If you have multiple controllers (in this case 7-mode only) and want to update the firmware and disk qualification package on these you have different possibilities to perform this task. All have in common that you have to touch each controller... which can be time-consuming. Therefore this little helper has been developed to reduce the required effort.
The following powershell script utilizes the default etc$ share to upload disk firmware and/or disk qualification packages to a 7DOT controller. With a simple loop this action can be executed on multiple 7DOT controllers sequentially.
Requirements:
- DataONTAP Powershell Toolkit
- Microsoft Powershell 3.0 (necessary for authenticated access to etc$ share via PSDrive)
- Microsoft .NET Framework 4.0 or 4.5 (neecessary for Powershell 3.0)
.SYNOPSIS
Uploads a given Disk Firmware and/or Disk Qualification Package to a 7-Mode controller.
.DESCRIPTION
Disk Firmware and/or Disk Qualification Package are uploaded using this Cmdlet by using the etc$ share of a 7-mode controller.
Connection is done using a PSDrive.
Requires PowerShell 3.0 or higher
.PARAMETER PathDFW
Path to the Disk Firmware (either zipped file or unzipped folder).
.PARAMETER PathDQP
Path to the Disk Qualification Package (either zipped zile or unzipped folder).
.PARAMETER Credential
Credentials used to connect to the etc$ share of the 7-mode controller.
.PARAMETER Controller
PSController to upload the files to. If no controller is specified the $global:CurrentNaController is used.
.PARAMETER NoBackgroundUpdate
Switch to disable the automatic background firmware update after uploading the Disk Firmware (not applicable if only Disk Qualification Package is uploaded).
.EXAMPLE
param (
[Parameter(Position=1,Mandatory=$False,ValueFromPipeline=$false)]
[String]$PathDFW,
[Parameter(Position=2,Mandatory=$False,ValueFromPipeline=$false)]
[String]$PathDQP,
[Parameter(Position=3,Mandatory=$True,ValueFromPipeline=$false)]
$Credential,
[Parameter(Position=4,Mandatory=$False,ValueFromPipeline=$false)]
[ValidateScript({($_ -is [NetApp.Ontapi.Filer.NaController]) -and ($_ -ne $null)})]
$Controller = $global:CurrentNaController,
[Parameter(Mandatory=$False,ValueFromPipeline=$false)]
[Switch]$NoBackgroundUpdate
$continue = $true
$DFW_unzip = $false
$DQP_unzip = $false
$DFW_uploaded = $false
#region "Check parameters"
# Check DataONTAP module
if (Get-Module -ListAvailable DataONTAP) {
Import-Module DataONTAP
} else {
Write-Error ("Required Module 'DataONTAP' is missing.")
$continue = $false
# Check $PathDFW and $PathDQP variable
if (!$PathDFW -and !$PathDQP) {
Write-Error ("No Disk Firmware and Disk Qualification Package file specified.")
$continue = $false
} else {
if ($PathDFW) {
if (Test-Path -Path $PathDFW -PathType Leaf) {
if ((Get-ChildItem $PathDFW).Extension -like ".zip") {
Write-Output "Disk Firmware file detected (zipped). Unzipping will be executed before upload."
$DFW_unzip = $true
} else {
Write-Error ("Invalid Disk Firmware file path specified.")
$continue = $false
} else {
if (Get-ChildItem $PathDFW -Recurse -Include *.lod,*.ctl) {
Write-Output "Disk Firmware files detected (unzipped)."
} else {
$continue = $false
if ($PathDQP) {
if (Test-Path -Path $PathDQP -PathType Leaf) {
if ((Get-ChildItem $PathDQP).Extension -like ".zip") {
Write-Output "Disk Qualification Package file detected (zipped). Unzipping will be executed before upload."
$DQP_unzip = $true
} else {
Write-Error ("Invalid Disk Qualification Package file path specified.")
$continue = $false
} else {
if (Get-ChildItem $PathDQP -Recurse -include qual_device*) {
Write-Output "Disk Qualification Package files detected (unzipped)."
} else {
$continue = $false
# Check $Controller variable
if ($Controller -eq $null) {
if ($global:CurrentNaController -ne $null) {
} else {
Write-Error ("No existing connection to a controller found.")
$continue = $false
# Check $Credential variable
If ($continue -and $Credential -and ($Credential.GetType().Fullname -ne "System.Management.Automation.PSCredential")) {
$Credential = Get-Credential $Credential
If ($Credential.GetType().Fullname -ne "System.Management.Automation.PSCredential") {
Write-Error ("No credential specified. Unable to connect to controller.")
$continue = $false
if (!$PathDFW -and $NoBackgroundUpdate) {
Write-Warning ("No Disk Firmware file specified. Background update settings are not updated.")
#endregion
if ($continue) {
#region "Define variables"
if ($PathDFW) {
$DFW_zipped = Convert-Path $PathDFW
$DFW_unzipped_parenpath = Split-Path ($DFW_zipped) -Parent
$DFW_unzipped_foldername = "all\"
$DFW_unzipped_path = $(Join-Path -Path $DFW_unzipped_parenpath -ChildPath $DFW_unzipped_foldername)
$DFW_destination_foldername = "disk_fw\"
if ($PathDQP) {
$DQP_zipped = Convert-Path $PathDQP
$DQP_unzipped_parenpath = Split-Path ($DQP_zipped) -Parent
$DQP_unzipped_foldername = "DQP\"
$DQP_unzipped_path = $(Join-Path -Path $DQP_unzipped_parenpath -ChildPath $DQP_unzipped_foldername)
$DQP_destination_foldername = "\"
$controller_share = "\\" + $Controller.Name + "\etc$"
$controller_share_drivename = "ScriptWorkDir"
$controller_share_driveletter = $controller_share_drivename + ":"
#endregion
#region "Unzip files"
$shell_app = New-Object -ComObject Shell.Application
if ($DFW_unzip) {
if (Test-Path $DFW_unzipped_path) {
Remove-Item $DFW_unzipped_path -Recurse -Force
New-Item -ItemType directory -Path $DFW_unzipped_path | Out-Null
$zip_file = $shell_app.Namespace($DFW_zipped)
$unzipped_folder = $shell_app.Namespace($DFW_unzipped_path)
$unzipped_folder.Copyhere($zip_file.Items())
$zip_file = $null
$unzipped_folder = $null
Write-Output ("Disk Firmware files extracted to {0} " -f $DFW_unzipped_path)
} else {
$DFW_unzipped_path = $DFW_zipped
if ($DQP_unzip) {
if (Test-Path $DQP_unzipped_path) {
Remove-Item $DQP_unzipped_path -Recurse -Force
New-Item -ItemType directory -Path $DQP_unzipped_path | Out-Null
$zip_file = $shell_app.Namespace($DQP_zipped)
$unzipped_folder = $shell_app.Namespace($DQP_unzipped_path)
$zip_file = $null
$shell_app = $null
Write-Output ("Disk Qualification Package files extracted to {0} " -f $DQP_unzipped_path)
} else {
$DQP_unzipped_path = $DQP_zipped
$shell_app = $null
#endregion
#region "Copy files to controller"
New-PSDrive -name $controller_share_drivename -PSProvider FileSystem -Root $controller_share -Credential $Credential | Out-Null
If (Test-Path $controller_share_driveletter) {
Write-Output ("{0} connected as PSDrive '{1}'" -f $controller_share, $controller_share_drivename)
if ($PathDFW) {
$DFW_destination_path = Join-Path -Path $controller_share_driveletter -ChildPath $DFW_destination_foldername
Get-ChildItem -Path $DFW_unzipped_path -Recurse | ? {!$_.PSIsContainer} | % { Copy-Item -Path $_.fullname -Destination $DFW_destination_path -Force }
Write-Output ("Disk Firmware files uploaded at {0}" -f $DFW_destination_path)
$DFW_uploaded = $true
if ($PathDQP) {
$DQP_destination_path = Join-Path -Path $controller_share_driveletter -ChildPath $DQP_destination_foldername
Get-ChildItem -Path $DQP_unzipped_path -Recurse | ? {!$_.PSIsContainer} | % { Copy-Item -Path $_.fullname -Destination $DQP_destination_path -Force }
Write-Output ("Disk Qualification Package files uploaded at {0}" -f $DQP_destination_path)
#$net.RemoveNetworkDrive($controller_share_driveletter)
Remove-PSDrive -Name $controller_share_drivename
Write-Output ("{0} disconnected as PSDrive '{1}'" -f $controller_share, $controller_share_drivename)
} else {
Write-Error ("Unable to connect to {0}. Please check the share and/or credentials." -f $controller_share)
if ($DFW_unzip) {
Write-Output ("Disk Firmware files (unzipped) removed at {0} " -f $DFW_unzipped_path)
if ($DQP_unzip) {
Write-Output ("Disk Qualification Package files (unzipped) removed at {0} " -f $DQP_unzipped_path)
#endregion
#region "Enable background firmware update"
if ($PathDFW -and $DFW_uploaded) {
if ($NoBackgroundUpdate) {
Set-NaOption -Controller $Controller -OptionName raid.background_disk_fw_update.enable -OptionValue off | Out-Null
Write-Output ("Background Disk Firmware update disabled on {0} (raid.background_disk_fw_update.enable off)" -f $Controller.Name)
} else {
Set-NaOption -Controller $Controller -OptionName raid.background_disk_fw_update.enable -OptionValue on |Out-Null
Write-Output ("Background Disk Firmware update enabled on {0} (raid.background_disk_fw_update.enable on)" -f $Controller.Name)
#endregion
Here an example for performing a disk firmware and disk qualification package update on multiple controllers listed in a simple text file:
$cred = Get-Credential <username_for_share_access>
Get-Content .\controllers.txt | % {
Connect-NaController $_
.\Upload-NaDiskFirmware.ps1 -PathDFW <path_to_disk_firmware> -PathDQP <path_to_disk_qualification_package> -Credential $cred
