Don't have an account?
ONTAP Hardware
Hello,
I have a new storage system FAS2650 with two controllers in same chassis and ontap 9.1, I want to know if there is an additional configuration to create a HA pair and cluster HA or the configuration is built-in by Netapp. Thanks
Solved! See The Solution
Hi,
It has built in configuration. Refer https://library.netapp.com/ecm/ecm_download_file/ECMLP2316768
Here’s a video that explains how to change the security style of a volume from Unix to NTFS in ONTAP 9
Join our Discord Community
