i had deployed "ontap tools for vmware" which is the new name for VSC for vmware.But the same problem occured again.
Which is the conttroller is unknown state ,with the following error message
"Error occurred while fetching storage system privileges: No Controller found for controller id [Unknown .x.x.x.x"
the compability is ok, as i checked from IMT,
what i had done is, add default credential, and modified the storage controller credential and re-discover again,but same result.
I had collected all the logs also from the plugin , searched for a clue, ıt is mostly like below,
any ideas???
Controller queue contents:
Unknown - 10.96.12.40 (Unknown - 10.96.12.40)
2021-08-11 14:23:10,997Z [Queue Watcher] DEBUG (DiscoveryPool) -
Host queue contents:
2021-08-11 14:23:17,121Z [qtp9361871-1901] DEBUG (VscControllers) - getPopulatedController() DISCOVERY_LOCK - for controller id: java.lang.Object@2cb58eca
2021-08-11 14:23:18,234Z [qtp9361871-1901] DEBUG (VscControllers) - GetALLCluster: getControllersWithoutHosts started
2021-08-11 14:23:18,234Z [qtp9361871-1901] DEBUG (VscControllers) - getPopulatedController() DISCOVERY_LOCK - for controller id: java.lang.Object@2cb58eca
2021-08-11 14:23:18,234Z [qtp9361871-1901] DEBUG (VscControllers) - GetALLCluster: getControllersWithoutHosts - getPopulatedControllers method call finished
2021-08-11 14:23:18,234Z [qtp9361871-1901] DEBUG (VscControllers) - GetALLCluster: getControllersWithoutHosts completed
2021-08-11 14:23:18,238Z [qtp9361871-1901] DEBUG (VscControllers) - getPopulatedController() DISCOVERY_LOCK - for controller id: java.lang.Object@2cb58eca
2021-08-11 14:23:19,201Z [qtp9361871-1925] DEBUG (VscControllers) - getPopulatedController() DISCOVERY_LOCK - for controller id: java.lang.Object@2cb58eca
