Simulator Discussions
Need HELP! THE 2nd node can not join / recognize the cluster
netappmagic
Hi,
I finally set up the cluster with 1 node and with adding 2 etra network adapters as instructed by the tutorial video.
When I set up the 2nd node (added 2 extra network adapters as well), and in the end, it prompts me to enter the cluster name, which I did, then it shows me trying to join, and then network setup.. then it loops back to me and ask me if to create or join the cluster again. pls see the attachment. So, i am in the loop.
Are there any solution for that?   This is 2nd time. The first time, I thought I did something wrong, so, started over from scratch.
What is the cluster IP and I can find from the existing 1 node cluster?
If I stopped the prompted questinair, at one point, it asked me to enter cluster IP to recognize. What CLUSTER IP i should use? The cluster with the other node is running fine.
Also, based on the video, when I need to change default subnet in the end of adding 2 extra adapters, however, since vmware play doesn't have VM Editor, I skipped this step.
Appreicate your help!
15 REPLIES 15
