I am using the NMSDK for ontap in cluster mode with python. I am wondering if it is possible to set options that are accessible in advanced mode via API.
for example:
- Volume atime-update
- nfs tcp-max-xfer-size
Thanks,
Pierre
You'll want to use the "volume-set-option" API to set the "no_atime_update" option to off. For cDOT, this is in the vserver context. Make sure the user you connect with has enough privileges to access advanced level.
I can't find anything in the API docs about the NFS tcp-max-xfer-size setting, so you may need to use a different method to set that.
Andrew
@asulliva How to set advance option?
like I am trying RPC approach for snapdiff (ZAPI V2)
But I am getting below error:
{u'results': {u'@errno': u'13005', u'@reason': u'Unable to find API: sd_rpc_connect on data vserver NAS_SVM', u'@status': u'failed'}}
Do we need to set any option to get "sd_rpc_connect" api enable via NMSDK
