I would like to know where can I get reference manual of SDK For Data ONTAP 8.2 7-mode.
I can reach below document center for old SDKs.
https://mysupport.netapp.com/documentation/productlibrary/index.html?productID=60427&archive=true
But There is no reference manual on them. (just release note only)
If you have location of the reference manual of the SDK For Data ONTAP 8.2 7-mode, please let me know.
I would like to have like below.NetApp Manageability SDK 9.3 Document
Reference Manual for ONTAP
https://mysupport.netapp.com/documentation/docweb/index.html?productID=62555&language=en-US
(This is for ONTAP 9.3's API .)
Thanks in advance.
Hello @jfushii
Here is the listing for what I have found on the Netapp SDKs.
https://library.netapp.com/ecmdocs/ECMLP2860175/html/GUID-489BE083-D5F6-4A0F-880E-BE8D843F1DB3.html
As the 8.2 7-mode versions of ONTAP are reaching End of Support, much of the documentation from the site will likely be removed.
Hope this helps!
