I have a FAS-2240-2 system running 8.2.5P5 7-Mode.
There is only one Aggregate and one Share, Path is /vol/data_vol1 and one Volume, data_vol1 on aggr0. Security Style is mixed.
I have created an Export for Unix and set it to Client: "All hosts", Permission: "Allow Read Write".
From my ESXi servers via vCenter and also a testing Linux machine I can see the share but I can not write files.
If I remove this "all hosts" and add an non-existing IP instead, I can not even read. So this "Exports" seems to be the reason? It also does not work when I remove All hosts and just add the clients with their IP and permission Allow Read Write.
With my Domain Admin account via Windows I can read and write. NFS Permissions are set, so this is as expected.
But why does Unix not work as expected?
Thank you for help.
