I am trying to execute TR-4798 (Oct 2020) SnapMirror sample (page 76). I failed to execute airflow sample.
So I break down to ansible with snapmirror operation. But still failed.
Is there any idea to solve this problem?
I execute following code.
ansible-playbook snapmirror-update.yaml
- name: "Trigger SnapMirror Update"
hosts: localhost
tasks:
- name: update snapmirror
na_ontap_snapmirror:
state: present
source_path: 'svm0:airflow_clone_20210121_090845'
destination_path: 'svm0:airflow_clone_20210121_090905'
hostname: '172.16.28.131'
username: 'admin'
password: 'ontapsim0'
https: 'yes'
validate_certs: 'False'The output is it seems http connection error.
[WARNING]: No inventory was parsed, only implicit localhost is available
[WARNING]: provided hosts list is empty, only localhost is available. Note that
the implicit localhost does not match 'all'
PLAY [Trigger SnapMirror Update] ***********************************************
TASK [Gathering Facts] *********************************************************
ok: [localhost]
TASK [update snapmirror] *******************************************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: netapp_lib.api.zapi.zapi.NaApiError: NetApp API failed. Reason - URL error:URLError(OSError('Tunnel connection failed: 503 Service Unavailable',),)
fatal: [localhost]: FAILED! => {"changed": false, "msg": "Error fetching snapmirror info: NetApp API failed. Reason - URL error:URLError(OSError('Tunnel connection failed: 503 Service Unavailable',),)"}
PLAY RECAP *********************************************************************
localhost : ok=1 changed=0 unreachable=0 failed=1 skipped=0 rescued=0 ignored=0The current volume is follows
