Tech ONTAP Blogs
Configuring Resource Requests and Limits for Trident CSI
DhruvKharkwal
NetApp
Introduction
In the dynamic world of Kubernetes, where pods scale and storage demands fluctuate, efficient resource management isn't just a best practice—it's a necessity. Enter NetApp Trident™ , the open-source storage orchestrator that simplifies persistent storage for containerized applications. As a Container Storage Interface (CSI) driver, Trident handles volume provisioning, snapshots, and more across diverse backends like ONTAP,  Amazon FSx for NetApp ONTAP (FSxN), Google Cloud NetApp Volumes (GCNV), Azure NetApp Files (ANF). But even the most robust tools like Trident can falter if they're starved for CPU or memory. That's where Kubernetes resource requests and limits come into play, ensuring your storage operations run smoothly without overwhelming your cluster.
In this post, we'll break down the fundamentals of resource requests and limits and explore ways to configure resource requests & limits for Trident controller and node pod containers. Whether you're deploying Trident via Helm or customizing it with the TridentOrchestrator CRD,  this feature will boost performance, prevent evictions, and optimize costs. Let's dive in.
Kubernetes Resource Requests and Limits: The Basics
At its core, Kubernetes uses resource requests and limits to allocate and cap CPU and memory for containers/pods. These settings live in your pod specs under the resources field and play a dual role: guiding scheduling decisions and enforcing runtime boundaries.
  • Requests: Requests are guaranteed resources that Kubernetes ensures for the container/or pod on a node. If a node doesn’t have enough free CPU or memory to meet a pod’s request, the pod will remain in the Pending state. The scheduler only assigns the pod to a node that can guarantee the requested resources, ensuring predictable performance for critical workloads.
  • Limits: Limits are the maximum resources that can be utilized by a container/pod. For CPU, exceeding limits triggers kernel throttling (slowing down the process). For memory, it risks an Out-Of-Memory (OOM) kill, where the container gets terminated to protect the node.
Here's how they differ by resource type:
Resources Requests Behavior Limits Behavior
CPU It defines the minimum guaranteed CPU resources. Throttles usage—no termination, but performance dips.
Memory Reserves space; pods can exceed if free memory exists.  Enforces hard caps via OOM kills when pressure builds.
Configuring them is straightforward. In a Deployment or Pod spec, here is an example:
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
  replicas: 3
  selector:
    matchLabels:
      app: my-app
  template:
    metadata:
      labels:
        app: my-app
    spec:
      containers:
      - name: app-container
        image: nginx:1.21
        resources:
          requests:
            memory: "64Mi"
            cpu: "250m"
          limits:
            memory: "128Mi"
            cpu: "500m"
This ensures each pod requests 0.25 CPU and 64Mi memory but won't exceed 0.5 CPU or 128Mi memory. Without limits, your container could theoretically hog the entire node—risky in shared clusters.
Why Resource Management Matters for Trident
Trident deploys as a controller pod (one instance managing storage operations) and node pods (one per worker node for mounting volumes). These pods include sidecar containers like CSI provisioner, attacher, and resizer, which handle dynamic provisioning and attachment.
Poor resource tuning here can lead to:
  • Scheduling Failures: Under-requested pods might not fit on nodes, delaying storage ops.
  • Performance Bottlenecks: Overloaded Trident pods throttle during peak I/O, slowing app responsiveness.
  • Cluster Instability: Unbounded memory use could trigger evictions, disrupting storage for entire workloads.
By setting requests and limits, you guarantee Trident's core functions (e.g. volume provisioning, volume snapshots) while protecting against rogue consumption—crucial for stateful apps relying on persistent volumes.
Default Resource Configurations in Trident
Trident applies sensible default resource requests values for both controller and node pod containers, while intentionally omitting default CPU and memory limits.
Trident’s actual resource consumption varies significantly depending on the size and scale of worker nodes and number of persistent volumes. Setting restrictive default limits could easily degrade performance or cause pod evictions in typical production deployments. As a result, Trident ships without default limits out of the box, giving operators maximum flexibility.
When running in resource-constrained or multi-tenant environments where strict containment is required, administrators can (and should) add explicit CPU and memory limits to the Trident controller and node pods to match their specific policies and workload characteristics.
Controller Pod Defaults
Container CPU Request Memory Request CPU Limit Memory Limit
trident-main 10m 80Mi None None
csi-provisioner 2m 20Mi None None
csi-attacher 2m 20Mi None None
csi-resizer 3m 20Mi None None
csi-snapshotter 2m 20Mi None None
trident-autosupport 1m 30Mi None None
Node Pod Defaults (Linux)
trident-main 10m 60Mi None None
node-driver-registrar 1m 10Mi None None
Node Pod Defaults (Windows)
node-driver-registrar 6m 40Mi None None
liveness-probe 2m 40Mi None None
Prerequisite to use this feature.
Installing Trident with specific Resource Requests and Limits values
To configure Kubernetes resource requests and limits for individual containers in Trident controller and node pods, users can specify CPU and memory constraints in two ways:
  • Operator-based deployment: User can specify CPU and memory constraints directly in the TridentOrchestrator (TORC) Custom Resource Definition using the `spec.resources` field. This allows for declarative, GitOps-friendly configuration with granular control over each container's resource requirements.
  • Helm-based deployment: User can configure controller, node and operator pod containers resources either through the Helm chart's values.yaml file or using the --set flag in the helm command, during installation or upgrade.
Both methods support granular container-level configuration for all Trident containers including trident-main, CSI sidecars (provisioner, attacher, resizer, snapshotter, registrar), and trident-autosupport, across both Linux and Windows node platforms. This enables better resource planning, and prevention of resource contention.
Note: Always preserve exact container names and YAML indentation to avoid parse errors.
Examples:
  • Helm way of installation:
    Refer Deploy Trident operator using Helm for installation steps and specify resource request and limit values in values.yaml or use  --set to specify resource request and limit values.
    Below is the Sample values.yaml file that you can refer as a example.
    resources:
      controller:
        trident-main:
          requests:
            cpu: 50m
            memory: 128Mi
          limits:
            cpu: 100m
            memory: 256Mi
        # sidecars
        csi-provisioner:
          requests:
            cpu: 20m
            memory: 50Mi
          limits:
            cpu: 40m
            memory: 100Mi
        csi-attacher:
          requests:
            cpu: 20m
            memory: 25Mi
          limits:
            cpu: 80m
            memory: 70Mi
        csi-resizer:
          requests:
            cpu: 40m
            memory: 30Mi
          limits:
            cpu: 90m
            memory: 75Mi
        csi-snapshotter:
          requests:
            cpu: 30m
            memory: 22Mi
          limits:
            cpu: 85m
            memory: 68Mi
        trident-autosupport:
          requests:
            cpu: 20m
            memory: 35Mi
          limits:
            cpu: 60m
            memory: 130Mi
      node:
        linux:
          trident-main:
            requests:
              cpu: 75m
              memory: 100Mi
            limits:
              cpu: 150m
              memory: 200Mi
          # sidecars
          node-driver-registrar:
            requests:
              cpu: 20m
              memory: 15Mi
            limits:
              cpu: 55m
              memory: 35Mi
        windows:
          trident-main:
            requests:
              cpu: 8m
              memory: 45Mi
            limits:
              cpu: 180m
              memory: 140Mi
          # sidecars
            requests:
              cpu: 30m
              memory: 45Mi
            limits:
              cpu: 90m
              memory: 135Mi
          liveness-probe:
            requests:
              cpu: 20m
              memory: 45Mi
            limits:
              cpu: 55m
              memory: 70Mi
      operator:
        requests:
          cpu: 20m
          memory: 60Mi
        limits:
          cpu: 40m
          memory: 120Mi
  • Operator way of installation:
    Refer Customise Trident operator installation to install trident and specify resource values in TridentOrchestrator CRD as per below example:
    kind: TridentOrchestrator
    metadata:
    spec:
      debug: true
      namespace: trident
      windows: true
      resources:
        controller:
          trident-main:
            requests:
              cpu: 10m
              memory: 80Mi
            limits:
              cpu: 200m
              memory: 256Mi
          # sidecars
          csi-provisioner:
            requests:
              cpu: 20m
              memory: 20Mi
            limits:
              cpu: 100m
              memory: 64Mi
          csi-attacher:
            requests:
              cpu: 50m
              memory: 20Mi
            limits:
              cpu: 100m
              memory: 64Mi
          csi-resizer:
            requests:
              cpu: 30m
              memory: 20Mi
            limits:
              cpu: 100m
              memory: 64Mi
          csi-snapshotter:
            requests:
              cpu: 25m
              memory: 20Mi
            limits:
              cpu: 100m
              memory: 64Mi
            requests:
              cpu: 10m
              memory: 30Mi
            limits:
              cpu: 50m
              memory: 128Mi
        node:
          linux:
            trident-main:
              requests:
                cpu: 10m
                memory: 60Mi
              limits:
                cpu: 200m
                memory: 256Mi
            # sidecars
              requests:
                cpu: 10m
                memory: 10Mi
              limits:
                cpu: 50m
                memory: 32Mi
          windows:
            trident-main:
              requests:
                cpu: 60m
                memory: 40Mi
              limits:
                cpu: 200m
                memory: 128Mi
            # sidecars
              requests:
                cpu: 40m
                memory: 40Mi
              limits:
                cpu: 100m
                memory: 128Mi
            liveness-probe:
              requests:
                cpu: 20m
                memory: 40Mi
              limits:
                cpu: 50m
                memory: 64Mi​
    Important Disclaimer: The resource values shown in the examples above are for demonstration purposes only. They are not official recommendations from NetApp. Actual resource requirements vary significantly based on cluster size, number of persistent volumes, I/O workload intensity, backend type, and whether features like snapshots or autosupport are heavily used. Always monitor your Trident pods in a test or staging environment using kubectl top, Prometheus, or similar tools, and adjust requests and limits to match your observed real-world usage.
Post-deployment
, you can verify resource values with kubectl describe torc trident -n trident and check status.currentInstallationParams.resources.
Updating Resource Requests and Limits Post-Installation
User might find the need to adjust CPU and memory requests or limits values for controller or node pod containers. The method to update these resources depends on whether you originally installed Trident using the Trident Operator (TridentOrchestrator CR) or Helm.
If Trident is installed using Trident Operator i.e. via the TridentOrchestrator (TORC) CRD, user can update resource values by running kubectl edit command and then modifying spec.resources section with new values or through kubectl patch command.
For installations done through Helm, Use the helm upgrade command with updated values for CPU and memory in your Helm chart’s values file or directly by using --set flag.
Note: Keep in mind that changing resource requests or limits will trigger a rolling restart of the Trident controller and node pods.
Best Practices and Common Pitfalls
Drawing from Kubernetes wisdom, here's how to get it right for Trident:
Do's
  • Monitor and Iterate: Use tools like Prometheus or kubectl top to profile usage, then adjust values based on that.
  • Test in Staging: Simulate loads to validate limits without OOM kills.
Don'ts
  • Over-Request: This wastes capacity; Trident is lightweight, so avoid inflating beyond observed needs.
Wrapping Up: Tune, Deploy, Prosper
Resource requests and limits are your Kubernetes Swiss Army knife for Trident, turning potential chaos into controlled efficiency. By understanding the basics, leveraging defaults, and customizing thoughtfully, you'll ensure seamless storage orchestration even under load.
Ready to optimize? Grab your Trident Helm chart or CRD, tweak those resources, and deploy. Your cluster—and your apps—will thank you.
For more on Kubernetes resources, check the K8s official docs. Trident setup details are in NetApp Trident's guides.
