Hi everybody,
is it possible to disable the shutdown of the system (FAS2240 CDOT) ? We are running trainings with netapp, therefore it isnt that big problem
running without nvram:
if the NVRAM batteries are dangerously low, the system shuts down automatically every 24 hours to encourage you to replace them. If you reboot the system it will run for another 24 hours before shutting down.
