Hello,
Kindly need some help with wiring the FAS2240-2 (dual controller) and a one(1) DS2246 unit.
Found this https://library.netapp.com/ecm/ecm_get_file/ECMP1193604 & https://library.netapp.com/ecm/ecm_get_file/ECMP1149275 . (appear the same)
followed section 3c (double controller model), that have more then one DS, so I assume maybe with one DS wiring would be wrong as we have it.
The issue is that we're see from web UI the alerts as if DS2246 is only connected to one IOM controller on FAS2240-2 instead of to both. Tried changing cable and replacing with a new one, same issue appears. 😞
Does anyone have a wiring diagram that they can share how it should be just with one filer and one disk-shelf?
Asked DC to get Config Advisor installed on VCenter/WIN server but they claimed, hardly anything there to take into consideration. Will ask them to try again also on this once the wiring is confirmed.
Btw: This setup used to work on a previous location with both FAS & DS to both controllers. Nothing has changed at new location besides re-racking and re-wiring. Is there some command that needs to be executed maybe that we can try?
Much appreciated ahead of time, and hope I can share with DC folks to troubleashoot this issue. My hunch is that also the 2nd replacement (new) cable is maybe also faulty.
Thanks everyone,
Geo
