Volume metrics through OnCommand API 2.1 issue
shynee
Hello,
I am trying to gather perforamance metrics on volumes. I can successfully pull metrics for Clusters, Node, Aggregates and SVM's. But on volumes, I only see three metrics on few volumes (total_throughput, write_throughput and read_throughput) and just reource_key and rest of the metrics are blank. Tried all the following URL's. Still no luck. I am wondering if I am missing something
GET /1.0/ontap/volumes/metrics
GET /2.0/ontap/volumes/metrics
GET /3.0/ontap/volumes/metrics
GET /4.0/ontap/volumes/metrics
GET /5.0/ontap/volumes/metrics
API Services : 2.1
OS : Centos 7.4
Cmode clusters - 9.1P2 and 9.2
Appreciate you response
Regards,
Shynee
1 REPLY 1
shynee
Clusters also report only four metrics. So I have an issue with cluster and volumes. Nodes, aggregates and Storage virtual machines are fine
If I try to access the metrics from a browser.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<apiServerResponse xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="">
<status>
<code>SUCCESS</code>
</status>
<result>
<total_records>224</total_records>
<records xsi:type="metricPerResourceKey">
<resource_key>
d4d585ba-6cfd-11e5-a8af-123478563412:type=volume,uuid=00dcffb0-55cf-4ca8-b74d-1c393971de74
</resource_key>
<metrics/>
</records>
<resource_key>
d4d585ba-6cfd-11e5-a8af-123478563412:type=volume,uuid=b70ac8f7-b2aa-4db6-8dad-802c58e71c5e
</resource_key>
<metrics/>
</records>
<resource_key>
d4d585ba-6cfd-11e5-a8af-123478563412:type=volume,uuid=34204fda-e291-4424-93e1-c96bd0b15f34
</resource_key>
<metrics/>
</records>
<resource_key>
d4d585ba-6cfd-11e5-a8af-123478563412:type=volume,uuid=ea54a5fe-28e3-4dca-8aa0-202252ebf357
</resource_key>
<metrics/>
</records>
<resource_key>
d4d585ba-6cfd-11e5-a8af-123478563412:type=volume,uuid=c0a2a065-e143-4c81-b3a9-873a0f968bea
</resource_key>
<metrics>
<metric>
<name>total_throughput</name>
<unit>per_sec</unit>
<samples>
<sample>
<timestamp>1526222391239</timestamp>
<value>0.0</value>
</sample>
</samples>
</metric>
<metric>
<name>write_throughput</name>
<samples>
<sample>
<value>0.0</value>
</sample>
</samples>
</metric>
<metric>
<name>read_throughput</name>
<samples>
<sample>
<value>0.0</value>
</sample>
</samples>
</metric>
</metrics>
</records>
