Hi,
We have a Snap Creator workflow using a Vault XDP relationship type and we are planning to convert that relationship to a Mirror and Vault XDP type, which is became the default with later releases of ONTAP.
In Snap Creator, we had only the Vault tab configured and that worked fine. The workflow broke and backups are failing after converting the relationship from Vault to "Mirror and Vault". We changed the Snap Creator configuration from Vault to Mirror but that only updates the destination DP volume but not pushing the snapshots from the source to the destination, leaving us without the backup solution and ability to recover from an earlier snapshot at the destination.
What are we doing wrong?
Thanks
