Hi All, I'm trying to figure out the best way to convert our existing LUNs and Volumes from thin to thick provisioned.
Is it literally as simple as opening the OnCommand System Manager and:
1. Editing a volume to take the check off of the Thin Provisioned check box
2. Editing a LUN to remove the Disable Space Reservation
I currently have an 18.06TB aggregate and x4 volumes of 5, 6, 4 and 2TB. I also have x4 LUNs all of exactly the same sizes. NetApp support said that the Volumes should be 5% larger than the LUNs so I will need to increase these slightly.
Can anyone see any issues with changing this as above or are there additional steps that would have to be taken via the commandline. All of these LUNs are production facing and in use, would there be any impact/downtime when doing this?
Also after changing to thick provisioned Volumes + 5% for each I'm taken to 17.85 out of 18.06TB used. This is getting very close to capacity, can anyone see any issues around this? Do I need to leave any space free for system functions etc?
I would really appreciate any help, thanks!
