We are running version 9.1.P8 and received a high risk report from Id:ntap-20180423-0003. What is the solution to eliminate the risk?
That security advisory - https://security.netapp.com/advisory/ntap-20180423-0003/ - looks like it is related to the OpenSSH vulnerabilities discovered in various NetApp products. There are some selectable taps across the top, one of which is "Remediation". You can see the fixed builds available for each affected product there. For 9.1, it appears that the fixed build is 9.1P16.
