceId" has missing index entries
SQL error (-300) -- Run time SQL error -- Validation of table "hsNotifications" has failed
It seems that I should only need to recreate or correct those 2 tables.
I'm almost sure the problem was with some older data inside those table related to when I had onCommand Host 1.0 on a server that is no more inside dfm (it uninstalled not in a really good way).
The real problem is that there's no dfm hs delete -f so I'm not able to delete those stale entry.
THose are the dfm hs list, dfm hs list -a, dfm hs list -av. As you can see there are 2 hosts that are still inside the tables but that I've no way to remove and I'm sure the problem is there.
Anyone can help me with this?
[root@itromlx13 ~]# dfm hs list
Id         Host Name                                Host Address         Version    Status                 Timezone
40155      ITNAPIS10.Q8INT.COM                      10.14.5.10           1.1.0.1512 up                     GMT-1:00(1 hour East of UTC).
41243      ITROMIS10.Q8INT.COM                      10.160.5.110         1.1.0.1512 up                     GMT-1:00(1 hour East of UTC).
[root@itromlx13 ~]# dfm hs list -a
Id         Host Name                                Host Address         Version    Status                 Timezone                                 Deleted    Deleted By
40155      ITNAPIS10.Q8INT.COM                      10.14.5.10           1.1.0.1512 up                     GMT-1:00(1 hour East of UTC).            No
41243      ITROMIS10.Q8INT.COM                      10.160.5.110         1.1.0.1512 up                     GMT-1:00(1 hour East of UTC).            No
35248      ITROMIS100.Q8INT.com                     10.160.5.200         1.1.0.1512 down                   GMT-1:00(1 hour East of UTC).            Yes        dfmserver
35067      ITROMIS60.Q8INT.com                      10.160.5.60          1.0.0.1493 down                   GMT-2:00(2 hours East of UTC).           Yes        dfmserver
[root@itromlx13 ~]# dfm hs list -va
Host Name:       ITNAPIS10.Q8INT.COM
Host Address:    10.14.5.10
Admin Port:      8699
Version:         1.1.0.1512
Management Port: 8799
Status:          up
Timezone:        GMT-1:00
Plugin Type:     OnCommand Host Service VMware Plug-in
Plugin Version:  1.1.0.0
Host Name:       ITROMIS10.Q8INT.COM
Host Address:    10.160.5.110
Admin Port:      8699
Version:         1.1.0.1512
Status:          up
Timezone:        GMT-1:00
Host Name:       ITROMIS100.Q8INT.com
Host Address:    10.160.5.200
Admin Port:      8699
Version:         1.1.0.1512
Status:          down
Timezone:        GMT-1:00
Plugin Version:  1.0.0.0
Host Name:       ITROMIS60.Q8INT.com
Host Address:    10.160.5.60
Admin Port:      8699
Version:         1.0.0.1493
Status:          down
Timezone:        GMT-2:00
Those are the logs of dfm backup create -v
[root@itromlx13 ~]# dfm backup create -v
Disabling Performance Advisor.
DestinationPath = /opt/dfm_backup/
TempPath        = /opt/dfm_backup/dfm_temp_dest_dir/
InstallPath     = /opt/NTAPdfm/
DataPath        = /opt/NTAPdfm/data/
LogPath         = /opt/NTAPdfm/data/
KeysPath        = /opt/NTAPdfm/conf/keys/
PerfPath        = /opt/NTAPdfm/perfdata/
ScriptPath      = /opt/NTAPdfm/script-plugins/
RptPath        = /opt/NTAPdfm/reports/repository/custom/
DBFileName      = monitordb.db
LogFileName     = monitordb.log
KeysFileName    = dfmenc.keys
ArchivePath     = /opt/dfm_backup/dfm_backup_2012-01-23_17-25-05.ndb
ArchiveTempName = tmp.backup.file.ndb
strDBFilePath= /opt/dfm_backup/dfm_temp_dest_dir/monitordb.db
strDBLogFilePath= /opt/dfm_backup/dfm_temp_dest_dir/monitordb.log
strKeysFilePath= /opt/dfm_backup/dfm_temp_dest_dir/dfmenc.keys
Copying keystore for backup ...
SQL Anywhere Backup Utility Version 10.0.1.4213
(107134 of 107120 pages, 100% complete)
Database backup completed
Enabling Performance Advisor.
Error: Database validation returned errors.
Please see dfmbackup.log file for details.
This is the dfmbackup.log:
Jan 23 17:25:32 [dfm: INFO]: [23221:0x2b8da1a67080]: dbeng9 process spawned with pid = 23377.
Jan 23 17:25:32 [dfm: INFO]: [23221:0x2b8da1a67080]: dbvalid process spawned successfully, pid = 23378.
I. 01/23 17:25:32. SQL Anywhere Personal Server Version 10.0.1.4213
I. 01/23 17:25:32.
I. 01/23 17:25:32. Copyright (c) 2011, iAnywhere Solutions, Inc.
I. 01/23 17:25:32. Portions copyright (c) 2011, Sybase, Inc.
I. 01/23 17:25:32. All rights reserved. All unpublished rights reserved.
I. 01/23 17:25:32.
I. 01/23 17:25:32. This software contains confidential and trade secret information of
I. 01/23 17:25:32. iAnywhere Solutions, Inc.
I. 01/23 17:25:32. Use, duplication or disclosure of the software and documentation
I. 01/23 17:25:32. by the U.S. Government is subject to restrictions set forth in a license
I. 01/23 17:25:32. agreement between the Government and iAnywhere Solutions, Inc. or
I. 01/23 17:25:32. other written agreement specifying the Government's rights to use the
I. 01/23 17:25:32. software and any applicable FAR provisions, for example, FAR 52.227-19.
I. 01/23 17:25:32.
I. 01/23 17:25:32. iAnywhere Solutions, Inc., One Sybase Drive, Dublin, CA 94568, USA
I. 01/23 17:25:32.
I. 01/23 17:25:33. 4 logical processor(s) on 2 physical processor(s) detected.
I. 01/23 17:25:33. This server is licensed to:
I. 01/23 17:25:33.     DFM User
I. 01/23 17:25:33.     NetApp
I. 01/23 17:25:33. Running Linux 2.6.18-274.7.1.el5 #1 SMP Mon Oct 17 11:57:14 EDT 2011 on X86_64
I. 01/23 17:25:33. Server built for X86_64 processor architecture
I. 01/23 17:25:33. Authenticated Server licensed for use with Authenticated Applications only
I. 01/23 17:25:33. 904832K of memory used for caching
I. 01/23 17:25:33. Minimum cache size: 8192K, maximum cache size: 4087256K
I. 01/23 17:25:33. Using a maximum page size of 8192 bytes
I. 01/23 17:25:33. Starting database "dfmBackupDbvalidDatabase" (/opt/dfm_backup/dfm_temp_dest_dir//monitordb.db) at Mon Jan 23 2012 17:25
I. 01/23 17:25:33. Database recovery in progress
I. 01/23 17:25:33.     Last checkpoint at Mon Jan 23 2012 17:25
I. 01/23 17:25:33.     Checkpoint log...
Jan 23 17:25:33 [dfm: INFO]: [23221:0x2b8da1a67080]: dbvalid process spawned successfully, pid = 23394.
Jan 23 17:25:34 [dfm: INFO]: [23221:0x2b8da1a67080]: dbvalid process spawned successfully, pid = 23397.
I. 01/23 17:25:35.     Transaction log: /opt/dfm_backup/dfm_temp_dest_dir//monitordb.log...
Jan 23 17:25:35 [dfm: INFO]: [23221:0x2b8da1a67080]: dbvalid process spawned successfully, pid = 23400.
Jan 23 17:25:36 [dfm: INFO]: [23221:0x2b8da1a67080]: dbvalid process spawned successfully, pid = 23407.
I. 01/23 17:25:37.     Rollback log...
I. 01/23 17:25:37.     Checkpointing...
I. 01/23 17:25:37. Starting checkpoint of "dfmBackupDbvalidDatabase" (monitordb.db) at Mon Jan 23 2012 17:25
I. 01/23 17:25:37. Finished checkpoint of "dfmBackupDbvalidDatabase" (monitordb.db) at Mon Jan 23 2012 17:25
I. 01/23 17:25:37. Recovery complete
I. 01/23 17:25:37. Database "dfmBackupDbvalidDatabase" (monitordb.db) started at Mon Jan 23 2012 17:25
I. 01/23 17:25:37. This database is licensed for use with:
I. 01/23 17:25:37.     Application: DataFabric Manager
I. 01/23 17:25:37.     Company: NetApp
I. 01/23 17:25:37. Database server started at Mon Jan 23 2012 17:25
I. 01/23 17:25:37. Trying to start SharedMemory link ...
I. 01/23 17:25:37.     SharedMemory link started successfully
I. 01/23 17:25:37. Trying to start TDS (TCPIP) link ...
I. 01/23 17:25:37. Unable to start on default port; starting on port 49152 instead
I. 01/23 17:25:37.     TDS (TCPIP) link started successfully
I. 01/23 17:25:37. Now accepting requests
Jan 23 17:25:38 [dfm: INFO]: [23221:0x2b8da1a67080]: dbvalid process spawned successfully, pid = 23433.
I. 01/23 17:25:38. Cache size adjusted to 849288K
I. 01/23 17:25:42. Cache size adjusted to 836256K
I. 01/23 17:25:42. Cache size adjusted to 833672K
I. 01/23 17:25:48. Cache size adjusted to 833064K
Jan 23 17:30:46 [dfm:ERROR]: [23221:0x2b8da1a67080]: Database validation returned errors.
SQL Anywhere Stop Server Utility Version 10.0.1.4213
I. 01/23 17:30:46. Database server shutdown requested by DBSTOP
I. 01/23 17:30:46. Starting checkpoint of "dfmBackupDbvalidDatabase" (monitordb.db) at Mon Jan 23 2012 17:30
I. 01/23 17:30:46. Finished checkpoint of "dfmBackupDbvalidDatabase" (monitordb.db) at Mon Jan 23 2012 17:30
Jan 23 17:30:46 [dfm: INFO]: [23221:0x2b8da1a67080]: dbstop process returned successfully.
I. 01/23 17:30:46. Database server stopped at Mon Jan 23 2012 17:30
Jan 23 17:30:46 [dfm:ERROR]: [23221:0x2b8da1a67080]: Database backup create failed
1 ACCEPTED SOLUTION
marz
Greetings Francesco
Steps to resolve this problem have been delivered to the EMEA Team.  They will work with you on scheduling to apply the correction on your server.
Thanks
Alex
8 REPLIES 8
marz
What is the case number?
f_duranti
Case number is 2002833610
marz
Thank you.  We will continue updates through the case.
marz
Greetings Francesco
Thanks
Alex
f_duranti
Alex, thanks for your help.  Support team solved the problem yesterday.
Francesco
janihujanen
Hi,
I Have same database backup problem with DFM. What was the resolution?
br, Jani
adaikkap
Raise a support case and quote the following case# to get a quick resolution 2002833610
Regards
adai
su_yue
can you shares this case's root cause?
very thanks
