Hi,
I have upgrade my FAS2554 from 8.3 to 9.1. All works fine but about every 5 minutes in the Events Log I found this debug messages:
acp.command.connect: Could not establish connection with 192.168.2.145.
I read that starting from ONTAP 9 ACP move from out-of-band to in-band for communications, but I have no idea how to switch or solve for my case.
Here my configurations:
cluster2::> storage shelf acp module show
Node Module Name State
cluster2-node01 1.0.B connection-error
1.0.A connection-error
cluster2-node02 1.0.B connection-error
4 entries were displayed.
cluster2::> storage shelf acp show
Node Channel Connectivity
cluster2-node01 out-of-band full-connectivity
cluster2-node02 out-of-band full-connectivity
2 entries were displayed.
cluster2::> storage shelf acp show -instance
Node: cluster2-node01
Channel: out-of-band
Enable Status: true
Port: e0P
IP Address: 192.168.2.55
Subnet: 192.168.0.1
Netmask: 255.255.252.0
Connection Status: full-connectivity
Node: cluster2-node02
Enable Status: true
Port: e0P
IP Address: 192.168.1.253
Subnet: 192.168.0.1
cluster2::> storage shelf acp module show -instance
Module Name: 1.0.B
Adapter Name: 0a
MAC Address: 00:a0:98:c6:ea:91
IOM Type: iom6e
Shelf Serial Number: SHJHU1702000451
IP Address: 192.168.2.145
Protocol Version: 2.1.01.22
Firmware Version: 01.22
Assigner ID: 537067641
State: connection-error
Last Contact: 514
Module Name: 1.0.A
Adapter Name: 0a
MAC Address: 00:a0:98:c6:ed:91
IOM Type: iom6e
IP Address: 192.168.1.145
State: active
Last Contact: 36
Module Name: 1.0.B
Adapter Name: 0b
IOM Type: iom6e
Last Contact: 514
Module Name: 1.0.A
Adapter Name: 0b
IOM Type: iom6e
State: active
Last Contact: 36
cluster2::> system service-processor show
IP Firmware
Node Type Status Configured Version IP Address
cluster2-node01
SP online true 2.4.1P2 192.168.7.210
cluster2-node02
SP online true 2.4.1P2 192.168.7.211
I read the KB https://kb.netapp.com/app/answers/answer_view/a_id/1029778 but I have no understand if for my setup is sufficient an
storage shelf acp configure -is-enabled true -channel in-band
or can cause problems if firmware or similar are not at the right version.
Thanks
