Hi guys,
I have an E2712 array with 2 controllers and I want to add a DE212C drive tray.
I have reviewed the manuals and I cannot find an example of how to make the connection. Appears as connecting DD1600 (SAS-2) trays but not DE212C (SAS-3)
Can someone help me how should I connect?
I attach the example that comes in the manual. Should I make the same connection despite being a DE212C tray?
Namely:
Controller A (port 1 exp) cabling to Tray A IOM port 1
Controller A (port 2 exp) cabling to Tray A IOM port 2
Controller B (port 1 exp) cabling to Tray B IOM port 1
Controller B (port 2 exp) cabling to Tray B IOM port 2
Is it like this or is it another way?
Thank you,
Regards,
