Virtualization Articles and Resources
Closing Locked Files using PowerShell in cDOT
mbeattie
Hi,
Clustered Data ONTAP doesn't support closing locked CIFS files using the MMC yet (coming in a future release) ...but even then do you really want to waste your time clicking in a GUI just to close a locked file?
I'd posted a previous solution for closing locked files in 7-Mode using sysinternals psfile.exe here:
https://communities.netapp.com/thread/22165
Unfortunately psfile.exe doesn't behave well with cDOT and I required the same functionality in cDOT for closing locked CIFS files on a vserver...so I developed a work around solution in the interim (see code and example output below).
I'll be porting this into a WFA workflow and uploading to communities. Hope this helps
Matt
Example Output:
PS C:\Scripts\> .\CloseLockedFile.ps1 -FileSpec "\\vserver1\share1$\folder1\data\employees.accdb"
The Script "CloseLockedFile.ps1" Started Processing.
Imported Module "DataOnTap"
Please enter the password for user "vsadmin": *************
Connected to vserver "vserver1"
Enumerated the mount point for CIFS share "share1$" as "/volume1/qtree1"
NcController : vserver1
Value        :
               2 entries were acted on.
Executed Command: set advanced;vserver locks break -vserver vserver1 -volume volume1 -lif * -path /volume1/qtree1/folder1/data/employees.accdb
The Script "CloseLockedFile.ps1" Completed Successfully.
Param(
   [CmdletBinding()]
   [Parameter(Position=0,
      Mandatory=$True,
      ValueFromPipeLine=$True,
      ValueFromPipeLineByPropertyName=$True)]
   [String]$FileSpec
'Script Name : CloseLockedFile.ps1
'Author      : Matthew Beattie
'Email       : mbeattie@netapp.com
'Created     : 08/06/14
'Description : This script closes a locked file on a CIFS share on a
'            : NetApp storage controller running Clustered Data ONTAP.
'            : It accepts a FileSpec parameter containing the UNC Path of the
'            : file to close.
#'Initialization Section.
[String]$scriptPath     = Split-Path($MyInvocation.MyCommand.Path)
[String]$scriptSpec     = $MyInvocation.MyCommand.Definition
[String]$scriptBaseName = (Get-Item $scriptSpec).BaseName
[String]$scriptName     = (Get-Item $scriptSpec).Name
Write-Host "The Script ""$scriptName"" Started Processing."
#'Split the files UNC Path into variables.
[String]$modulename = "DataOnTap"
[Array]$elements    = $fileSpec -Split [regex]::Escape("\")
[String]$hostName   = $elements[2]
[String]$shareName  = $elements[3]
[String]$fileName   = $elements[$elements.Length -1]
[String]$folderPath = "/"
#'Import the Data ONTAP powershell module.
Try{
   Import-Module $moduleName -ErrorAction Stop
   Write-Host "Imported Module ""$moduleName"""
}Catch{
   Write-Error "Failed Importing Module ""$moduleName"""
   Break;
#'construct the folder path between the share and file name.
For($i=4; $i -lt ($elements.Count -1); $i++){
   [String]$folderPath = $folderPath + $elements[$i] + "/"
#'Ensure the vserver is online and responding to ICMP requests.
If(-Not(Test-Connection -computername $hostName -count 1)){
   Write-Warning "The vserver ""$hostName"" did not respond to an ICMP request"
   Break;
#'Prompt for credentials to connect to the vserver.
[String]$username = "vsadmin"
[System.Security.SecureString]$password = `
Read-Host "Please enter the password for user ""$username""" -AsSecureString
[System.Management.Automation.PSCredential]$credentials = `
New-Object System.Management.Automation.PSCredential -ArgumentList $username, $password
#'Connect to the vserver.
Try{
   Connect-NcController -Name $hostName -Credential $credentials -HTTPS -ErrorAction Stop | Out-Null
   Write-Host "Connected to vserver ""$hostName"""
}Catch{
   Write-Error "Failed connecting to vserver ""$hostName"""
   Break;
#'Enumerate the mount point of the CIFS share matching the share name.
Try{
   [String]$mountPoint = Get-NcCifsShare -Name $shareName -ErrorAction Stop | `
                         Select-Object -ExpandProperty Path
   Write-Host "Enumerated the mount point for CIFS share ""$shareName"" as ""$mountPoint"""
}Catch{
   Write-Error "Failed enumerating the CIFS share named ""$shareName"""
   Break;
#'Set the command to close the locked CIFS file
[String]$volumeName = $mountPoint.Split("/")[1]
[String]$filePath   = "$mountPoint$folderPath$fileName"
[String]$command    = "set advanced;vserver locks break -vserver $hostName -volume $volumeName -lif * -path $filePath"
#'Invoke the command to close the CIFS locked files.
Try{
   Invoke-NcSsh -Name $hostName -Command $command -Credential $credentials -ErrorAction Stop
   Write-Host "Executed Command: $command"
}Catch{
   Write-Error "Failed executing Command: $command"
   Break;
Write-Host "The Script ""$scriptName"" Completed Successfully."
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Please Note:
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information (PII)
  • Copyrighted materials without the permission of the copyright owner
Continued non-compliance may result in NetApp Community account restrictions or termination.
Replies
mbeattie
Attached the WFA workflow which also supports DFS integration. The requirements are:
  • The “vsadmin” account enabled on the vserver serving the CIFS share
  • The credentials for the “vsadmin” account are added to the WFA Cache
  • The file input parameter must be in double quotes
  • DFS Management utilities installed on the WFA server
    >Install-WindowsFeatuure RSAT-DFS-Mgmt-Con
NOTE: If WFA is installed on Windows Server 2012 R2 the DFSN powershell module could be integrated to manage the DFS namespace instead of "dfsutil.exe" http://technet.microsoft.com/en-us/library/jj884270.aspx)
jkane13
I am trying to implement this and having a problem.  Wondering if anyone can help.
Looking at another thread for 7 mode, I found a way to add the WARNING message to see a little more of what is happening.  I add that code and also ser -VERBOSE mode.
This is the error message I get.
VERBOSE: Trying HTTP/HTTPS
WARNING: Failed connecting to Controller "vserver_test". Object reference not set to an instance of an object.
C:\Users\me\CloseLockedFile.ps1 : Failed connecting to vserver "vserver_test"
+ CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,CloseLockedFile.ps1
Connecting from a command line directly, I get this.
PS C:\Users\me\PowerShell> Connect-NcController vserver_test
Connect-NcController : Object reference not set to an instance of an object.
At line:1 char:1
+ Connect-NcController vserver_test
+ CategoryInfo : InvalidResult: (vserver_test:NcController) [Connect-NcController], NullReferenceExcep
tion
+ FullyQualifiedErrorId : HttpConnectionFailed,DataONTAP.C.PowerShell.SDK.ConnectNcController
If I go to a 7Mode filer and change Nc to Na, it seems to work.
Any ideas?
mbeattie
Hi There,
This script assumes you are authenticating to the vserver as "vsadmin" so you might need to change the $username variable if you are attempting to use a different user. Also i'd check that your vserver named "vserver_test" has the appropriate A & PTR records registered in DNS otherwise you can use the vservers IP Address instead. Are you able to connect to the vserver using the followin PowerShell code:
Import-Module DataONTAP
$hostname    = "vserver_test" #Note you could also use the IP Address of the vserver
$password    = Read-Host "Please enter the password for user ""$username""" -AsSecureString
$credentials = New-Object System.Management.Automation.PSCredential -ArgumentList $username, $password
Connect-NcController -Name $hostname -Credential $credentials -HTTPS
Let me know, hope that helps
/matt
jkane13
I had been using either my personal ID or the root ID and those do the same thing.  No, the script you put here did not work.  Did the same thing.
I put in the IP address and still got the same output.
$hostname = "172.30.XX.XX" #Note you could also use the IP Address of the vserver
$username = "root"
PS C:\Users\me> C:\Users\me\dotlogin.ps1
At C:\Users\me\dotlogin.ps1:6 char:1
+ Connect-NcController -Name $hostname -Credential $credentials -HTTPS
+ CategoryInfo : InvalidResult: (172.30.XX.XX:NcController) [Connect-NcController], NullReferenceException
jkane13
Hmmm.  I decided to try invalid credentials.  Weird!  It does not say "Incorrect credentials" like it should.  I get the same "Object reference not set to an instance of an object" message instead.
This is making me wonder if the filer has some config setting that is not right.
mbeattie
Hi,
I noticed you changed the username variable to "root". If you are looking for a solution to closing locked files for 7-Mode systems then i've posted a script here:
http://community.netapp.com/t5/Microsoft-Cloud-and-Virtualization-Discussions/Unlocking-files-via-Powershell/m-p/47124#M2213
I would advise ensuring that you can SSH to the vserver as vsadmin using Putty. Try logging onto the cluster as "admin" and checking the state of the vsadmin account on the vserver.
cluster1> security login show -vserver vserver1
Vserver: vserver1
                             Authentication                  Acct
UserName         Application Method         Role Name        Locked
TESTLAB\Administrator
                 ssh         domain         vsadmin          -
vsadmin          ontapi      password       vsadmin          no
vsadmin          ssh         password       vsadmin          no
Ensure the vsadmin account is not Locked. If not and you still can't authenticate to the vserver as that account then can you check the logs and post the error. Thanks
/matt
jkane13
Well, it is a test system.  So I should have susepcted that it was not configured right.  I could not ssh directly to the vserver.  I could connect to cifs shares.
There were no network interfaces configured with management access.  They were all data only.  DOH!
It's working now that I created a new interface.
jkane13
Thanks a lot!  You have been a lot of help and this is a good learning experience.
I am curious about how this is different from using Computer Manager and remotely closing the files in the GUI.
This is what I see ...
If I close the files with the GUI, running a `vserver locks show` shows the files closed.
If I close the file on the filer with `vserver locks break ...`, the GUI shows the file as still locked.
My guess is that the GUI is not updating right, even when clicking refresh, or even closing and reopening the console.
I even remoted to another windows server and opened a new computer management console there to remotely look at the Open Files and the file shows open.
That makes me think that maybe the file really isn't closed yet after running vserver locks break.
Does this make sense?  Which should I trust?
Or ... is this what you meant by "Clustered Data ONTAP doesn't support closing locked CIFS files using the MMC yet (coming in a future release)"?
dmitryyablonsky
Hi,
we try to implement the script  on our environment .
The scirpt  is working  but we have an issue with  lang  he.UTF-8  support
It's seems there is a compatebility issue .
Please advise
Dmitry.
mbeattie
I know this is a really old thread now but for anyone still following...there are PowerShell CmdLets available for working with listing\closing CIFS files instead of using the CLI. See the help documentation for the following cmdlets:
Get-Help Get-NcCifsSessionFile -Full
Get-Help Close-NcCifsSessionFile -Full
Here is an "example" of a WFA command to close a CIFS file.
Note: If using the code below, note that the file UNC Path IS Case Sensitive  from an ONTAP perspective but NOT from a Windows perspective
Param(
   [Parameter(Mandatory=$True, HelpMessage="The UNC Path of the file to close. The UNC Path must be enclosed in double quotes")]
   [String]$FileSpec
#'Split the UNC path of the file.
$fileSpec.Replace("""", "")
#'Enumerate the IP Address of the hostname (it could be a DNS CName alias).
[String]$ip = [System.Net.Dns]::GetHostAddresses($hostname).IPAddressToString
If([String]::IsNullOrEmpty($ip)){
   Throw "The host ""$hostName"" did not resolve in DNS. Please ensure DNS is configured"
}Else{
   Get-WFALogger -Info -Message "Resolved ""$hostname"" to IP Address ""$ip"""
#'Enumerate the host (DNS A Record) that resoloves to the IP Address (DNS PTR Record).
[String]$fqdn = [System.Net.Dns]::GetHostEntry($ip).HostName
If([String]::IsNullOrEmpty($fqdn)){
   Throw "The IP Address ""$ip"" did not resolve in DNS. Please ensure DNS is configured"
}Else{
   Get-WFALogger -Info -Message "Resolved IP Address ""$ip"" to FQDN ""$fqdn"""
#'Enumerate the cluster name from the vserver name.
[String]$vserverName = $fqdn.Split(".")[0].ToLower();
[String]$mySqlQuery  = "SELECT cluster.name FROM cm_storage.cluster, cm_storage.vserver WHERE vserver.cluster_id = cluster.id AND vserver.name = '$vserverName'"
Get-WFALogger -Info -Message "Enumerating cluster name for vserver ""$vserverName"""
Try{
   $records = Invoke-MySqlQuery -Query $mySqlQuery -ErrorAction Stop
   Get-WFALogger -Info -Message "Invoked SQL Query`: ""$mySqlQuery"""
}Catch{
   Get-WFALogger -Error -Message $("Failed Invoking SQL Query`: ""$mySqlQuery"". Error " + $_.Exception.Message)
   Throw "Failed Enumerating cluster name for vserver ""$vserverName"""
[String]$cluster = $records[1].Name
If([String]::IsNullOrEmpty($cluster)){
   Get-WFALogger -Error -Message "The SQL recordset returned Null"
   Throw "Failed enumerating cluster name for vserver ""$vserverName"""
For($i=4; $i -lt ($elements.Count); $i++){
   [String]$folderPath += $elements[$i] + "\"
[String]$folderPath = $folderPath.SubString(0, $folderPath.Length -1)
If(-Not(Test-Connection -computername $vserverName -count 1)){
   Throw "The vserver ""$vserverName"" did not respond to an ICMP request"
}Else{
   Get-WFALogger -Info -Message "The vserver ""$vserverName"" responded to an ICMP request"
#'Connect to the cluster.
Connect-WFACluster $Cluster
#'Enumerate the open CIFS file.
$query         = Get-NcCifsSessionFile -Template
$query.Path    = $folderPath
$query.Share   = $shareName
$query.Vserver = $vserverName
Try{
   $file = Get-NcCifsSessionFile -Query $query -ErrorAction Stop
   Get-WFALogger -Info -Message "Enumerated file ""$FileSpec"""
}Catch{
   Get-WFALogger -Error -Message $("Failed enumerating file ""$FileSpec"". Error " + $_.Exception.Message)
   Throw "Failed enumerating file ""$FileSpec"""
#'Ensure the file is open.
If($Null -eq $file){
   Throw "The file ""$FileSpec"" is not currently open. Please check the UNC Path. Please note that the UNC Path is case sensitive."
}Else{
   Get-WFALogger -Info -Message $("Closing File ""$FileSpec"" on Node """ + $file.Node + """ -FileId """ + $file.FileId + """ -ConnectionId """ + $file.ConnectionId + """ -SessionID """ + $file.SessionId + """")
#'Close the open CIFS file.
Try{
   [String]$command = $("Close-NcCifsSessionFile -Node " + $file.Node + " -FileId " + $file.FileId + " -ConnectionId " + $file.ConnectionId + " -SessionID " + $file.SessionId + " -VserverContext " + $file.Vserver + " -Confirm`:`$False -ErrorAction Stop")
   Invoke-Expression -Command $command -ErrorAction Stop
   Get-WFALogger -Info -Message "Executed Command`: $command"
   Get-WFALogger -Info -Message "Closed file ""$FileSpec"" on vserver ""$hostname"""
}Catch{
   Get-WFALogger -Error -Message $("Failed Executing Command`: $command. Error " + $_.Exception.Message)
   Throw "Failed closing file ""$FileSpec"" on vserver ""$hostname"""
Hope that helps
/Matt
