Active IQ Unified Manager Articles and Resources
The Pirate Pack for VMWARE v1.0 - Vfiler and Array Provisioning and Management for VMWARE ESX
goodrum
NOTE: This version has been deprecated and replaced with v2.0 for VMware
The Pirate Pack for VMWARE v1.0 - 2012-07-24
These workflows are used to manage VMWARE Datastore creation for all three protocol options - FCP, iSCSI, and NFS.  Both the iSCSI and NFS workflows support direct Array and Vfiler integration.  Both workflows also support creation of VLAN tags and IPspaces.  These workflows will create the storage on the NetApp Controller and present based on the appropriate protocol.  Using the VMWARE Powershell toolkit integration, the newly created storage will be presented to the ESX Cluster selected and new Datastores will be created.
Note: The FCP workflow requires that Zoning be setup prior to execution.  If new VLANs are created then those will need to be configured on the switch prior to executing the iSCSI or NFS workflows.
Workflows Included:
VMWARE FCP Datastore
  • Create a new FCP iGroup
  • Input for number of new Volumes to create with one Lun per Volume. Each Lun created will be the same size.
  • Starting Lun ID otherwise, the next number available to the iGroup will be used.
  • vCenter information and ESX Cluster to create Datastores
  • ESX Path Select Policy option
  • New VMFS Datastore command based on NAA ID of the Lun
VMWARE iSCSI Datastore with Vfiler Support
  • New Optional VLAN and/or Ipspace
  • New Vfiler Root Volume and Vfiler instance
  • New iSCSI iGroup
  • Add iSCSI Connection details to all hosts in the ESX Cluster
  • Optional Storage IP connection details
VMWARE NFS Datastore with Vfiler Support
  • Input for number of new Volumes to create.  Each volume created will be the same size.
Additional Features:
New Finders:
  • Find Lun by Full Path on Array
  • Find iGroup on specific array
  • Find the last volume created in a series
  • Find Volume Based on Name and Array
New Dictionary Objects
  • NFS_Datastore
  • VMFS_Datastore
  • Vfiler_Full
New Functions
  • convertFromGB
  • isValid
  • retBoolean
  • setNextID
  • returnNamePadded
  • padAndConcat
New Commands
  • Create vFiler Full
  • Create IPspace
  • Create NFS Datastore Full
  • Create VMFS Datastore Full
  • Rescan HBA - VMWARE
WFA: 1.1.1.22.5 B7752
Please Note:
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information (PII)
  • Copyrighted materials without the permission of the copyright owner
Continued non-compliance may result in NetApp Community account restrictions or termination.
Replies
hill
Jeremy,
This is fantastic!  Great work as always!!!
-Kevin
menzies
Jeremy,
Great work, thanks for sharing with the community.
Regards,
Craig
cvanagt
Hello Jeremy,
thank you so much for sharing this fantastic tool with the community !
Very best regards from France,
Cyril VA
goodrum
Cyril,
Thanks for the comments.  I have just released a newly updated version specifically for Workflow Automation 2.0.  Check out the new version
Jeremy Goodrum, NetApp
The Pirate
Twitter: @virtpirate
www.virtpirate.com
