I have installed Snapcenter in my environment and I am having issues adding storage systems and host the errors I am facing are as attached. The chose storage type area is grayed out. Please let me know if one has a solution to this issue
Hi Zagwa,
With SnapCenter you can register/add ONLY SVMs.
What you see is expected behavior, as designed. Support for registering/adding cluster is coming in the upcoming release.
You have to connect to the SVM, not the cluster.
The thing is, where I need to select sorage type is sort of grayed out, I can't make a selection and ONTAP SVM sort comes in as default as is locked there
