EF & E-Series, SANtricity, and Related Plug-ins
HPE DAC Cable
Ghassan
Hi,
Do you know if we can use the below HPE DAC Cable and HP Switch to connect to the NetApp Storage EF280 ???
JH295A
HPE 1950 12XGT 4SFP+ Switch
JH695A
HPE X240 10G SFP+ SFP+ 3m DAC C-Cable
2 REPLIES 2
loganb
this question will be better suited under this forum below.
http://community.netapp.com/t5/All-Flash-FAS-EF-Series-and-SolidFire-Systems/ct-p/flash-storage-systems
couple resources you can use to verify the cabling:
The NetApp® Interoperability Matrix Tool (IMT) defines the qualified components and versions you can use to build FC/FCoE, iSCSI, NFS and CIFS configurations.
https://hwu.netapp.com/Controller/Index?platformTypeId=2357027
andris
What is the exact HW configuration of the EF280?  (What variant, HIC installed, etc.)
Generally, 10GbE SFP+ twinax cable connections with 3rd party switches "just worK", especially if you use the switch's approved cables - it's standards-based and usually reliable.
