Hi all,
does anyone know if a FAS2554 power supply could be installed in a DS4246?
Thanks in advance.
The Hardware Universe under Field Replacement Unit Parts has 2 PSUs for the FAS2554 https://hwu.netapp.com/Controller/Index?platformTypeId=2032#none
Mktg Part No Mfg Part No DescriptionX518A-R6 114-00070 PSU W/Fans,580W,AC,DS4243/4246,FAS2240-4X522A-R6 114-00026 PSU W/Fans,580W,AC,Energy Star,DS424x
It also has the same 2 PSUs for the DS4246 https://hwu.netapp.com/Shelves/Index?osTypeId=2032#none
It therefore looks like both PSUs from the FAS2554 can be used for the DS424x shelves.
Cheers.
NetApp lists these as two different part #s:
DS4246: X518A-R6
FAS25xx: 215-07880_A0
The shelf PS is 580w - not sure about the FAS one. I'd be very cautious about doing a mix/match even if the PSU seems to "fit". A power-sag due to a mismatched PSU could lead to all sorts of unplanned outages...
Me too!
This is the reason for my question!
That's what I wanted to hear...read!
Thank you very much!
hiThe highest version of DS2554 ONTAP supports 9.8, the following is my query for your reference
