Virtualization Articles and Resources
Powershell script to expand/contract volume on SM and non-SM volumes
Hi Guys,
I just wrote a script to expand/contract a volume.  I needed to write this specifically for volumes in snapmirror relationships because someone would expand source volume and then forget to expand the destination and then snapmirror would start failing.
I am pretty new to powershell and this is probably my most complicated script so all in all I am looking for any inputs on how I can make this better.  It works perfectly for me but your inputs will be appreciated.  Feel free to use it for yourself.  There is nothing to modify for your specific environment.  This is totally interactive script.  Also, you will only have to login once, once you login it stores your credentials and in domain environment, then it will login to source and destination filers.
Logic is pretty simple and it is as follows:
Ask for filer name and then ask for prompt to login.
Ask for volume on the source filer that you wan to expand.
At this point, if the volume is in Snapmirror relationship, it will enter the "IF" loop and depending upon the size you enter, it will expand/contract both source and destination volume.
If the volume is not in snapmirror relationship, it will enter "ELSE" and expand the source volume.
#    Volume Expansion/Contraction Script        #
#                 Author:                      #
#                Nimish Naik                      #
import-module .\DataONTAP.dll
$sfiler = ""
$svol = ""
$saggr = ""
$saggrfrespace = ""
$dispfreesaggrspace = ""
$sm = ""
$dfiler = ""
$dvol = ""
$daggr = ""
$daggrfreespace = ""
$dispfreedaggrspace = ""
$dvol = ""
$size = ""
while ($sfiler -eq ""){
   Clear-Host
   $sfiler = read-host "Enter the name of filer"
clear-host
connect-nacontroller $sfiler -Credential (Get-Credential)
add-nacredential
while ($svol -eq ""){
   Clear-Host
   $svol = read-host "Enter name of volume you'd like to expand/contract"
$sm = Get-NaSnapmirrorDestination $svol
if ($sm.destinationlocation -gt '0') {
$saggr = get-navolcontainer -controller $sfiler -name $svol
$saggrfreespace = $saggr.sizeavailable /1024 /1024/1024
$dispfreesaggrspace = "Free space on aggregate $saggr on $sfiler = $saggrfreespace GB"
$split = $sm.destinationlocation.split(":")
$dfiler = $split[0]
$dvol = $split[1]
connect-nacontroller $dfiler -Credential (Get-NaCredential $sfiler -SystemScope $false).Credential
$daggr = get-navolcontainer -controller $dfiler -name $dvol
$daggrfreespace = $daggr.sizeavailable /1024 /1024 /1024
$dispfreedaggrspace = "Free space on aggregate $daggr on $dfiler = $daggrfreespace GB"
while ($size -eq ""){
   Clear-Host
   write-host "If you are expanding the volume, the format MUST be in (+)(size)(value) format"
   write-Host "For example, if you want to expand the volume by 100 MB, the format to enter on next screen MUST be +100m"
   write-host ""
   write-host "If you are contracting the volume the format MUST be in (-)(size)(value) format"
   write-Host "For example, if you want to contract the volume by 100 MB, the format to enter on next screen MUST be -100m"
   write-host ""
   read-host "valid values are k, m, g, t "
   write-host ""
   $dispfreesaggrspace
   $dispfreedaggrspace
   write-host ""
   $size = read-host "How much would you like volume $svol and $dvol to expand(+)/contract(-) by?"
   clear-host
   write-host "Resize the volumes $svol on $sfiler & $dvol on $dfiler by $size ?"
   read-host "You must press the Any key on top right of the keyboard to continue. Press Ctrl-C to cancel"
Connect-NaController $sfiler -Credential (Get-NaCredential $sfiler -SystemScope $false).Credential
clear-host
set-navolsize $svol $size
clear-host
Connect-NaController $dfiler -Credential (Get-NaCredential $sfiler -SystemScope $false).credential
clear-host
set-navolsize $dvol $size
clear-host
remove-nacredential $sfiler
else {
   Clear-Host
   write-host ""
   write-host
   read-host "valid values are k, m, g, t - Press any key to continue"
   clear-host
   $dispfreesaggrspace
   $size = read-host "How much would you like volume $svol to expand(+)/contract(-) by?"
   clear-host
   write-host "Resize the volumes $svol on $sfiler by $size ?"
clear-host
Please Note:
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information (PII)
  • Copyrighted materials without the permission of the copyright owner
Continued non-compliance may result in NetApp Community account restrictions or termination.
Replies
Good. Try using "Write-Host" to minimum and use powershell objects instead.
Also you can use custom hash tables to append all values to one place rather than using Add-Content to create reusable objects, please have a look at the linkhttp://blogs.msdn.com/b/powershell/archive/2009/12/05/new-object-psobject-property-hashtable.aspx
Thanks Vinith,
Much appreciated.  I will surely look in to hash tables.
All Community Forums
