Volume Clone/Lun Map Automation?
gdekhayser
Hello all-
I want to build a workflow that lets the user choose a filer->volume->snapshot, clone from that snap, and map the lun in that clone to an igroup on that filer with a pre-set LUN ID (say 15 or 16).
I also want to build a reverse workflow that will take that flexcloned lun, UNMAP it, and then destroy the cloned volume.
Having trouble getting my head around how to do this.  BTW, this is on 7-mode.
Thanks for any advice/help.
Glenn
1 ACCEPTED SOLUTION
shailaja
>>What you show is exactly what I want to accomplish, although the user inputs I want to make queries because I want the user to have drop-downs and not be able to select bad entries.
Right. User inputs based on queries will always be good for the actual execution and to make it error-free. I was just experimenting and hence did not bother on the queries.
Shailaja
23 REPLIES 23
