Hello All,
I have FAS 3240 Cluster and one of the controller is giving me messages that
Netappctrl1 monitor.nvramLowBatteries:alert]: NVRAM batteries are dangerously low.
Netappctrl1 monitor.nvramLowBatteries.notice:notice]: If the NVRAM batteries are "" dangerously low, the system shuts down automatically "" every 24 hours to encourage you to replace them. "" If you reboot the system it will run for another "" 24 hours before shutting down.
Netappctrl1 monitor.shutdown.nvramLowBatteries.pending:warning]: NVRAM batteries are dangerously low. Halting system in 24 hours. Replace the batteries immediately!
I completely understand that I will have to replace the NVRAM battery and I have also refered the Kb article on Netapp which is failry easy to understand except a single thing which I want to confirm
https://www.buyfromnorbain.com/Documents/ocw/0539740~Document~1.pdf
I need to check how many modules I have for NVRAM inside Netapp
