SCVMM 2012 R2 polls "Windows Standard Storage management service" every 2 hours to update its Database, you can verify this behaviour by analyzing the "Reads Storage Provider" job in SCVMM Jobs pane.
We can see below that the Read-SCStorageProvider cmdlet retrieves updated information from the storage provider including array, pool,and logical unit information exposed by the SMI-S provider every two hours.
Now if you need to fasten up this pooling process, you can create a scheduled job using powershell scheduled jobs "PSScheduledjob" module and fasten up the discovery process. Copy paste the below snippet in PowerShell - "Run as Administrator Mode".
#You can create scheduled tasks very easily if you have PowerShell v3 and above .
# Creates a scheduled job immediately which runs every 10 minutes
$trigger = New-JobTrigger -Once -At (Get-Date) -RepetitionInterval (New-TimeSpan -Minutes 10) -RepetitionDuration ([TimeSpan]::MaxValue)
Register-ScheduledJob -Name ReadStorageProvider -Trigger $trigger -ScriptBlock {
.DESCRIPTION
Following snippet runs the Read-SCStorageProvider cmdlet which retrieves updated information from the storage provider including array, pool,and logical unit information exposed by the SMI-S provider every 10 minutes
ipmo virtualmachinemanager
Get-SCStorageProvider | Read-SCStorageProvider
#After i Run this script on my elevated powershell prompt i was able to see the Job created in task scheduler under "TaskSchedulerLibrary\Microsoft\Windows\powershell\scheduledjobs"
Next wait for 10 minutes and verify that the job starts as scheduled every 10 minutes in SCVMM - Jobs pane.
I hope that you have enjoyed this blog entry and have found this information helpful.
Good Luck !
Thanks,
Vinith
