Hi,
Has anyone successfully configured an SVM DR Fan-Out configuration? According to this document https://kb.netapp.com/app/answers/answer_view/a_id/1075580/~/can-svm-dr-be-used-in-a-fan-out-configuration%3F- it is supported since 9.4 but I'm getting the error when trying to setup the second relationship that the source Vsevere is already in a DR relationship.
Thanks
Hmm, did you create both fan-out relations with identity-preserve true?
cause if yes then it is not supported
https://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.pow-dap%2FGUID-B9E36563-1C7A-48F5-A9FF-1578B99AADA9.html
Starting with ONTAP 9.4, fan-out. You can fan-out to two destinations only.
By default, only one -identity-preserve true relationship is allowed per source SVM.
And thank you for mentioning KB - we will update it
@sergey : Good catch, I see the bit 'identity-preserve ' is covered in the release notes for 9.4 but KB needs update.
Can this also be updated or made clear ?The KB example shows - Two separate Clusters for SVM DR fan-out from source: cluster-a, i.e To cluster-b & cluster-c. However, fan-out could be 2 destinations SVM on the same cluster-b as well ? Or, it has to be two separate clusters. hmm.. !
Thanks!
quckly checked in a lab
it is not possbile to have 2 SVM DR relatiosnhips from the same source to only one destination cluster
Error: command failed: Source Vserver "data" is already in a Vserver DR relationship with anotherVserver in this cluster.
which make sense
Sorry for the delayed response.
Thanks for your response. I just question whether this is truly SVM-DR Fanout?
I see the KB updated. Great thanks.
Wayne
Hi, I've a question, can we have two SVM-DR from source SVM to two different clusters
1. source SVM to DR-cluster1 - identity-preserve false
2. source SVM to DR-cluster2 - identity-preserve true
Any suggestions?
