Don't have an account?
ONTAP Hardware
Just looking at a DS14 MK2 RS-1401 p/n 430-00010+B0 XYR. It has 14x 147GB 10K FC disks
Would they be compatible with a FAS2040? Is it capable of 4Gps FC?
Solved! See The Solution
MK2 is 2GBps , it should work.
Thanks
Hi Paul,
Appreicate if you could share with the steps such as format all the disks before create aggr etc.
Thanks,
katherine
Did you know you can receive a notification when new software releases are published to the NetApp Support Site?
Join our Discord Community
