Hi All
Looking for a little advice before i log a case as we are flat out of ideas.
We have multiple environments with 8020s running On-Tap 9.1 each has a vCenter and each has an instance of the VSC Appliance (7.1) installed.
However 2 of these have the same problem which i cannot bottom out.
They both see the storage arrays (as they should.)
They both see all volumes (as they should.)
However when the box is checked "Enable VASA Provider" is sellected it waits for a while and then spits out an error that there is an issue with a certificate.
vCenter registration of the VASA provider failed. An invalid HTTPS certificate was detected and rejected by the VASA provider 185 Seconds ago.
Please regenerate your vCenter Storage monitoriong Service Certificate and then re-try registration.
Ive looked all through vCenter and cannot find an expired certificate or a cert for Sto (these certs are issued from our CA Cert Server)
So far I have..
De-registered and re-registered the VSC
De-registered and re-registered the VSC and confirmed Folders are removed from the vCenter
Manually de registered the VSC and re-registered with vcenter reboot
Deregistered the VSC Regenerated the VSC appliance certs and re-registered with vCenter
All to no avail, i have no idea where it is looking for these certs..
Any Ideas ...?
