Virtualization Articles and Resources
This script started as a repeatable process to create a NetApp volume with our standard options. From there, it morphed into not only creating the volume, but also creating the NFS exports, adding it the the ESX hosts, and setting up QSM to a DR Filer. There are a few assumptions made in the script that work for our environment. They will likely need to be tweaked for your individual environment, but thought I would put this out there for others to use.
The defaults for this script are to create a qtree for each volume with the same name, set no_atime_update to on and fractional_reserve to 0, set create_ and convert_ucode to on, set autogrow to vol size +200g with 20g growth, create hidden CIFS share. For the DR side, it will suggest some defaults (such as appending sm_ to beginning of volume name, 105% vol size, mirror 1 hour after source snapshot, destination snapshot 1 hour after mirror, run both source and destination ASIS at same time if both are selected in the script.
Some options you may want to change are:
Lines 49-50 (path to text files with Filer lists)
Line 301 (default source hourly snapshots to keep)
Lines 430, 437, 444 (NFS export details)
Line 460 (default auto add vCenter datastores)
Lines 1118-1136 (ESX datastore creation selection)
Line 1333 (default DR volume name)
Line 1334 (default DR volume size)
Line 1404 (default DR hourly snapshots to keep)
Line 1422, 1457, 1484 (default DR ASIS on, compression and inline compress on 64-bit aggrs)
Lines 1748-1773 (default DR snapshot schedule - 1 hour after QSM)
Lines 2097-2122 (default DR ASIS schedule - same as source schedule)
Lines 2421-2446 (default QSM schedule - 1 hour after source snapshot)
Line 2630 (default autogrow max - vol size +200g)
Lines 2666-2668 (NFS export details)
Lines 2674-2682 (default source volume options)
Line 2697 (default autogrow increment - +20g)
Lines 2704-2717 (ESX datastore details)
Line 2753 (default DR autogrow max - vol size +200g)
Lines 2791-2799 (default DR volume options)
## Volume Creation Script - Created by Stephen Kiser - 3/1/13 ##
## Create Source and DR volumes with QSM and ESX datastore creation options ##
## NECESSARY SYSTEM CALLS ##
[void] [System.Reflection.Assembly]::LoadWithPartialName("System.Drawing")
[void] [System.Reflection.Assembly]::LoadWithPartialName("System.Windows.Forms")
# Check for NetApp and VMware PowerShell modules/snapins
Function Load_Module($name) {
If (!(Get-Module -Name $name)) {
If (Get-Module -ListAvailable | Where { $_.name -eq $name })
{Import-Module $name;Return $true}
Else
{Return $false;$global:x="2"}
Else
{Return $true}
$moduleName = "DataONTAP"
$VMwareLoaded=$False
$snapIn = "VMware*"
Try {
If (Load_Module $moduleName) {Write-Host "Loaded Module: $moduleName";$OnTAPLoaded=$true}
Else {
Write-Host "Failed to load $moduleName."
Write-Host "You can install it from G:\Systems\Virtualization\Scripts\PowerShellAddIns"
Write-Host "Unzip the DataONTAP.zip file to C:\Windows\System32\WindowsPowerShell\v1.0\Modules"
Write-Host "Aborting script."}
Catch {Write-Host "Exception caught: $_"}
Add-PSSnapin $snapIn -ErrorAction SilentlyContinue
If ((Get-PSSnapin $snapIn) -eq $null) {
Write-Host "This script requires VMware PowerCLI, but it was not found on this system."
Write-Host "Run the latest version of the VMware-PowerCLI executable"
$global:x = "2"
Else {
$vmware = $snapIn.substring(0,(($snapIn.length)-1))+" PowerCLI"
Write-Host "Loaded SnapIn: $vmware"
$VMwareLoaded=$true
# Continue if both required modules/snapins are loaded
If ($OnTAPLoaded -and $VMwareLoaded) {
## Filer List Variables
$Filers = GC "C:\Scripts\Vol_Create\filers.txt"
$DR_filers = GC "C:\Scripts\Vol_Create\dr_filers.txt"
## FUNCTIONS ##
Function Select_Filer ($Filers) {
# Get the Filer to create the source volume on
$form = New-Object System.Windows.Forms.Form
$form.Text = "Filer Selection"
$form.Size = New-Object System.Drawing.Size(300,200)
$form.StartPosition = "CenterScreen"
$L_Filer = New-Object System.Windows.Forms.Label
$L_Filer.Location = New-Object System.Drawing.Size(10,20)
$L_Filer.Size = New-Object System.Drawing.Size(280,20)
$L_Filer.Text = "What Filer do you want to create the volume on?"
$form.Controls.Add($L_Filer)
$CB_Filer = New-Object System.Windows.Forms.ComboBox
$CB_Filer.DropDownStyle = "DropDownList"
ForEach ($Filer in $Filers) {$CB_Filer.Items.Add($Filer)}
$CB_Filer.Location = New-Object System.Drawing.Size(10,40)
$CB_Filer.Size = New-Object System.Drawing.Size(260,20)
$form.Controls.Add($CB_Filer)
$OKButton = New-Object System.Windows.Forms.Button
$OKButton.Location = New-Object System.Drawing.Size(75,120)
$OKButton.Size = New-Object System.Drawing.Size(75,23)
$OKButton.Text = "OK"
$OKButton.Add_Click({$global:MyFiler=($CB_Filer.SelectedItem.ToLower()).ToString();$global:x="0";$form.Close()})
$form.Controls.Add($OKButton)
$CancelButton = New-Object System.Windows.Forms.Button
$CancelButton.Location = New-Object System.Drawing.Size(150,120)
$CancelButton.Size = New-Object System.Drawing.Size(75,23)
$CancelButton.Text = "Cancel"
$CancelButton.Add_Click({$global:x="2";$form.Close()})
$form.Controls.Add($CancelButton)
$form.KeyPreview = $True
$form.Add_KeyDown({if ($_.KeyCode -eq "Enter")
{$global:MyFiler=($CB_Filer.SelectedItem.ToLower()).ToString();$global:x="0";$form.Close()}})
$form.Add_KeyDown({if ($_.KeyCode -eq "Escape")
{$global:x="2";$form.Close()}})
$form.Topmost = $True
$form.Add_Shown({$form.Activate()})
[void] $form.ShowDialog()
Function Select_Aggr ($aggr1, $aggrs) {
# Get the aggregate to create the volume on
# Function Variables
$agrList = $aggr1
$agrList1=$aggrs
# Function Definitions
$tlp_MainTable = New-Object System.Windows.Forms.TableLayoutPanel
$gb_SelectAggr = New-Object System.Windows.Forms.GroupBox
$cb_Aggr = New-Object System.Windows.Forms.ComboBox
$gb_AggrList = New-Object System.Windows.Forms.GroupBox
$tb_Aggrs = New-Object System.Windows.Forms.RichTextBox
$tlp_MainTable.SuspendLayout()
$gb_SelectAggr.SuspendLayout()
$gb_AggrList.SuspendLayout()
$form.SuspendLayout()
#tlp_MainTable
$tlp_MainTable.ColumnCount = 1
[void]$tlp_MainTable.ColumnStyles.Add((New-Object System.Windows.Forms.ColumnStyle([System.Windows.Forms.SizeType]::Percent, 100)))
$tlp_MainTable.Controls.Add($gb_SelectAggr, 0, 0)
$tlp_MainTable.Controls.Add($gb_AggrList, 0, 1)
$tlp_MainTable.Controls.Add($OKButton, 0, 2)
$tlp_MainTable.Dock = [System.Windows.Forms.DockStyle]::Fill
$tlp_MainTable.Location = New-Object System.Drawing.Point(0, 0)
$tlp_MainTable.Name = "tlp_MainTable"
$tlp_MainTable.RowCount = 3
[void]$tlp_MainTable.RowStyles.Add((New-Object System.Windows.Forms.RowStyle([System.Windows.Forms.SizeType]::Percent, 15)))
[void]$tlp_MainTable.RowStyles.Add((New-Object System.Windows.Forms.RowStyle([System.Windows.Forms.SizeType]::Percent, 75)))
[void]$tlp_MainTable.RowStyles.Add((New-Object System.Windows.Forms.RowStyle([System.Windows.Forms.SizeType]::Percent, 10)))
$tlp_MainTable.Size = New-Object System.Drawing.Size(650, 500)
#gb_SelectAggr
$gb_SelectAggr.Controls.Add($cb_Aggr)
$gb_SelectAggr.Dock = [System.Windows.Forms.DockStyle]::Fill
$gb_SelectAggr.Location = New-Object System.Drawing.Point(3, 3)
$gb_SelectAggr.Name = "gb_SelectAggr"
$gb_SelectAggr.Size = New-Object System.Drawing.Size(600, 20)
$gb_SelectAggr.TabStop = $false
$gb_SelectAggr.Text = "Select Aggregate To Create The New Volume On"
#$cb_Aggr
$cb_Aggr.AutoSize = $true
$cb_Aggr.Location = New-Object System.Drawing.Point(6, 20)
$cb_Aggr.Name = "cb_Aggr"
$cb_Aggr.DropDownStyle = "DropDownList"
$cb_Aggr.Size = New-Object System.Drawing.Size(260, 20)
$cb_Aggr.TabIndex = 1
ForEach ($ag in $agrList1 | Sort Name) {$cb_Aggr.Items.Add($ag.Name)}
#gb_AggrList
$gb_AggrList.Controls.Add($tb_Aggrs)
$gb_AggrList.Dock = [System.Windows.Forms.DockStyle]::Fill
$gb_AggrList.Location = New-Object System.Drawing.Point(3, 40)
$gb_AggrList.Name = "tb_AggrList"
$gb_AggrList.Size = New-Object System.Drawing.Size(600, 300)
$gb_AggrList.TabStop = $false
$gb_AggrList.Text = "List Of Available Aggregates"
#tb_Aggrs
$tb_Aggrs.AutoSize = $True
$tb_Aggrs.Location = New-Object System.Drawing.Point(6, 20)
$tb_Aggrs.Dock = [System.Windows.Forms.DockStyle]::Fill
$tb_Aggrs.Name = "tb_Aggrs"
$tb_Aggrs.Font = New-Object System.Drawing.Font("Lucida Console",9.5)
$tb_Aggrs.Size = New-Object System.Drawing.Size(600, 300)
$tb_Aggrs.TabStop = $false
$tb_Aggrs.ReadOnly = $true
$tb_Aggrs.AppendText("`nAggregate Name`tAvailable Size (GB)`tTotal Size (GB)`tBlock Type`n")
$tb_Aggrs.AppendText("--------------`t-------------------`t---------------`t----------`n")
ForEach ($agr in $agrList) {
If($agr.BlockType -ne "64_bit") {$agr.BlockType = "32_bit"}
$len = $agr.Name.Length
If ($len -lt 7) {$tb_Aggrs.AppendText($agr.Name+"`t`t`t"+[Math]::Truncate($agr.SizeAvailable / 1GB)+"`t`t`t`t"+[Math]::Truncate($agr.SizeTotal / 1GB)+"`t`t`t"+$agr.BlockType+"`n")}
ElseIf ($len -gt 11) {$tb_Aggrs.AppendText($agr.Name+"`t"+[Math]::Truncate($agr.SizeAvailable / 1GB)+"`t`t`t`t"+[Math]::Truncate($agr.SizeTotal / 1GB)+"`t`t`t"+$agr.BlockType+"`n")}
Else {$tb_Aggrs.AppendText($agr.Name+"`t`t"+[Math]::Truncate($agr.SizeAvailable / 1GB)+"`t`t`t`t"+[Math]::Truncate($agr.SizeTotal / 1GB)+"`t`t`t"+$agr.BlockType+"`n")}
#OKButton
$OKButton.Location = New-Object System.Drawing.Point(250,425)
$OKButton.TabIndex = 2
$OKButton.Add_Click({$global:MyAggr=($cb_Aggr.SelectedItem.ToLower()).ToString();$global:x="0";$form.Close()})
#CancelButton
$CancelButton.Location = New-Object System.Drawing.Point(325,425)
$CancelButton.TabIndex = 3
#Form
$form.AutoScaleDimensions = New-Object System.Drawing.SizeF(6, 13)
$form.AutoScaleMode = [System.Windows.Forms.AutoScaleMode]::Font
$form.AutoSize = $True
$form.ClientSize = New-Object System.Drawing.Size(600, 450)
$form.Controls.Add($tlp_MainTable)
$form.Name = "Form"
$form.Text = "Aggregate Selection"
#Final Layout
{$global:MyAggr=$cb_Aggr.SelectedItem.ToString();$global:x="0";$form.Close()}})
$tlp_MainTable.ResumeLayout($false)
$tlp_MainTable.PerformLayout()
$gb_SelectAggr.ResumeLayout($false)
$gb_SelectAggr.PerformLayout()
$gb_AggrList.ResumeLayout($false)
$gb_AggrList.PerformLayout()
$form.ResumeLayout($false)
[void]$form.ShowDialog()
Function Vol_Details (){
# Get the volume details
$form.Text = "Volume Details"
$form.Size = New-Object System.Drawing.Size(295,320)
$L_VName = New-Object System.Windows.Forms.Label
$L_VName.Location = New-Object System.Drawing.Size(10,10)
$L_VName.Size = New-Object System.Drawing.Size(280,20)
$L_VName.Text = "What name do you want to give to the volume?"
$form.Controls.Add($L_VName)
$TB_VName = New-Object System.Windows.Forms.TextBox
$TB_VName.Location = New-Object System.Drawing.Size(10,30)
$TB_VName.Size = New-Object System.Drawing.Size(260,20)
$form.Controls.Add($TB_VName)
$L_VSize = New-Object System.Windows.Forms.Label
$L_VSize.Location = New-Object System.Drawing.Size(10,50)
$L_VSize.Size = New-Object System.Drawing.Size(280,20)
$L_VSize.Text = "How large (in GB) do you want the volume to be?"
$form.Controls.Add($L_VSize)
$TB_VSize = New-Object System.Windows.Forms.TextBox
$TB_VSize.Location = New-Object System.Drawing.Size(10,70)
$TB_VSize.Size = New-Object System.Drawing.Size(260,20)
$form.Controls.Add($TB_VSize)
$L_SnapRes = New-Object System.Windows.Forms.Label
$L_SnapRes.Location = New-Object System.Drawing.Size(10,90)
$L_SnapRes.Size = New-Object System.Drawing.Size(280,20)
$L_SnapRes.Text = "What % of the vol should be reserved for SnapShots?"
$form.Controls.Add($L_SnapRes)
$TB_SnapRes = New-Object System.Windows.Forms.TextBox
$TB_SnapRes.Location = New-Object System.Drawing.Size(10,110)
$TB_SnapRes.Size = New-Object System.Drawing.Size(260,20)
$TB_SnapRes.Text="0"
$form.Controls.Add($TB_SnapRes)
$L_SnapSched = New-Object System.Windows.Forms.Label
$L_SnapSched.Location = New-Object System.Drawing.Size(10,130)
$L_SnapSched.Size = New-Object System.Drawing.Size(280,20)
$L_SnapSched.Text = "How many SnapShots do you want to keep?"
$form.Controls.Add($L_SnapSched)
$L_SnapW = New-Object System.Windows.Forms.Label
$L_SnapW.Location = New-Object System.Drawing.Size(10,152)
$L_SnapW.Size = New-Object System.Drawing.Size(46,20)
$L_SnapW.Text = "Weekly:"
$form.Controls.Add($L_SnapW)
$TB_SnapW = New-Object System.Windows.Forms.TextBox
$TB_SnapW.Location = New-Object System.Drawing.Size(56,150)
$TB_SnapW.Size = New-Object System.Drawing.Size(25,20)
$TB_SnapW.Text="0"
$form.Controls.Add($TB_SnapW)
$L_SnapN = New-Object System.Windows.Forms.Label
$L_SnapN.Location = New-Object System.Drawing.Size(100,152)
$L_SnapN.Size = New-Object System.Drawing.Size(45,20)
$L_SnapN.Text = "Nightly:"
$form.Controls.Add($L_SnapN)
$TB_SnapN = New-Object System.Windows.Forms.TextBox
$TB_SnapN.Location = New-Object System.Drawing.Size(145,150)
$TB_SnapN.Size = New-Object System.Drawing.Size(25,20)
$TB_SnapN.Text="0"
$form.Controls.Add($TB_SnapN)
$L_SnapH = New-Object System.Windows.Forms.Label
$L_SnapH.Location = New-Object System.Drawing.Size(185,152)
$L_SnapH.Size = New-Object System.Drawing.Size(45,20)
$L_SnapH.Text = "Hourly:"
$form.Controls.Add($L_SnapH)
$TB_SnapH = New-Object System.Windows.Forms.TextBox
$TB_SnapH.Location = New-Object System.Drawing.Size(230,150)
$TB_SnapH.Size = New-Object System.Drawing.Size(25,20)
$TB_SnapH.Text="8"
$form.Controls.Add($TB_SnapH)
$L_Export = New-Object System.Windows.Forms.Label
$L_Export.Location = New-Object System.Drawing.Size(10,180)
$L_Export.Size = New-Object System.Drawing.Size(120,20)
$L_Export.Text = "Create NFS Export?"
$form.Controls.Add($L_Export)
$L_YesExp = New-Object System.Windows.Forms.Label
$L_YesExp.Location = New-Object System.Drawing.Size(165,180)
$L_YesExp.Size = New-Object System.Drawing.Size(30,20)
$L_YesExp.Text = "Yes"
$form.Controls.Add($L_YesExp)
$C_YesExp = New-Object System.Windows.Forms.CheckBox
$C_YesExp.Location = New-Object System.Drawing.Size(195,178)
$C_YesExp.Size = New-Object System.Drawing.Size(20,20)
$C_YesExp.UseVisualStyleBackColor = $True
$C_YesExp.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_YesExp)
$L_NoExp = New-Object System.Windows.Forms.Label
$L_NoExp.Location = New-Object System.Drawing.Size(220,180)
$L_NoExp.Size = New-Object System.Drawing.Size(30,20)
$L_NoExp.Text = "No"
$form.Controls.Add($L_NoExp)
$C_NoExp = New-Object System.Windows.Forms.CheckBox
$C_NoExp.Location = New-Object System.Drawing.Size(250,178)
$C_NoExp.Size = New-Object System.Drawing.Size(20,20)
$C_NoExp.UseVisualStyleBackColor = $True
$C_NoExp.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_NoExp)
$L_Asis = New-Object System.Windows.Forms.Label
$L_Asis.Location = New-Object System.Drawing.Size(10,200)
$L_Asis.Size = New-Object System.Drawing.Size(140,20)
$L_Asis.Text = "Enable Storage Efficiency?"
$form.Controls.Add($L_Asis)
$L_YesAsis = New-Object System.Windows.Forms.Label
$L_YesAsis.Location = New-Object System.Drawing.Size(165,200)
$L_YesAsis.Size = New-Object System.Drawing.Size(30,20)
$L_YesAsis.Text = "Yes"
$form.Controls.Add($L_YesAsis)
$C_YesAsis = New-Object System.Windows.Forms.CheckBox
$C_YesAsis.Location = New-Object System.Drawing.Size(195,198)
$C_YesAsis.Size = New-Object System.Drawing.Size(20,20)
$C_YesAsis.UseVisualStyleBackColor = $True
$C_YesAsis.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_YesAsis)
$L_NoAsis = New-Object System.Windows.Forms.Label
$L_NoAsis.Location = New-Object System.Drawing.Size(220,200)
$L_NoAsis.Size = New-Object System.Drawing.Size(30,20)
$L_NoAsis.Text = "No"
$form.Controls.Add($L_NoAsis)
$C_NoAsis = New-Object System.Windows.Forms.CheckBox
$C_NoAsis.Location = New-Object System.Drawing.Size(250,198)
$C_NoAsis.Size = New-Object System.Drawing.Size(20,20)
$C_NoAsis.UseVisualStyleBackColor = $True
$C_NoAsis.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_NoAsis)
$OKButton.Location = New-Object System.Drawing.Size(68,230)
$global:vName=$TB_VName.Text;
$global:vSize=$TB_VSize.Text;
$global:snapRes=$TB_SnapRes.Text;
$global:snapW=$TB_SnapW.Text;
$global:snapN=$TB_SnapN.Text;
$global:snapH=$TB_SnapH.Text;
$global:x="0";
If ($C_YesExp.CheckState -eq "1") {$global:YesExp = "1"} Else {$global:YesExp = "0"};
If ($C_YesAsis.CheckState -eq "1") {$global:YesAsis = "1"} Else {$global:YesAsis = "0"};
$form.Close()})
$CancelButton.Location = New-Object System.Drawing.Size(145,230)
$form.Add_KeyDown({if ($_.KeyCode -eq "Enter"){
$global:x="0";
$form.Close()}})
Function ExportNFS () {
# Get which VLANs to export the qtree to
$form.Text = "NFS Export Details"
$form.Size = New-Object System.Drawing.Size(270,220)
$L_exports = New-Object System.Windows.Forms.Label
$L_exports.Location = New-Object System.Drawing.Point(0,10)
$L_exports.Size = New-Object System.Drawing.Size(250,20)
$L_exports.TextAlign = 2
$L_exports.Text = "What VLANs do you want to export to?"
$form.Controls.Add($L_exports)
$C_Irv = New-Object System.Windows.Forms.CheckBox
$C_Irv.Location = New-Object System.Drawing.Point(50,30)
$C_Irv.Size = New-Object System.Drawing.Size(125,20)
$C_Irv.UseVisualStyleBackColor = $True
$C_Irv.Text = "DC1 (110, 128)"
$form.Controls.Add($C_Irv)
$C_HQ = New-Object System.Windows.Forms.CheckBox
$C_HQ.Location = New-Object System.Drawing.Point(50,50)
$C_HQ.Size = New-Object System.Drawing.Size(125,20)
$C_HQ.UseVisualStyleBackColor = $True
$C_HQ.Text = "DC2 (128, 162)"
$form.Controls.Add($C_HQ)
$C_V = New-Object System.Windows.Forms.CheckBox
$C_V.Location = New-Object System.Drawing.Point(50,70)
$C_V.Size = New-Object System.Drawing.Size(125,20)
$C_V.UseVisualStyleBackColor = $True
$C_V.Text = "View (110, 128)"
$form.Controls.Add($C_V)
$L_VC = New-Object System.Windows.Forms.Label
$L_VC.Location = New-Object System.Drawing.Point(0,100)
$L_VC.Size = New-Object System.Drawing.Size(250,20)
$L_VC.TextAlign = 2
$L_VC.Text = "Automatically add to ESX Hosts?"
$form.Controls.Add($L_VC)
$C_YesVC = New-Object System.Windows.Forms.CheckBox
$C_YesVC.Location = New-Object System.Drawing.Point(55,120)
$C_YesVC.Size = New-Object System.Drawing.Size(50,20)
$C_YesVC.UseVisualStyleBackColor = $True
$C_YesVC.Name = "YesVC"
$C_YesVC.Text = "Yes"
$C_YesVC.CheckState = 1
$form.Controls.Add($C_YesVC)
$C_NoVC = New-Object System.Windows.Forms.CheckBox
$C_NoVC.Location = New-Object System.Drawing.Point(160,120)
$C_NoVC.Size = New-Object System.Drawing.Size(40,20)
$C_NoVC.UseVisualStyleBackColor = $True
$C_NoVC.Name = "NoVC"
$C_NoVC.Text = "No"
$form.Controls.Add($C_NoVC)
$OKButton.Location = New-Object System.Drawing.Point(55,145)
If ($C_Irv.CheckState -eq "1") {$global:Irv = "1"} Else {$global:Irv = "0"};
If ($C_HQ.CheckState -eq "1") {$global:HQ = "1"} Else {$global:HQ = "0"};
If ($C_V.CheckState -eq "1") {$global:V = "1"} Else {$global:V = "0"};
If ($C_YesVC.CheckState -eq "1") {$global:ExpVC = "1"} Else {$global:ExpVC = "0"};
$CancelButton.Location = New-Object System.Drawing.Size(130,145)
$CancelButton.Add_Click({$global:x="0";$form.Close()})
Function Export_CheckChanged{
# Don't allow both yes and no checkboxes to be selected
Param([object]$Sender, [System.EventArgs]$Arguments)
If ($Sender.Name -eq "YesVC" -and $Sender.Checked){
$C_NoVC.Checked = $False
$C_NoVC.Enabled = $False
ElseIf ($Sender.Name -eq "NoVC" -and $Sender.Checked){
$C_YesVC.Checked = $False
$C_YesVC.Enabled = $False
Else{
$C_YesVC.Enabled = $true
$C_NoVC.Enabled = $true
$C_YesVC.Add_CheckedChanged({Export_CheckChanged $this $_})
$C_NoVC.Add_CheckedChanged({Export_CheckChanged $this $_})
$form.Add_KeyDown({if ($_.KeyCode -eq "Enter") {
Function Get_SnapHours (){
$form.Text = "Snapshot Details"
$form.Size = New-Object System.Drawing.Size(270,275)
$L_Hours = New-Object System.Windows.Forms.Label
$L_Hours.Location = New-Object System.Drawing.Point(0,20)
$L_Hours.Size = New-Object System.Drawing.Size(260,20)
$L_Hours.TextAlign = 2
$L_Hours.Text = "On what hours should snapshots be taken?"
$form.Controls.Add($L_Hours)
$L_am = New-Object System.Windows.Forms.Label
$L_am.Location = New-Object System.Drawing.Point(53,40)
$L_am.Size = New-Object System.Drawing.Size(40,20)
$L_am.Text = "AM"
$form.Controls.Add($L_am)
$L_pm = New-Object System.Windows.Forms.Label
$L_pm.Location = New-Object System.Drawing.Point(178,40)
$L_pm.Size = New-Object System.Drawing.Size(40,20)
$L_pm.Text = "PM"
$form.Controls.Add($L_pm)
$C_12a = New-Object System.Windows.Forms.CheckBox
$C_12a.Location = New-Object System.Drawing.Point(20,58)
$C_12a.Size = New-Object System.Drawing.Size(40,20)
$C_12a.UseVisualStyleBackColor = $True
$C_12a.Text = "12"
$form.Controls.Add($C_12a)
$C_6a = New-Object System.Windows.Forms.CheckBox
$C_6a.Location = New-Object System.Drawing.Point(80,58)
$C_6a.Size = New-Object System.Drawing.Size(40,20)
$C_6a.UseVisualStyleBackColor = $True
$C_6a.Text = "6"
$form.Controls.Add($C_6a)
$C_12p = New-Object System.Windows.Forms.CheckBox
$C_12p.Location = New-Object System.Drawing.Point(150,58)
$C_12p.Size = New-Object System.Drawing.Size(40,20)
$C_12p.UseVisualStyleBackColor = $True
$C_12p.Text = "12"
$form.Controls.Add($C_12p)
$C_6p = New-Object System.Windows.Forms.CheckBox
$C_6p.Location = New-Object System.Drawing.Point(200,58)
$C_6p.Size = New-Object System.Drawing.Size(40,20)
$C_6p.UseVisualStyleBackColor = $True
$C_6p.Text = "6"
$form.Controls.Add($C_6p)
$C_1a = New-Object System.Windows.Forms.CheckBox
$C_1a.Location = New-Object System.Drawing.Point(20,78)
$C_1a.Size = New-Object System.Drawing.Size(40,20)
$C_1a.UseVisualStyleBackColor = $True
$C_1a.Text = "1"
$form.Controls.Add($C_1a)
$C_7a = New-Object System.Windows.Forms.CheckBox
$C_7a.Location = New-Object System.Drawing.Point(80,78)
$C_7a.Size = New-Object System.Drawing.Size(40,20)
$C_7a.UseVisualStyleBackColor = $True
$C_7a.Text = "7"
$form.Controls.Add($C_7a)
$C_1p = New-Object System.Windows.Forms.CheckBox
$C_1p.Location = New-Object System.Drawing.Point(150,78)
$C_1p.Size = New-Object System.Drawing.Size(40,20)
$C_1p.UseVisualStyleBackColor = $True
$C_1p.Text = "1"
$form.Controls.Add($C_1p)
$C_7p = New-Object System.Windows.Forms.CheckBox
$C_7p.Location = New-Object System.Drawing.Point(200,78)
$C_7p.Size = New-Object System.Drawing.Size(40,20)
$C_7p.UseVisualStyleBackColor = $True
$C_7p.Text = "7"
$form.Controls.Add($C_7p)
$C_2a = New-Object System.Windows.Forms.CheckBox
$C_2a.Location = New-Object System.Drawing.Point(20,98)
$C_2a.Size = New-Object System.Drawing.Size(40,20)
$C_2a.UseVisualStyleBackColor = $True
$C_2a.Text = "2"
$form.Controls.Add($C_2a)
$C_8a = New-Object System.Windows.Forms.CheckBox
$C_8a.Location = New-Object System.Drawing.Point(80,98)
$C_8a.Size = New-Object System.Drawing.Size(40,20)
$C_8a.UseVisualStyleBackColor = $True
$C_8a.Text = "8"
$form.Controls.Add($C_8a)
$C_2p = New-Object System.Windows.Forms.CheckBox
$C_2p.Location = New-Object System.Drawing.Point(150,98)
$C_2p.Size = New-Object System.Drawing.Size(40,20)
$C_2p.UseVisualStyleBackColor = $True
$C_2p.Text = "2"
$form.Controls.Add($C_2p)
$C_8p = New-Object System.Windows.Forms.CheckBox
$C_8p.Location = New-Object System.Drawing.Point(200,98)
$C_8p.Size = New-Object System.Drawing.Size(40,20)
$C_8p.UseVisualStyleBackColor = $True
$C_8p.Text = "8"
$form.Controls.Add($C_8p)
$C_3a = New-Object System.Windows.Forms.CheckBox
$C_3a.Location = New-Object System.Drawing.Point(20,118)
$C_3a.Size = New-Object System.Drawing.Size(40,20)
$C_3a.UseVisualStyleBackColor = $True
$C_3a.Text = "3"
$form.Controls.Add($C_3a)
$C_9a = New-Object System.Windows.Forms.CheckBox
$C_9a.Location = New-Object System.Drawing.Point(80,118)
$C_9a.Size = New-Object System.Drawing.Size(40,20)
$C_9a.UseVisualStyleBackColor = $True
$C_9a.Text = "9"
$form.Controls.Add($C_9a)
$C_3p = New-Object System.Windows.Forms.CheckBox
$C_3p.Location = New-Object System.Drawing.Point(150,118)
$C_3p.Size = New-Object System.Drawing.Size(40,20)
$C_3p.UseVisualStyleBackColor = $True
$C_3p.Text = "3"
$form.Controls.Add($C_3p)
$C_9p = New-Object System.Windows.Forms.CheckBox
$C_9p.Location = New-Object System.Drawing.Point(200,118)
$C_9p.Size = New-Object System.Drawing.Size(40,20)
$C_9p.UseVisualStyleBackColor = $True
$C_9p.Text = "9"
$form.Controls.Add($C_9p)
$C_4a = New-Object System.Windows.Forms.CheckBox
$C_4a.Location = New-Object System.Drawing.Point(20,138)
$C_4a.Size = New-Object System.Drawing.Size(40,20)
$C_4a.UseVisualStyleBackColor = $True
$C_4a.Text = "4"
$form.Controls.Add($C_4a)
$C_10a = New-Object System.Windows.Forms.CheckBox
$C_10a.Location = New-Object System.Drawing.Point(80,138)
$C_10a.Size = New-Object System.Drawing.Size(40,20)
$C_10a.UseVisualStyleBackColor = $True
$C_10a.Text = "10"
$form.Controls.Add($C_10a)
$C_4p = New-Object System.Windows.Forms.CheckBox
$C_4p.Location = New-Object System.Drawing.Point(150,138)
$C_4p.Size = New-Object System.Drawing.Size(40,20)
$C_4p.UseVisualStyleBackColor = $True
$C_4p.Text = "4"
$form.Controls.Add($C_4p)
$C_10p = New-Object System.Windows.Forms.CheckBox
$C_10p.Location = New-Object System.Drawing.Point(200,138)
$C_10p.Size = New-Object System.Drawing.Size(40,20)
$C_10p.UseVisualStyleBackColor = $True
$C_10p.Text = "10"
$form.Controls.Add($C_10p)
$C_5a = New-Object System.Windows.Forms.CheckBox
$C_5a.Location = New-Object System.Drawing.Point(20,158)
$C_5a.Size = New-Object System.Drawing.Size(40,20)
$C_5a.UseVisualStyleBackColor = $True
$C_5a.Text = "5"
$form.Controls.Add($C_5a)
$C_11a = New-Object System.Windows.Forms.CheckBox
$C_11a.Location = New-Object System.Drawing.Point(80,158)
$C_11a.Size = New-Object System.Drawing.Size(40,20)
$C_11a.UseVisualStyleBackColor = $True
$C_11a.Text = "11"
$form.Controls.Add($C_11a)
$C_5p = New-Object System.Windows.Forms.CheckBox
$C_5p.Location = New-Object System.Drawing.Point(150,158)
$C_5p.Size = New-Object System.Drawing.Size(40,20)
$C_5p.UseVisualStyleBackColor = $True
$C_5p.Text = "5"
$form.Controls.Add($C_5p)
$C_11p = New-Object System.Windows.Forms.CheckBox
$C_11p.Location = New-Object System.Drawing.Point(200,158)
$C_11p.Size = New-Object System.Drawing.Size(40,20)
$C_11p.UseVisualStyleBackColor = $True
$C_11p.Text = "11"
$form.Controls.Add($C_11p)
$OKButton.Location = New-Object System.Drawing.Point(55,200)
If ($C_12a.CheckState -eq "1") {$h12a = "0";$global:sourceSnapH = "0"} Else {$h12a = ""};
If ($C_1a.CheckState -eq "1") {$h1a = "1";$global:sourceSnapH = "1"} Else {$h1a = ""};
If ($C_2a.CheckState -eq "1") {$h2a = "2";$global:sourceSnapH = "2"} Else {$h2a = ""};
If ($C_3a.CheckState -eq "1") {$h3a = "3";$global:sourceSnapH = "3"} Else {$h3a = ""};
If ($C_4a.CheckState -eq "1") {$h4a = "4";$global:sourceSnapH = "4"} Else {$h4a = ""};
If ($C_5a.CheckState -eq "1") {$h5a = "5";$global:sourceSnapH = "5"} Else {$h5a = ""};
If ($C_6a.CheckState -eq "1") {$h6a = "6";$global:sourceSnapH = "6"} Else {$h6a = ""};
If ($C_7a.CheckState -eq "1") {$h7a = "7";$global:sourceSnapH = "7"} Else {$h7a = ""};
If ($C_8a.CheckState -eq "1") {$h8a = "8";$global:sourceSnapH = "8"} Else {$h8a = ""};
If ($C_9a.CheckState -eq "1") {$h9a = "9";$global:sourceSnapH = "9"} Else {$h9a = ""};
If ($C_10a.CheckState -eq "1") {$h10a = "10";$global:sourceSnapH = "10"} Else {$h10a = ""};
If ($C_11a.CheckState -eq "1") {$h11a = "11";$global:sourceSnapH = "11"} Else {$h11a = ""};
If ($C_12p.CheckState -eq "1") {$h12p = "12";$global:sourceSnapH = "12"} Else {$h12p = ""};
If ($C_1p.CheckState -eq "1") {$h1p = "13";$sglobal:ourceSnapH = "13"} Else {$h1p = ""};
If ($C_2p.CheckState -eq "1") {$h2p = "14";$global:sourceSnapH = "14"} Else {$h2p = ""};
If ($C_3p.CheckState -eq "1") {$h3p = "15";$global:sourceSnapH = "15"} Else {$h3p = ""};
If ($C_4p.CheckState -eq "1") {$h4p = "16";$global:sourceSnapH = "16"} Else {$h4p = ""};
If ($C_5p.CheckState -eq "1") {$h5p = "17";$global:sourceSnapH = "17"} Else {$h5p = ""};
If ($C_6p.CheckState -eq "1") {$h6p = "18";$global:sourceSnapH = "18"} Else {$h6p = ""};
If ($C_7p.CheckState -eq "1") {$h7p = "19";$global:sourceSnapH = "19"} Else {$h7p = ""};
If ($C_8p.CheckState -eq "1") {$h8p = "20";$global:sourceSnapH = "20"} Else {$h8p = ""};
If ($C_9p.CheckState -eq "1") {$h9p = "21";$global:sourceSnapH = "21"} Else {$h9p = ""};
If ($C_10p.CheckState -eq "1") {$h10p = "22";$global:sourceSnapH = "22"} Else {$h10p = ""};
If ($C_11p.CheckState -eq "1") {$h11p = "23";$global:sourceSnapH = "23"} Else {$h11p = ""};
$CancelButton.Location = New-Object System.Drawing.Point(130,200)
If ($h12a -ne "") {$h12a += ","}
If ($h1a -ne "") {$h1a += ","}
If ($h2a -ne "") {$h2a += ","}
If ($h3a -ne "") {$h3a += ","}
If ($h4a -ne "") {$h4a += ","}
If ($h5a -ne "") {$h5a += ","}
If ($h6a -ne "") {$h6a += ","}
If ($h7a -ne "") {$h7a += ","}
If ($h8a -ne "") {$h8a += ","}
If ($h9a -ne "") {$h9a += ","}
If ($h10a -ne "") {$h10a += ","}
If ($h11a -ne "") {$h11a += ","}
If ($h12p -ne "") {$h12p += ","}
If ($h1p -ne "") {$h1p += ","}
If ($h2p -ne "") {$h2p += ","}
If ($h3p -ne "") {$h3p += ","}
If ($h4p -ne "") {$h4p += ","}
If ($h5p -ne "") {$h5p += ","}
If ($h6p -ne "") {$h6p += ","}
If ($h7p -ne "") {$h7p += ","}
If ($h8p -ne "") {$h8p += ","}
If ($h9p -ne "") {$h9p += ","}
If ($h10p -ne "") {$h10p += ","}
$snapHours1 = $h12a+$h1a+$h2a+$h3a+$h4a+$h5a+$h6a+$h7a+$h8a+$h9a+$h10a+$h11a+$h12p+$h1p+$h2p+$h3p+$h4p+$h5p+$h6p+$h7p+$h8p+$h9p+$h10p+$h11p
If ($snapHours1.substring((($snapHours1.length) -1), 1) -eq ",") {$global:snapHours = $snapHours1.substring(0,(($snapHours1.length) -1))} Else {$global:snapHours=$snapHours1}
Function Get_Asis () {
$form.Text = "ASIS Details"
$L_Hours.Location = New-Object System.Drawing.Point(0,10)
$L_Hours.Size = New-Object System.Drawing.Size(260,30)
$L_Hours.Text = "On what hour should Storage Efficiency run?`n(this should be after hours)"
$L_am.Text = "AM"
$L_pm.Text = "PM"
$C_12a.Text = "12"
$C_6a.Text = "6"
$C_12p.Text = "12"
$C_6p.Text = "6"
$C_1a.Text = "1"
$C_7a.Text = "7"
$C_1p.Text = "1"
$C_7p.Text = "7"
$C_2a.Text = "2"
$C_8a.Text = "8"
$C_2p.Text = "2"
$C_8p.Text = "8"
$C_3a.Text = "3"
$C_9a.Text = "9"
$C_3p.Text = "3"
$C_9p.Text = "9"
$C_4a.Text = "4"
$C_10a.Text = "10"
$C_4p.Text = "4"
$C_10p.Text = "10"
$C_5a.Text = "5"
$C_11a.Text = "11"
$C_5p.Text = "5"
$C_11p.Text = "11"
If ($C_12a.CheckState -eq "1") {$h12a = "0";$global:sourceASISH = "0"} Else {$h12a = ""};
If ($C_1a.CheckState -eq "1") {$h1a = "1";$global:sourceASISH = "1"} Else {$h1a = ""};
If ($C_2a.CheckState -eq "1") {$h2a = "2";$global:sourceASISH = "2"} Else {$h2a = ""};
If ($C_3a.CheckState -eq "1") {$h3a = "3";$global:sourceASISH = "3"} Else {$h3a = ""};
If ($C_4a.CheckState -eq "1") {$h4a = "4";$global:sourceASISH = "4"} Else {$h4a = ""};
If ($C_5a.CheckState -eq "1") {$h5a = "5";$global:sourceASISH = "5"} Else {$h5a = ""};
If ($C_6a.CheckState -eq "1") {$h6a = "6";$global:sourceASISH = "6"} Else {$h6a = ""};
If ($C_7a.CheckState -eq "1") {$h7a = "7";$global:sourceASISH = "7"} Else {$h7a = ""};
If ($C_8a.CheckState -eq "1") {$h8a = "8";$global:sourceASISH = "8"} Else {$h8a = ""};
If ($C_9a.CheckState -eq "1") {$h9a = "9";$global:sourceASISH = "9"} Else {$h9a = ""};
If ($C_10a.CheckState -eq "1") {$h10a = "10";$global:sourceASISH = "10"} Else {$h10a = ""};
If ($C_11a.CheckState -eq "1") {$h11a = "11";$global:sourceASISH = "11"} Else {$h11a = ""};
If ($C_12p.CheckState -eq "1") {$h12p = "12";$global:sourceASISH = "12"} Else {$h12p = ""};
If ($C_2p.CheckState -eq "1") {$h2p = "14";$global:sourceASISH = "14"} Else {$h2p = ""};
If ($C_3p.CheckState -eq "1") {$h3p = "15";$global:sourceASISH = "15"} Else {$h3p = ""};
If ($C_4p.CheckState -eq "1") {$h4p = "16";$global:sourceASISH = "16"} Else {$h4p = ""};
If ($C_5p.CheckState -eq "1") {$h5p = "17";$global:sourceASISH = "17"} Else {$h5p = ""};
If ($C_6p.CheckState -eq "1") {$h6p = "18";$global:sourceASISH = "18"} Else {$h6p = ""};
If ($C_7p.CheckState -eq "1") {$h7p = "19";$global:sourceASISH = "19"} Else {$h7p = ""};
If ($C_8p.CheckState -eq "1") {$h8p = "20";$global:sourceASISH = "20"} Else {$h8p = ""};
If ($C_9p.CheckState -eq "1") {$h9p = "21";$global:sourceASISH = "21"} Else {$h9p = ""};
If ($C_10p.CheckState -eq "1") {$h10p = "22";$global:sourceASISH = "22"} Else {$h10p = ""};
If ($C_11p.CheckState -eq "1") {$h11p = "23";$global:sourceASISH = "23"} Else {$h11p = ""};
If ($h11p -ne "") {$h11p += ","}
$asisHours1 = $h12a+$h1a+$h2a+$h3a+$h4a+$h5a+$h6a+$h7a+$h8a+$h9a+$h10a+$h11a+$h12p+$h1p+$h2p+$h3p+$h4p+$h5p+$h6p+$h7p+$h8p+$h9p+$h10p+$h11p
If ($asisHours1.substring((($asisHours1.length) -1), 1) -eq ",") {$global:asisHours = $asisHours1.substring(0,(($asisHours1.length) -1))} Else {$global:asisHours=$asisHours1}
Function ExportESX ($MyDC,$vName,$path,$NFShost) {
# Get all hosts in selected location and add NFS datastore to them
$VC_DC = $MyDC
If ($VC_DC -eq "DC1") {
$vcen = Connect-VIServer "vcen01" | Out-Null
$ESXhosts = Get-VMHost -Location "DC1" | Select Name | ForEach {$_.Name}
ForEach ($esx in $ESXhosts) {
New-Datastore -VMHost $esx -Nfs -Name $vName -Path $path -NfsHost $NFShost | Out-Null
If ($VC_DC -eq "DC2") {
$vcen = Connect-VIServer "vcen02" | Out-Null
$ESXhosts = Get-VMHost -Location "DC2" | Select Name | ForEach {$_.Name}
If ($VC_DC -eq "View") {
$vcen = Connect-VIServer "vcen03" | Out-Null
$ESXhosts = Get-VMHost -Location "View" | Select Name | ForEach {$_.Name}
Function NoNFS ($MyFiler) {
$form.Text = "No NFS IP"
$form.Size = New-Object System.Drawing.Size(240,120)
$Label = New-Object System.Windows.Forms.Label
$Label.Location = New-Object System.Drawing.Size(0,10)
$Label.Size = New-Object System.Drawing.Size(225,40)
$Label.TextAlign = 2
$Label.Text = "Unable to find NFS IP for $MyFiler`nExport was not added to ESX hosts!"
$form.Controls.Add($Label)
$OKButton.Location = New-Object System.Drawing.Size(75,50)
$OKButton.Size = New-Object System.Drawing.Size(75,25)
$OKButton.Add_Click({$global:x="0";$form.Close()})
Function Select_DRFiler ($DR_filers) {
$L_Filer.Text = "What Filer do you want to create the backup volume on?"
foreach ($Filer in $DR_filers) {$CB_Filer.Items.Add($Filer)}
$OKButton.Add_Click({$global:MyDRFiler=($CB_Filer.SelectedItem.ToLower()).ToString();$global:x="1";$form.Close()})
{$global:MyDRFiler=($CB_Filer.SelectedItem.ToLower()).ToString();$global:x="1";$form.Close()}})
Function Select_DRAggr ($dr_aggr1, $dr_aggrs) {
#Variables
$agrList = $dr_aggr1
$agrList1=$dr_aggrs
#Definitions
#tlp_MainTable
$tlp_MainTable.Controls.Add($OKButton, 1, 2)
#gb_SelectAggr
$gb_SelectAggr.TabStop = $False
$gb_SelectAggr.Text = "Select Aggregate To Create The DR Volume On"
#$cb_Aggr
$cb_Aggr.AutoSize = $True
#gb_AggrList
$gb_AggrList.TabStop = $False
#tb_Aggrs
#OKButton
$OKButton.Add_Click({$global:MyDRAggr=($cb_Aggr.SelectedItem.ToLower()).ToString();$global:x="1";$form.Close()})
#CancelButton
#Form
$form.Name = "Form"
#Final Layout
{$global:MyDRAggr=$cb_Aggr.SelectedItem.ToString();$global:x="1";$form.Close()}})
$tlp_MainTable.ResumeLayout($False)
$gb_SelectAggr.ResumeLayout($False)
$gb_AggrList.ResumeLayout($False)
$form.ResumeLayout($False)
Function DRVol_Details ($vName,[int]$drVsize,$DRblock){
# Get DR volume details
$drVname = "sm_"+$vName
$drVsize *= "1.05"
$form.Text = "DR Volume Details"
$form.Size = New-Object System.Drawing.Size(320,290)
$L_VName.Size = New-Object System.Drawing.Size(300,20)
$L_VName.Text = "What name do you want to give to the DR volume?"
$TB_VName.Size = New-Object System.Drawing.Size(285,20)
$TB_VName.Text = $drVname
$L_VSize.Location = New-Object System.Drawing.Size(10,57)
$L_VSize.Size = New-Object System.Drawing.Size(300,20)
$TB_VSize.Location = New-Object System.Drawing.Size(10,77)
$TB_VSize.Size = New-Object System.Drawing.Size(285,20)
$TB_VSize.Text = $drVsize
$L_SnapSched.Location = New-Object System.Drawing.Size(10,100)
$L_SnapSched.Size = New-Object System.Drawing.Size(300,20)
$L_SnapW.Location = New-Object System.Drawing.Size(10,122)
$TB_SnapW.Location = New-Object System.Drawing.Size(56,120)
$TB_SnapW.Text = "0"
$L_SnapN.Location = New-Object System.Drawing.Size(120,122)
$TB_SnapN.Location = New-Object System.Drawing.Size(165,120)
$TB_SnapN.Text = "0"
$L_SnapH.Location = New-Object System.Drawing.Size(225,122)
$TB_SnapH.Location = New-Object System.Drawing.Size(270,120)
$TB_SnapH.Text = "30"
$L_Asis.Location = New-Object System.Drawing.Size(10,145)
$L_YesAsis.Location = New-Object System.Drawing.Size(195,145)
$C_YesAsis.Location = New-Object System.Drawing.Size(225,142)
$C_YesAsis.CheckState ="1"
$L_NoAsis.Location = New-Object System.Drawing.Size(250,145)
$C_NoAsis.Location = New-Object System.Drawing.Size(280,142)
#if aggr is 64-bit give option to enable compression
If ($DRblock -eq "64_bit") {
$L_Comp = New-Object System.Windows.Forms.Label
$L_Comp.Location = New-Object System.Drawing.Size(10,165)
$L_Comp.Size = New-Object System.Drawing.Size(140,20)
$L_Comp.Text = "Enable Compression?"
$form.Controls.Add($L_Comp)
$L_YesComp = New-Object System.Windows.Forms.Label
$L_YesComp.Location = New-Object System.Drawing.Size(195,165)
$L_YesComp.Size = New-Object System.Drawing.Size(30,20)
$L_YesComp.Text = "Yes"
$form.Controls.Add($L_YesComp)
$C_YesComp = New-Object System.Windows.Forms.CheckBox
$C_YesComp.Location = New-Object System.Drawing.Size(225,162)
$C_YesComp.Size = New-Object System.Drawing.Size(20,20)
$C_YesComp.CheckState ="1"
$C_YesComp.UseVisualStyleBackColor = $True
$C_YesComp.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_YesComp)
$L_NoComp = New-Object System.Windows.Forms.Label
$L_NoComp.Location = New-Object System.Drawing.Size(250,165)
$L_NoComp.Size = New-Object System.Drawing.Size(30,20)
$L_NoComp.Text = "No"
$form.Controls.Add($L_NoComp)
$C_NoComp = New-Object System.Windows.Forms.CheckBox
$C_NoComp.Location = New-Object System.Drawing.Size(280,162)
$C_NoComp.Size = New-Object System.Drawing.Size(20,20)
$C_NoComp.UseVisualStyleBackColor = $True
$C_NoComp.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_NoComp)
$L_InL = New-Object System.Windows.Forms.Label
$L_InL.Location = New-Object System.Drawing.Size(10,185)
$L_InL.Size = New-Object System.Drawing.Size(170,20)
$L_InL.Text = "Enable InLine Compression?"
$form.Controls.Add($L_InL)
$L_YesInL = New-Object System.Windows.Forms.Label
$L_YesInL.Location = New-Object System.Drawing.Size(195,185)
$L_YesInL.Size = New-Object System.Drawing.Size(30,20)
$L_YesInL.Text = "Yes"
$form.Controls.Add($L_YesInL)
$C_YesInL = New-Object System.Windows.Forms.CheckBox
$C_YesInL.Location = New-Object System.Drawing.Size(225,182)
$C_YesInL.Size = New-Object System.Drawing.Size(20,20)
$C_YesInL.CheckState ="1"
$C_YesInL.UseVisualStyleBackColor = $True
$C_YesInL.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_YesInL)
$L_NoInL = New-Object System.Windows.Forms.Label
$L_NoInL.Location = New-Object System.Drawing.Size(250,185)
$L_NoInL.Size = New-Object System.Drawing.Size(30,20)
$L_NoInL.Text = "No"
$form.Controls.Add($L_NoInL)
$C_NoInL = New-Object System.Windows.Forms.CheckBox
$C_NoInL.Location = New-Object System.Drawing.Size(280,182)
$C_NoInL.Size = New-Object System.Drawing.Size(20,20)
$C_NoInL.UseVisualStyleBackColor = $True
$C_NoInL.DataBindings.DefaultDataSourceUpdateMode = 0
$form.Controls.Add($C_NoInL)
$OKButton.Location = New-Object System.Drawing.Size(85,220)
$global:DRvName=$TB_VName.Text;
$global:DRvSize=$TB_VSize.Text;
$global:DRsnapW=$TB_SnapW.Text;
$global:DRsnapN=$TB_SnapN.Text;
$global:DRsnapH=$TB_SnapH.Text;
$global:x="1";
If ($C_YesAsis.CheckState -eq "1") {$global:DRYesAsis = "1"} Else {$global:DRYesAsis = "0"};
If ($C_YesComp.CheckState -eq "1") {$global:DRYesComp = "1"} Else {$global:DRYesComp = "0"};
If ($C_YesInL.CheckState -eq "1") {$global:DRYesInL = "1"} Else {$global:DRYesInL = "0"};
$form.Close()})
$CancelButton.Location = New-Object System.Drawing.Size(160,220)
$global:x="1";
$form.Close()}})
Function Get_DRSnapHours ($sourceSnapH){
#Get snapshot schedule for DR volume
#Set default to 1 hour after mirror
$form.Text = "DR Snapshot Details"
$L_am.Text = "AM"
$L_pm.Text = "PM"
$C_12a.Text = "12"
$C_6a.Text = "6"
$C_12p.Text = "12"
$C_6p.Text = "6"
$C_1a.Text = "1"
$C_7a.Text = "7"
$C_1p.Text = "1"
$C_7p.Text = "7"
$C_2a.Text = "2"
$C_8a.Text = "8"
$C_2p.Text = "2"
$C_8p.Text = "8"
$C_3a.Text = "3"
$C_9a.Text = "9"
$C_3p.Text = "3"
$C_9p.Text = "9"
$C_4a.Text = "4"
$C_10a.Text = "10"
$C_4p.Text = "4"
$C_10p.Text = "10"
$C_5a.Text = "5"
$C_11a.Text = "11"
$C_5p.Text = "5"
$C_11p.Text = "11"
If (($sourceSnapH).Length -gt "0") {
If ($sourceSnapH -eq "22") {$C_12a.CheckState = "1"}
If ($sourceSnapH -eq "23") {$C_1a.CheckState = "1"}
If ($sourceSnapH -eq "0") {$C_2a.CheckState = "1"}
If ($sourceSnapH -eq "1") {$C_3a.CheckState = "1"}
If ($sourceSnapH -eq "2") {$C_4a.CheckState = "1"}
If ($sourceSnapH -eq "3") {$C_5a.CheckState = "1"}
If ($sourceSnapH -eq "4") {$C_6a.CheckState = "1"}
If ($sourceSnapH -eq "5") {$C_7a.CheckState = "1"}
If ($sourceSnapH -eq "6") {$C_8a.CheckState = "1"}
If ($sourceSnapH -eq "7") {$C_9a.CheckState = "1"}
If ($sourceSnapH -eq "8") {$C_10a.CheckState = "1"}
If ($sourceSnapH -eq "9") {$C_11a.CheckState = "1"}
If ($sourceSnapH -eq "10") {$C_12p.CheckState = "1"}
If ($sourceSnapH -eq "11") {$C_1p.CheckState = "1"}
If ($sourceSnapH -eq "12") {$C_2p.CheckState = "1"}
If ($sourceSnapH -eq "13") {$C_3p.CheckState = "1"}
If ($sourceSnapH -eq "14") {$C_4p.CheckState = "1"}
If ($sourceSnapH -eq "15") {$C_5p.CheckState = "1"}
If ($sourceSnapH -eq "16") {$C_6p.CheckState = "1"}
If ($sourceSnapH -eq "17") {$C_7p.CheckState = "1"}
If ($sourceSnapH -eq "18") {$C_8p.CheckState = "1"}
If ($sourceSnapH -eq "19") {$C_9p.CheckState = "1"}
If ($sourceSnapH -eq "20") {$C_10p.CheckState = "1"}
If ($sourceSnapH -eq "21") {$C_11p.CheckState = "1"}
If ($C_12a.CheckState -eq "1") {$DRh12a = "0"} Else {$DRh12a = ""};
If ($C_1a.CheckState -eq "1") {$DRh1a = "1"} Else {$DRh1a = ""};
If ($C_2a.CheckState -eq "1") {$DRh2a = "2"} Else {$DRh2a = ""};
If ($C_3a.CheckState -eq "1") {$DRh3a = "3"} Else {$DRh3a = ""};
If ($C_4a.CheckState -eq "1") {$DRh4a = "4"} Else {$DRh4a = ""};
If ($C_5a.CheckState -eq "1") {$DRh5a = "5"} Else {$DRh5a = ""};
If ($C_6a.CheckState -eq "1") {$DRh6a = "6"} Else {$DRh6a = ""};
If ($C_7a.CheckState -eq "1") {$DRh7a = "7"} Else {$DRh7a = ""};
If ($C_8a.CheckState -eq "1") {$DRh8a = "8"} Else {$DRh8a = ""};
If ($C_9a.CheckState -eq "1") {$DRh9a = "9"} Else {$DRh9a = ""};
If ($C_10a.CheckState -eq "1") {$DRh10a = "10"} Else {$DRh10a = ""};
If ($C_11a.CheckState -eq "1") {$DRh11a = "11"} Else {$DRh11a = ""};
If ($C_12p.CheckState -eq "1") {$DRh12p = "12"} Else {$DRh12p = ""};
If ($C_1p.CheckState -eq "1") {$DRh1p = "13"} Else {$DRh1p = ""};
If ($C_2p.CheckState -eq "1") {$DRh2p = "14"} Else {$DRh2p = ""};
If ($C_3p.CheckState -eq "1") {$DRh3p = "15"} Else {$DRh3p = ""};
If ($C_4p.CheckState -eq "1") {$DRh4p = "16"} Else {$DRh4p = ""};
If ($C_5p.CheckState -eq "1") {$DRh5p = "17"} Else {$DRh5p = ""};
If ($C_6p.CheckState -eq "1") {$DRh6p = "18"} Else {$DRh6p = ""};
If ($C_7p.CheckState -eq "1") {$DRh7p = "19"} Else {$DRh7p = ""};
If ($C_8p.CheckState -eq "1") {$DRh8p = "20"} Else {$DRh8p = ""};
If ($C_9p.CheckState -eq "1") {$DRh9p = "21"} Else {$DRh9p = ""};
If ($C_10p.CheckState -eq "1") {$DRh10p = "22"} Else {$DRh10p = ""};
If ($C_11p.CheckState -eq "1") {$DRh11p = "23"} Else {$DRh11p = ""};
If ($DRh12a -ne "") {$DRh12a += ","}
If ($DRh1a -ne "") {$DRh1a += ","}
If ($DRh2a -ne "") {$DRh2a += ","}
If ($DRh3a -ne "") {$DRh3a += ","}
If ($DRh4a -ne "") {$DRh4a += ","}
If ($DRh5a -ne "") {$DRh5a += ","}
If ($DRh6a -ne "") {$DRh6a += ","}
If ($DRh7a -ne "") {$DRh7a += ","}
If ($DRh8a -ne "") {$DRh8a += ","}
If ($DRh9a -ne "") {$DRh9a += ","}
If ($DRh10a -ne "") {$DRh10a += ","}
If ($DRh11a -ne "") {$DRh11a += ","}
If ($DRh12p -ne "") {$DRh12p += ","}
If ($DRh1p -ne "") {$DRh1p += ","}
If ($DRh2p -ne "") {$DRh2p += ","}
If ($DRh3p -ne "") {$DRh3p += ","}
If ($DRh4p -ne "") {$DRh4p += ","}
If ($DRh5p -ne "") {$DRh5p += ","}
If ($DRh6p -ne "") {$DRh6p += ","}
If ($DRh7p -ne "") {$DRh7p += ","}
If ($DRh8p -ne "") {$DRh8p += ","}
If ($DRh9p -ne "") {$DRh9p += ","}
If ($DRh10p -ne "") {$DRh10p += ","}
$DRsnapHours1 = $DRh12a+$DRh1a+$DRh2a+$DRh3a+$DRh4a+$DRh5a+$DRh6a+$DRh7a+$DRh8a+$DRh9a+$DRh10a+$DRh11a+$DRh12p+$DRh1p+$DRh2p+$DRh3p+$DRh4p+$DRh5p+$DRh6p+$DRh7p+$DRh8p+$DRh9p+$DRh10p+$DRh11p
If ($DRsnapHours1.substring((($DRsnapHours1.length) -1), 1) -eq ",") {$global:DRsnapHours = $DRsnapHours1.substring(0,(($DRsnapHours1.length) -1))} Else {$global:DRsnapHours=$DRsnapHours1}
Function NoSourceSnap () {
# Alert user if no source snapshots
$form.Text = "No Source Snapshots"
$form.Size = New-Object System.Drawing.Size(300,120)
$Label.Size = New-Object System.Drawing.Size(285,40)
$Label.Text = "Snapshots were not configured on source volume.`nThey will not be set on the DR volume!"
$OKButton.Location = New-Object System.Drawing.Size(112,50)
$OKButton.Add_Click({$global:x="1";$form.Close()})
Function Get_DRAsis ($sourceASISH) {
# Get ASIS schedule for DR volume
# Default to same time as source, if source ASIS was enabled
$form.Text = "DR ASIS Details"
$L_am.Text = "AM"
$L_pm.Text = "PM"
$C_12a.Text = "12"
$C_6a.Text = "6"
$C_12p.Text = "12"
$C_6p.Text = "6"
$C_1a.Text = "1"
$C_7a.Text = "7"
$C_1p.Text = "1"
$C_7p.Text = "7"
$C_2a.Text = "2"
$C_8a.Text = "8"
$C_2p.Text = "2"
$C_8p.Text = "8"
$C_3a.Text = "3"
$C_9a.Text = "9"
$C_3p.Text = "3"
$C_9p.Text = "9"
$C_4a.Text = "4"
$C_10a.Text = "10"
$C_4p.Text = "4"
$C_10p.Text = "10"
$C_5a.Text = "5"
$C_11a.Text = "11"
$C_5p.Text = "5"
$C_11p.Text = "11"
If (($sourceASISH).Length -gt "0") {
If ($sourceASISH -eq "0") {$C_12a.CheckState = "1"}
If ($sourceASISH -eq "1") {$C_1a.CheckState = "1"}
If ($sourceASISH -eq "2") {$C_2a.CheckState = "1"}
If ($sourceASISH -eq "3") {$C_3a.CheckState = "1"}
If ($sourceASISH -eq "4") {$C_4a.CheckState = "1"}
If ($sourceASISH -eq "5") {$C_5a.CheckState = "1"}
If ($sourceASISH -eq "6") {$C_6a.CheckState = "1"}
If ($sourceASISH -eq "7") {$C_7a.CheckState = "1"}
If ($sourceASISH -eq "8") {$C_8a.CheckState = "1"}
If ($sourceASISH -eq "9") {$C_9a.CheckState = "1"}
If ($sourceASISH -eq "10") {$C_10a.CheckState = "1"}
If ($sourceASISH -eq "11") {$C_11a.CheckState = "1"}
If ($sourceASISH -eq "12") {$C_12p.CheckState = "1"}
If ($sourceASISH -eq "13") {$C_1p.CheckState = "1"}
If ($sourceASISH -eq "14") {$C_2p.CheckState = "1"}
If ($sourceASISH -eq "15") {$C_3p.CheckState = "1"}
If ($sourceASISH -eq "16") {$C_4p.CheckState = "1"}
If ($sourceASISH -eq "17") {$C_5p.CheckState = "1"}
If ($sourceASISH -eq "18") {$C_6p.CheckState = "1"}
If ($sourceASISH -eq "19") {$C_7p.CheckState = "1"}
If ($sourceASISH -eq "20") {$C_8p.CheckState = "1"}
If ($sourceASISH -eq "21") {$C_9p.CheckState = "1"}
If ($sourceASISH -eq "22") {$C_10p.CheckState = "1"}
If ($sourceASISH -eq "23") {$C_11p.CheckState = "1"}
If ($C_12a.CheckState -eq "1") {$DRh12a1 = "0"} Else {$DRh12a1 = ""};
If ($C_1a.CheckState -eq "1") {$DRh1a1 = "1"} Else {$DRh1a1 = ""};
If ($C_2a.CheckState -eq "1") {$DRh2a1 = "2"} Else {$DRh2a1 = ""};
If ($C_3a.CheckState -eq "1") {$DRh3a1 = "3"} Else {$DRh3a1 = ""};
If ($C_4a.CheckState -eq "1") {$DRh4a1 = "4"} Else {$DRh4a1 = ""};
If ($C_5a.CheckState -eq "1") {$DRh5a1 = "5"} Else {$DRh5a1 = ""};
If ($C_6a.CheckState -eq "1") {$DRh6a1 = "6"} Else {$DRh6a1 = ""};
If ($C_7a.CheckState -eq "1") {$DRh7a1 = "7"} Else {$DRh7a1 = ""};
If ($C_8a.CheckState -eq "1") {$DRh8a1 = "8"} Else {$DRh8a1 = ""};
If ($C_9a.CheckState -eq "1") {$DRh9a1 = "9"} Else {$DRh9a1 = ""};
If ($C_10a.CheckState -eq "1") {$DRh10a1 = "10"} Else {$DRh10a1 = ""};
If ($C_11a.CheckState -eq "1") {$DRh11a1 = "11"} Else {$DRh11a1 = ""};
If ($C_12p.CheckState -eq "1") {$DRh12p1 = "12"} Else {$DRh12p1 = ""};
If ($C_1p.CheckState -eq "1") {$DRh1p1 = "13"} Else {$DRh1p1 = ""};
If ($C_2p.CheckState -eq "1") {$DRh2p1 = "14"} Else {$DRh2p1 = ""};
If ($C_3p.CheckState -eq "1") {$DRh3p1 = "15"} Else {$DRh3p1 = ""};
If ($C_4p.CheckState -eq "1") {$DRh4p1 = "16"} Else {$DRh4p1 = ""};
If ($C_5p.CheckState -eq "1") {$DRh5p1 = "17"} Else {$DRh5p1 = ""};
If ($C_6p.CheckState -eq "1") {$DRh6p1 = "18"} Else {$DRh6p1 = ""};
If ($C_7p.CheckState -eq "1") {$DRh7p1 = "19"} Else {$DRh7p1 = ""};
If ($C_8p.CheckState -eq "1") {$DRh8p1 = "20"} Else {$DRh8p1 = ""};
If ($C_9p.CheckState -eq "1") {$DRh9p1 = "21"} Else {$DRh9p1 = ""};
If ($C_10p.CheckState -eq "1") {$DRh10p1 = "22"} Else {$DRh10p1 = ""};
If ($C_11p.CheckState -eq "1") {$DRh11p1 = "23"} Else {$DRh11p1 = ""};
If ($DRh12a1 -ne "") {$DRh12a1 += ","}
If ($DRh1a1 -ne "") {$DRh1a1 += ","}
If ($DRh2a1 -ne "") {$DRh2a1 += ","}
If ($DRh3a1 -ne "") {$DRh3a1 += ","}
If ($DRh4a1 -ne "") {$DRh4a1 += ","}
If ($DRh5a1 -ne "") {$DRh5a1 += ","}
If ($DRh6a1 -ne "") {$DRh6a1 += ","}
If ($DRh7a1 -ne "") {$DRh7a1 += ","}
If ($DRh8a1 -ne "") {$DRh8a1 += ","}
If ($DRh9a1 -ne "") {$DRh9a1 += ","}
If ($DRh10a1 -ne "") {$DRh10a1 += ","}
If ($DRh11a1 -ne "") {$DRh11a1 += ","}
If ($DRh12p1 -ne "") {$DRh12p1 += ","}
If ($DRh1p1 -ne "") {$DRh1p1 += ","}
If ($DRh2p1 -ne "") {$DRh2p1 += ","}
If ($DRh3p1 -ne "") {$DRh3p1 += ","}
If ($DRh4p1 -ne "") {$DRh4p1 += ","}
If ($DRh5p1 -ne "") {$DRh5p1 += ","}
If ($DRh6p1 -ne "") {$DRh6p1 += ","}
If ($DRh7p1 -ne "") {$DRh7p1 += ","}
If ($DRh8p1 -ne "") {$DRh8p1 += ","}
If ($DRh9p1 -ne "") {$DRh9p1 += ","}
If ($DRh10p1 -ne "") {$DRh10p1 += ","}
If ($DRh11p1 -ne "") {$DRh11p1 += ","}
$DRasisHours1 = $DRh12a1+$DRh1a1+$DRh2a1+$DRh3a1+$DRh4a1+$DRh5a1+$DRh6a1+$DRh7a1+$DRh8a1+$DRh9a1+$DRh10a1+$DRh11a1+$DRh12p1+$DRh1p1+$DRh2p1+$DRh3p1+$DRh4p1+$DRh5p1+$DRh6p1+$DRh7p1+$DRh8p1+$DRh9p1+$DRh10p1+$DRh11p1
If ($DRasisHours1.substring((($DRasisHours1.length) -1), 1) -eq ",") {$global:DRasisHours = $DRasisHours1.substring(0,(($DRasisHours1.length) -1))} Else {$global:DRasisHours=$DRasisHours1}
Function Get_MirrorHour ($sourceSnapH) {
# Get QSM schedule
# Default to 1 hour after source snapshot was taken
$form.Text = "SnapMirror Details"
$L_Hours.Location = New-Object System.Drawing.Size(0,20)
$L_Hours.Text = "On what hour should the SnapMirror run?"
$L_am.Text = "AM"
$L_pm.Text = "PM"
$C_12a.Text = "12"
$C_6a.Text = "6"
$C_12p.Text = "12"
$C_6p.Text = "6"
$C_1a.Text = "1"
$C_7a.Text = "7"
$C_1p.Text = "1"
$C_7p.Text = "7"
$C_2a.Text = "2"
$C_8a.Text = "8"
$C_2p.Text = "2"
$C_8p.Text = "8"
$C_3a.Text = "3"
$C_9a.Text = "9"
$C_3p.Text = "3"
$C_9p.Text = "9"
$C_4a.Text = "4"
$C_10a.Text = "10"
$C_4p.Text = "4"
$C_10p.Text = "10"
$C_5a.Text = "5"
$C_11a.Text = "11"
$C_5p.Text = "5"
$C_11p.Text = "11"
If ($sourceSnapH -eq "23") {$C_12a.CheckState = "1"}
If ($sourceSnapH -eq "0") {$C_1a.CheckState = "1"}
If ($sourceSnapH -eq "1") {$C_2a.CheckState = "1"}
If ($sourceSnapH -eq "2") {$C_3a.CheckState = "1"}
If ($sourceSnapH -eq "3") {$C_4a.CheckState = "1"}
If ($sourceSnapH -eq "4") {$C_5a.CheckState = "1"}
If ($sourceSnapH -eq "5") {$C_6a.CheckState = "1"}
If ($sourceSnapH -eq "6") {$C_7a.CheckState = "1"}
If ($sourceSnapH -eq "7") {$C_8a.CheckState = "1"}
If ($sourceSnapH -eq "8") {$C_9a.CheckState = "1"}
If ($sourceSnapH -eq "9") {$C_10a.CheckState = "1"}
If ($sourceSnapH -eq "10") {$C_11a.CheckState = "1"}
If ($sourceSnapH -eq "11") {$C_12p.CheckState = "1"}
If ($sourceSnapH -eq "12") {$C_1p.CheckState = "1"}
If ($sourceSnapH -eq "13") {$C_2p.CheckState = "1"}
If ($sourceSnapH -eq "14") {$C_3p.CheckState = "1"}
If ($sourceSnapH -eq "15") {$C_4p.CheckState = "1"}
If ($sourceSnapH -eq "16") {$C_5p.CheckState = "1"}
If ($sourceSnapH -eq "17") {$C_6p.CheckState = "1"}
If ($sourceSnapH -eq "18") {$C_7p.CheckState = "1"}
If ($sourceSnapH -eq "19") {$C_8p.CheckState = "1"}
If ($sourceSnapH -eq "20") {$C_9p.CheckState = "1"}
If ($sourceSnapH -eq "21") {$C_10p.CheckState = "1"}
If ($sourceSnapH -eq "22") {$C_11p.CheckState = "1"}
$OKButton.Location = New-Object System.Drawing.Size(55,200)
If ($C_12a.CheckState -eq "1") {$global:MirrorHour = "0"}
If ($C_1a.CheckState -eq "1") {$global:MirrorHour = "1"}
If ($C_2a.CheckState -eq "1") {$global:MirrorHour = "2"}
If ($C_3a.CheckState -eq "1") {$global:MirrorHour = "3"}
If ($C_4a.CheckState -eq "1") {$global:MirrorHour = "4"}
If ($C_5a.CheckState -eq "1") {$global:MirrorHour = "5"}
If ($C_6a.CheckState -eq "1") {$global:MirrorHour = "6"}
If ($C_7a.CheckState -eq "1") {$global:MirrorHour = "7"}
If ($C_8a.CheckState -eq "1") {$global:MirrorHour = "8"}
If ($C_9a.CheckState -eq "1") {$global:MirrorHour = "9"}
If ($C_10a.CheckState -eq "1") {$global:MirrorHour = "10"}
If ($C_11a.CheckState -eq "1") {$global:MirrorHour = "11"}
If ($C_12p.CheckState -eq "1") {$global:MirrorHour = "12"}
If ($C_1p.CheckState -eq "1") {$global:MirrorHour = "13"}
If ($C_2p.CheckState -eq "1") {$global:MirrorHour = "14"}
If ($C_3p.CheckState -eq "1") {$global:MirrorHour = "15"}
If ($C_4p.CheckState -eq "1") {$global:MirrorHour = "16"}
If ($C_5p.CheckState -eq "1") {$global:MirrorHour = "17"}
If ($C_6p.CheckState -eq "1") {$global:MirrorHour = "18"}
If ($C_7p.CheckState -eq "1") {$global:MirrorHour = "19"}
If ($C_8p.CheckState -eq "1") {$global:MirrorHour = "20"}
If ($C_9p.CheckState -eq "1") {$global:MirrorHour = "21"}
If ($C_10p.CheckState -eq "1") {$global:MirrorHour = "22"}
If ($C_11p.CheckState -eq "1") {$global:MirrorHour = "23"}
$CancelButton.Location = New-Object System.Drawing.Size(130,200)
Function Source_Vol_Created () {
# Notify user that source volume creation completed
$form.Text = "Source Vol Created"
$form.Size = New-Object System.Drawing.Size(250,120)
$Label.Location = New-Object System.Drawing.Size(0,20)
$Label.Size = New-Object System.Drawing.Size(240,20)
$Label.Text = "The source volume has been created."
$OKButton.Location = New-Object System.Drawing.Size(88,50)
Function DR_Vol_Created () {
# Notify user that DR volume creation completed
$form.Text = "DR Vol Created"
$Label.Text = "The DR volume has been created."
Function Vol_Aborted () {
# Notify user that script was aborted
$form.Text = "Script Aborted"
$Label.Size = New-Object System.Drawing.Size(230,20)
$Label.Text = "The script was aborted!"
$OKButton.Location = New-Object System.Drawing.Size(82,50)
$OKButton.Add_Click({$form.Close()})
## SCRIPT ##
##SOURCE VOLUME##
# Run the Select_Filer Function to select a Filer to add the volume to
Select_Filer $Filers | Out-Null
# Connect to selected Filer and get Aggregate variables
If ($x -eq "0") {
$filer1 = Connect-NaController $MyFiler
$aggrs = Get-NaAggr
$aggr1 = Get-NaAggr | Select-Object Name, SizeAvailable, SizeTotal, BlockType | Sort SizeAvailable -Descending
# Run the Select_Aggr Function to select the aggregate to create the volume on
If ($x -eq "0") {Select_Aggr $aggr1 $aggrs | Out-Null}
# Run the Vol_Details Function to get the volume name and size
If ($x -eq "0") {Vol_Details | Out-Null}
# If selected, Run ExportNFS Functions to get NFS Export VLANs
If ($x -eq "0") {If ($YesExp -eq "1") {ExportNFS | Out-Null}}
# Append collected volume size with "g"
If ($x -eq "0") {
[int]$vSize1 = $vSize
[int]$drVsize = $vSize
$vSize1 += 200
$vSize += "g"
[string]$vSize2 = $vSize1
$vSize2 += "g"
# Set path for Qtree addition
If ($x -eq "0") {
$path = "/vol/"+$vName+"/"+$vName
$volPath = "/vol/"+$vName
# Set CIFS Share name
If ($x -eq "0") {$cifs = $vName+"$"}
# Create the volume on the selected aggregate
If ($x -eq "0") {New-NaVol -Name $vName -Aggregate $MyAggr -Size $vSize -Confirm:$false | Out-Null}
# Create the Qtree in the new volume
If ($x -eq "0") {New-NaQtree -Path $path -Confirm:$false | Out-Null}
# Set SnapShot Reserve of new volume
If ($x -eq "0") {Set-NaSnapshotReserve -Name $vName $snapRes | Out-Null}
# Set SnapShot Schedules for new volume
If ($x -eq "0") {
If ($snapH -ne "0") {
Get_SnapHours | Out-Null
Set-NaSnapshotSchedule -Name $vName -Weeks $snapW -Days $snapN -Hours $snapH -WhichHours $snapHours | Out-Null
Else {Set-NaSnapshotSchedule -Name $vName -Weeks $snapW -Days $snapN -Hours $snapH | Out-Null}
# Set NFS Exports and delete default export
If ($x -eq "0") {
If ($Irv -eq "1") {Add-NaNfsExport -Persistent:$true -Path $path -ReadWrite @('192.128.10.0/24','192.128.28.0/24') -Root @('192.128.10.0/24','192.128.28.0/24') | Out-Null}
If ($HQ -eq "1") {Add-NaNfsExport -Persistent:$true -Path $path -ReadWrite @('192.128.28.0/24','192.130.162.0/24') -Root @('192.128.28.0/24','192.130.162.0/24') | Out-Null}
If ($V -eq "1") {Add-NaNfsExport -Persistent:$true -Path $path -ReadWrite @('192.128.10.0/24','192.128.28.0/24') -Root @('192.128.10.0/24','192.128.28.0/24') | Out-Null}
Remove-NaNfsExport -Paths $volPath | Out-Null
# Turn off Access Time Update on new volume
If ($x -eq "0") {Set-NaVolOption $vName no_atime_update on | Out-Null}
# Set Fractional Reserve for new volume to 0
If ($x -eq "0") {Set-NaVolOption $vName fractional_reserve 0 | Out-Null}
# Set unicode options for new volume
If ($x -eq "0") {
Set-NaVolOption $vName create_ucode on | Out-Null
Set-NaVolOption $vName convert_ucode on | Out-Null
# Set ASIS for new volume
If ($x -eq "0") {
If ($yesAsis -eq "1") {
Get_Asis | Out-Null
[string]$asisTime = "sun-sat@"
$asisTime += $asisHours
Enable-NaSis $vName | Out-Null
Set-NaSis -Path $volPath -Schedule $asisTime | Out-Null
# Set AutoGrow for new volume
If ($x -eq "0") {Set-NaVolAutosize $vName -Enabled -MaximumSize $vSize2 -IncrementSize "20g" | Out-Null}
# Add hidden CIFS share for new volume
If ($x -eq "0") {Add-NaCifsShare $cifs $path | Out-Null}
# If selected, add NFS exports to ESX hosts
If ($x -eq "0") {
$NFShost = Get-NaNetInterface | Where {$_.PrimaryAddresses -like "192.128.2*"} | Select PrimaryAddresses | ForEach {$_.PrimaryAddresses}
If ($NFShost) {
If ($ExpVC -eq "1") {
If ($Irv -eq "1") {
$MyDC = "DC1"
ExportESX $MyDC $vName $path $NFShost | Out-Null
If ($HQ -eq "1") {
$MyDC = "DC2"
If ($V -eq "1") {
$MyDC = "View"
Else {NoNFS $MyFiler}
# Display message if volume was created or if script was aborted
If ($x -eq "0") {Source_Vol_Created}
##DR VOLUME##
# Run the Select_DRFiler Function to select a Filer to add the backup volume to
If ($x -eq "1") {Select_DRFiler $DR_filers | Out-Null}
# Connect to selected DRFiler and get Aggregate variables
If ($x -eq "1") {
$drfiler1 = Connect-NaController $MyDRFiler
$dr_aggrs = Get-NaAggr
$dr_aggr1 = Get-NaAggr | Select-Object Name, SizeAvailable, SizeTotal, BlockType | Sort SizeAvailable -Descending
# Run the Select_DRAggr Function to select the aggregate to create the DR volume on
If ($x -eq "1") {
Select_DRAggr $dr_aggr1 $dr_aggrs | Out-Null
$DRblock = Get-NaAggr $MyDRAggr | Select BlockType | ForEach {$_.BlockType}
If ($x -eq "1") {DRVol_Details $vName $drVsize $DRblock | Out-Null}
If ($x -eq "1") {
[int]$DRvSize1 = $drVsize
$DRvSize1 += 200
[string]$DRvSize3 = $drVsize
$DRvSize3 += "g"
[string]$DRvSize2 = $DRvSize1
$DRvSize2 += "g"
# Set path
If ($x -eq "1") {
$DRqPath = "/vol/"+$DRvName+"/"+$vName
$DRvolPath = "/vol/"+$DRvName
If ($x -eq "1") {$DRcifs = $DRvName+"$"}
If ($x -eq "1") {New-NaVol -Name $DRvName -Aggregate $MyDRAggr -Size $DRvSize3 -Confirm:$false | Out-Null}
If ($x -eq "1") {
$DRsnapRes = "0"
Set-NaSnapshotReserve -Name $DRvName $DRsnapRes | Out-Null
If ($x -eq "1") {
If ($snapW -or $snapN -or $snapH) {
If ($DRsnapH -ne "0") {
Get_DRSnapHours $sourceSnapH | Out-Null
Set-NaSnapshotSchedule -Name $DRvName -Weeks $DRsnapW -Days $DRsnapN -Hours $DRsnapH -WhichHours $DRsnapHours | Out-Null
Else {Set-NaSnapshotSchedule -Name $DrvName -Weeks $DRsnapW -Days $DRsnapN -Hours $DRsnapH | Out-Null}
Else {NoSourceSnap}
If ($x -eq "1") {Set-NaVolOption $DRvName no_atime_update on | Out-Null}
If ($x -eq "1") {Set-NaVolOption $DRvName fractional_reserve 0 | Out-Null}
If ($x -eq "1") {
Set-NaVolOption $DRvName create_ucode on | Out-Null
Set-NaVolOption $DRvName convert_ucode on | Out-Null
# Set DR ASIS Options
If ($x -eq "1") {
If ($DRyesAsis -eq "1") {
Get_DRAsis $sourceASISH | Out-Null
[string]$DRasisTime = "sun-sat@"
$DRasisTime += $DRasisHours
Enable-NaSis $DRvName | Out-Null
Set-NaSis -Path $DRvolPath -Schedule $DRasisTime | Out-Null
If ($DRYesComp -eq "1") {Set-NaSis -Path $DRvolPath -Compression:$true | Out-Null}
If ($DRYesInL -eq "1") {Set-NaSis -Path $DRvolPath -InlineCompression:$true | Out-Null}
# Create Mirror
If ($x -eq "1") {
Get_MirrorHour $sourceSnapH | Out-Null
Set-NaSnapmirrorSchedule -Source $filer1":"$path -Destination $drfiler1":"$DRqPath -Minutes "0" -Hours $MirrorHour -DaysOfWeek "*" -DaysOfMonth "*" -Confirm:$false | Out-Null
Invoke-NaSnapmirrorInitialize $drfiler1":"$DRqPath $filer1":"$path -Confirm:$false | Out-Null
If ($x -eq "1") {DR_Vol_Created}
If ($x -eq "2") {Vol_Aborted}
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
Continued non-compliance may result in NetApp Community account restrictions or termination.
