Hi,
I am loking for REST API to mount the existing volume at junction point
You can use the swagger interface on your cluster via "https://<cluster>/docs/api". Here are some examples, start by querying the volume for the state and UUID. EG:
Method: GetURI: https://cluster1.testlab.local/api/storage/volumes?svm.name=vserver1&name=volume1&fields=uuid,state{ "records": [ { "uuid": "ac1b73fd-ebbc-11e9-865d-005056804db6", "name": "volume1", "state": "offline", "svm": { "name": "vserver1" } } ], "num_records": 1}
Once you have the volume UUID you need to ensure the volume is in an "online" state before it can be mounted (note that in the above example the state is "offline" so you first need to invoke a Patch request to online the volume).
Method: PatchURI: https://cluster1.testlab.local/api/storage/volumes/ac1b73fd-ebbc-11e9-865d-005056804db6{ "name": "volume1", "state": "online"}
Using the volumes UUID you can then mount the volume in the vservers namespace. EG
Method: PatchUri: https://cluster1.testlab.local/api/storage/volumes/ac1b73fd-ebbc-11e9-865d-005056804db6{ "name": "volume1", "nas": { "path": "/volume1" }}
The REST API will provide JSON ouput that contains the Job UUID number. EG
{ "job": { "uuid": "b1fd3fc1-f47f-11e9-865d-005056804db6", "_links": { "self": { "href": "/api/cluster/jobs/b1fd3fc1-f47f-11e9-865d-005056804db6" } } }}
You can then query the status of the job:
Method: GetUri: https://cluster1.testlab.local/api/cluster/jobs/b1fd3fc1-f47f-11e9-865d-005056804db6{ "uuid": "b1fd3fc1-f47f-11e9-865d-005056804db6", "description": "PATCH /api/storage/volumes/ac1b73fd-ebbc-11e9-865d-005056804db6", "state": "success", "message": "success", "code": 0, "start_time": "2019-10-22T14:54:49+11:00", "end_time": "2019-10-22T14:54:59+11:00"}
Hope that helps?
/Matt
Hi Taran,
not sure what you want to do but here:
https://library.netapp.com/ecm/ecm_download_file/ECMLP2854934
you can find the Ontap9 RestApi Docu, I assume you use Ontap 9.
On page 20ff. is descriped how to use the API,
Cheers,
Henrik
thanks Matt for the answer. It was of great help
No problem, happy to help. If you have ever considered using Ansible for automation orchestration here's a link to explore. This provides an easy method for customers to use NetApp API's without the complexity of programming:
https://netapp.io/2018/10/08/getting-started-with-netapp-and-ansible-install-ansible/
To provide a simple example based on your use case (mounting an offline volume). EG:
cluster1::*> volume show -vserver vserver1 -volume volume1 -fields volume, state, junction-pathvserver volume state junction-path-------- ------- ------- -------------vserver1 volume1 offline -
An ansible playbook can be used to define the desired state of the volume and set the tasks to peform (first online the volume and then mount it). EG
---- hosts: localhost gather_facts: false name: Mount Volume vars: login: &login hostname: cluster1.testlab.local # NetApp Cluster IP username: ansible # Ansible Cluster User password: N0tMyP@ssw0rd! # Ansible Cluster Password https: true validate_certs: false vserver: vserver1 volume: volume1 tasks: - name: Online Volume na_ontap_volume: state: present name: "{{ volume }}" vserver: "{{ vserver }}" is_online: yes <<: *login - name: Mount Volume na_ontap_volume: state: present name: "{{ volume }}" vserver: "{{ vserver }}" junction_path: "/{{ volume }}" <<: *login
Running the playbook ensures the volume is configured to the desired state you defined. EG
[mbeattie@testux01 playbooks]# ansible-playbook mount_volume.yml [WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'PLAY [Mount Volume] *********************************************************************************************************************************************************************************TASK [Online Volume] ********************************************************************************************************************************************************************************changed: [localhost]TASK [Mount Volume] *********************************************************************************************************************************************************************************changed: [localhost]PLAY RECAP ******************************************************************************************************************************************************************************************localhost : ok=2 changed=2 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
Comparing the storage configuration after running the playbook shows that the volume is now online and mounted.
cluster1::*> volume show -vserver vserver1 -volume volume1 -fields volume, state, junction-pathvserver volume state junction-path-------- ------- ------ -------------vserver1 volume1 online /volume1
This is very a simple example however it demonstrates that there are options availble for customers to easily deploy and configure NetApp storage without having to understand how to use the REST API's or develop code. Hope that's useful (or atleast interesting to know about). Please let me know if you have any questions.
Hi, Is there a way to get the junction path using uuid of a volume?It is not showing under nas section : nas.path. though the volume is mounted.
Hello !I have the same issue : I am looking for getting the junction path through REST API but no way until now ! 😮I am using ONTAP 9.8
I have figured out... we can use "Enter" to unmount the volume.variable= input("Press Enter to Unmount")nasjson = {"path": path,}dataobj['nas'] = nasjsonsample_url = "https://{}/api/storage/volumes/{}?return_timeout=15" .format(cluster, vol_uuid)result = get_res(cluster,sample_url,dataobj,headers_inc)if result[1] == "success":print(unmounted)else:print("respone",result[0])
