Hi,
I would like to know if Aggregate level deduplication will be available for disk based aggregates, as opposed to AFF systems.
Thanks
Henry
Thanks. I was guessing that would be the case.
For my problem, high performance is not an issue.
What happens is that we have volumes snapvaulted in 7 mode, and in order to save space, we have created clones so we can continue the snapvault without creating a baseline
As we are migrating these volumes to cDOT, we have to undo the clones, which would hydrate the data and remove any savings we are having.
In the future, even if the snapshot count has been increased, it seems aggregate deduplication is a better option than cloning from a long term perspective
Thanks again
I agree!
I think aggregate-level deduplication is a massive saver and it compliments SSD, b'cos it means you will need lesser SSDs to store same amount of data. However, b'cos the dedupe is at the aggregate level, which means deciding whether to have dedupe enabled or not on a performance centric volume will no longer be a choice. Unless you have serious doubts about the future perfomance impact and stakes are high, then you will be forced to create a dedicated aggregate and put all the non-performance centric volumes on it.
I guess the game changer is the SSDs & Multi-core CPUs systems (AFF) for Aggregate-level-dedupe.
At this moment, the value of SSD for archiving is not there yet to move data to SSD.
In my circumstance, the volumes we are snapvaulting are expected to have over 7 year retention periods, and I think moving them to SSD does not provide sufficient value. I think it will be in the future, as SSD sizes are much larger than NL-SAS, so eventually, pricing per TB will decrease
Of course, we could move to other Ontap technologies, such as Altavault, but for now, I think snapvault provides a simple enough environment for us to think outside the box
