Can someone tell me the max DS4246 shelves that can be connected to a FAS 2554 with duel controllers?
With ONTAP 9.8 you can have 144 drives on the FAS2554.
You can have 5 shelves of that model. Max stack size is 5 for this shelf.
You can always check that on hwu.netapp.com (account required).
Regards,
Pedro.
And please be aware of this also:
Max Stack Size- up to 5 expansion shelves in the stack with HDD Drives
- up to 3 expansion shelves in the stack with SSD Drives
Hi, BillyRey
In ONTAP9.8 version, FAS2554 can accommodate up to 144 disks in the DS4246 disk cabinet, and can accommodate up to 5 DS4246 disk cages, Max Number of DS4246 Shelves 1 internal + 5 external.
The following image shows the information found on the HWU website.
