Hi,
While trying to copy the image to the cluster for ontap upgrade using FTP..getting error message "Cannot find the url path specified ".
Any tips to fix the issue.
Thanks
Naga
Ontap version is 9.0. Yeah the FTP path is correct one. Fortunately using HFS HTTP program.
Downloaded the HFS~ HTTP program and just ran it and dragged the image under the home directory. And uploaded the image with the command "cluster image package get -url http://path"
Thank you
Hi, Naga
You need to be sure about your FTP and path
Can you check FTP server on your PC ?
FTP xxx.xxx.xxx.xxx
And see the real path to your file
So, wath's your cDOT version ?
